Question about Sony SLV-685HF VHS VCR
SONY SLV-685HF VHS VCR WILL NOT EJECT
THE UNIT WILL ACCEPT THE TAPE BUT WILL NOT EJECT IT WHEN THE EJECT BOTTON (BOTH ON THE UNIT OR THE ZAPPER) IS DEPRESSED. IT SEEMS TO GET OBSTRUCTED ON THE LEFT REAR CORNER (WHEN FACING THE UNIT). tHE CABLE SYSTEM TO THE TV COMES FIRST THOUGH THE UNIT AND WHEN THE CABLE LINE AND THE SOUND LINES ARE UNPLUGGED THE TV PICTURE AND SOUND GETS CUT OFF. ie IF THE UNIT IS REMOVED (UNHOOKED) THE TV IN NON OPERATIVE.
2 Suggested Answers
  • 4234 Answers
SOURCE: Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Dan
Posted on Aug 31, 2009
I try to load a tape but it does not go all the way and ejects in 3-5 seconds.
You have a defective loading basket, it is not cost effective to repair.
Jan 03, 2011 | Sony SLV-685HF VHS VCR
Where can I get a remote control for the Sony VHS SLV 685HS?
You can get a duplicate of the original remote (new or used) here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=SLV-685HF&uuid=12875134515770 for the 685HF. I can not find the SLV 685HS is not a valid model that I can find at either Sony Parts or Remotes.com.
However, a refurbished remote for the SLV685HS is listed at: http://www.replacementremotes.com/SONY/Buy-RMT-V231A-RMTV231A-147555321-Video-Remote-Control.html . (E-bay also lists a few remotes for th SLV685HS; these listings may or may not still be valid.)
I hope this helps.
Oct 19, 2010 | Sony SLV-685HF VHS VCR
Dan
Aug 31, 2009 | Sony SLV-640HF VHS VCR
Sony SLV-N60 stopped playing suddenly
Sounds like you have a head-clog. You can purchase a VHS Head Cleaner at Radio Shack for $5.00. If that doesn't work repairing your VCR is not cost effective when you consider that you can purchase a new VHS/DVD combo deck for under $125.00
Aug 17, 2009 | Sony SLV-N60 VHS VCR
Tape hanging up and will not record.
There is a threading arm that has gummed up inside the unit. I suspect that the tape is not being loaded correctly. This is a common problem with the Sony units and requires the removal of that loading arm to remove gummed up grease. Once that is completed, the unit will function correctly. Please note that the height of this swing arm is critical to the correct loading of the tape. I would not suggest you attempt this repair because the tape height adjustment needs to be exact. A local shop should be able to resolve this for you with NO parts required.
Dan
Mar 11, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Vcr does not run
Try changing the channels on the VCR itself. If you can do that, then it would indicate a problem with the VCR's remote. If you are still unable to change channels on the VCR manually, it could indicate a circuitry problem, for which you will have to get the VCR serviced.
Oct 25, 2008 | Sony SLV-685HF VHS VCR
Sony vcr model slv-m91hf
make sure the tape is not missing its tab which is on the left hand side of the tape at the back
Dec 09, 2007 | Sony SLV-M91HF VHS VCR
Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Dec 04, 2007 | Sony SLV-D300P DVD Player/VCR
Televison & Video Logo
88 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
