Question about Kenmore 3.2 cu. ft. Top Load Washer
Washer fills up but does not spin or agitate - Kenmore 3.2 cu. ft. Top Load Washer
  • llycabl Jun 15, 2009
    we have a maytag washer model number pav5158aww, the wash tub will fill up but then it will not agitate or if you put it on spin it will not spin out the water. It will trip the circuit switch if it is left on.
    I would like to also know how we could fix this ourselves..with diagrams..instructions etc...
    Thanks
    Scholar:
  • 60 Answers
Kenmore machines are made by "Whirlpool" and whirlpool washers have a peculiar timer on their direct drive models. (if there is no belt on the motor, then it is direct drive)
The symptoms are, when you open the lid at the end of the cycle,the tub hasn't drained. You can hear the motor running during the entire cycle, but it doesn't spin or drain. These units have a 'direct reversing' motor and to reverse the direction the timer interrupts the power to it. When (if) the timer becomes worn, the timer doesn't (can't) tell the motor to reverse. It continues running in one direction and can't perform its cycles properly.
However, every time you open the lid, you stop the machine...interrupting power and 're-setting' the timer. It will now run in the opposite direction until you lift the lid again.
Because of the reversing motor, you may get different "symptoms" at different times. The solution is to change the timer. These (timers) run between $150 - $200 PLUS the service call .If you are handy and the machine is not terribly old it is not a difficult job. If you are not handy or the switch is TOO much, buy a NEW machine (sorry)
check the motor, check the belt ,check the lid switch. If it's not one of those....it's the timer!!!
Cheers!
Ryan
Posted on Jun 15, 2009
  • 6,784 Answers
HI. there are two issue that can cause this malfunction. one is the top lid pressure switch. This switch is connected to the timer/control and the motor as well. if this switch is malfunctioning or damaged, it will not allow the washer to spin or agitate. Check the lid pressure switch for its operational value. make sure it is not loose or broken. check the wires that connect to the back of the switch as well for a good fit. if the lid switch is working and, the wires are connected properly to this switch, this will confirm timer/control failure. you will need to replace the timer/control asap if possible in this case.
The most common cause of the malfunction will be timer/control failure but, i recommend checking the top lid pressure switch before replacing the timer/control module.
The switch can be tested with a Ohm meter.
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My WHDSR109J8WW Top Load Washer will not agitate or spin. When to the spin cycle something clicks as if trying to spin but does not. Checked belt...fine. Did the reset motor troubleshoot...did not help....
hi Jlove.
Washer Fills but Does Not Agitate. If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts..
Washer Doesnt Agitate or Spin
Top Load Washer will not agitate or spin Google Search
Dec 13, 2017 | GE Washing Machines
Why wont my washer agitate
must be worn out dogs
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer will not agitate but fills/drains/spins
Could be related to pressure switch which measures the amount of water in tub. Does it fill and then just sit there?
Nov 13, 2009 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Open Questions:
See all Kenmore 3.2 cu. ft. Top Load Washer Questions
Kenmore 3.2 cu. ft. Top Load Washer Logo
73 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
