Question about Sony Cameras
Cameera lens will not open (expand) when turned on.
The lens willnot come out. It did finally start out bit by bit, by turning the camera on and off. Now the lens will not go back in. I can turn on the camera to review pictures.
    Scholar:
  • 89 Answers
Please check whether you're using a fully charged battery.
After fully charging the battery if the issue still persists, please try Power Resetting the Camera.
To Power Reset the Camera.
First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Posted on Jun 17, 2009
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
The problem is that the camera cannot open the front eye, when you turn on the camera it does not come out. and at the end it say lens error, restart camera, but still do the same thing. help cause i want...
Its a common error with cameras with retractable lenses. It could be a grain of sand stuck in the slide parts of the lens. Another cause is accidentally pressing the ON button when the camera is in its case.
The solution is usually "helping" the camera lens to come out. This is a tricky job because it requires putting pressure (by pulling) on sensitive lens parts. If you're not comfortable with that, ask someone else to have a look at it.
I've had one IXUS 860 which could not be recovered from the lens error. The second IXUS 860 had the same error - the lens however moved finally after turning the cap for a bit. In the first case it was sand. In the second had tried to push the lens out while in its case - the ON button was pressed.
Jul 04, 2011 | Canon PowerShot SD880 IS / Digital IXUS...
Camera lens wont open
Saw a similar problem recently, same cause, and result was the lens was jammed.
Did manage to wiggle it free after many attempts...it only stays on for a few seconds before faulting and going off...but it's a bit hard to get a hold on the edge of the lens to pop-out the low side.
Started by laying it on it's back and checking the level of the lens edges for the low spot, then used a thick sewing needle to lift up while turning the unit on (again and again) until the gear-ring popped back in during the lens-check at start-up.
Apr 06, 2010 | Casio Exilim EX-Z40 Digital Camera
The camera shutter wont open
if the camera is turning on and the lens pops out, it is not fully expanding. this may be because the camera was dropped and now the lens guide is damaged.
Nov 07, 2009 | Nikon Coolpix S550 Digital Camera
Kodak EasyShare One lens won't open - camera cycles on/off
I had the same problem. Even though I was keeping the camera on the dock all of the time to charge it, the solution was very simple - get a new battery for inside the camera.
I bought new ones at a greatly reduced price on eBay. Now I carry one with me wherever I go in case the battery wears out/down.
I shoot a lot of videos, so it really takes a lot out of the batteries.
Dec 15, 2008 | Kodak EasyShare One Digital Camera
Camera won't function - "E18" (Canon PowerShot S230)
Try lightly tapping lens on a hard surface. This sometimes reseats the lens. If this does not work take to bits and reassemble.
Dec 13, 2008 | Canon PowerShot A75 Digital Camera
Digimax 430 camera won't turn on
If your lens is open and the camera turns off after those dreaded beeps, I have a fix for your problem. Basically, for this model of camera, the lens first pushes out a bit and then it retracts into the camera. Well, my lens got stuck on the pushout and it prevented the camera from turning on. I used some finger pressure and wiggled the lens a bit. Then I turned it on and it retracted to where is was supposed to be to take pictures. Then I turned it off and it retracted into the camera. Problem solved!
Nov 05, 2007 | Samsung Digimax 430 Digital Camera
Samsung Digimax V4 Power Consumption
I had similar symptoms as well until it finally died: 1) First started eating batteries like crazy, especially standard AA and rechargeables. The CRV3 seemed to work a bit longer. 2) One day out of nowhere the autofocus stopped working. I replaced the batteries and it worked again for 10 shots. Then the autofocus stopped working and battery died (with the lens stuck open). Pressing power, the LCD backlight flashes on, the LED in the view finder blinks, and the lens motor makes noise. Then nothing just stuck open. 3) Again new batteries and was able to close lens, take a few pictures and dead again with lens stuck open - same problem in 2. 4) Replaced the batteries a couple times and was able to get a shot or two off, and now its complete stuck open, even with brand new batteries - with same problem in 2 it just won't turn on. I finally sent it to Samsung the week of Christmas. I called Friday 1/7/05 to check and had to leave a voicemail. They called back Monday 1/10/05 to let me know they recieved it and that I should call back Thursday to check its status.
Sep 12, 2005 | Samsung Digimax V4 Digital Camera
Cameras Logo
85 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
