Question about Frigidaire ATF6000ES Front Load Washer
Front load Fridgidaire ftfb4000fs1 won't spin
Washer runs through all the cycles but will not spin. Tub turns during wash but will not spin. Also somewhat noisy during spin cycle. Belt is fine. Where should I start to look to detect problem?
  • Anonymous Mar 29, 2014
    Why is the washer tub not spinning during wash cycle?
  • 6,784 Answers
This is a fault that resides within the motor control board. you will need to replace this failed module asap if possible. it has failed.
Posted on Jun 15, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Model #ftfb4000fs1 frigidaire front load washer will not go into final spin --- drains but will not spin dry
Just had this problem last week. The problem was the door switch, which made no sense to me since the drum still turned on the other cycles. But the repair shop replaced the ($76!) switch and the machine now works fine.
Oct 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Fridgidaire Washer has a loud knocking noise during spin cycle.
You need to replace your washer, the Inner tub Spider broke.. I repaired mine, With me doing the labour, $285 just for the part alone. plus about 3 to 4 hours labour.
Mar 14, 2009 | Frigidaire FWTBB30DS Front Load Washer
Frigidaire ftfb4000fs1 front load washer will not spin
hello **** theres a circuit board on the back or on the side called a module this controls the spin cycle there could be dry joints on the board or component may have fail good luck
shaun
Jan 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer--Tub won't move
what a bogus website you are. you offer no free support and you should say so
Jul 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
370 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
