Question about MSI 845GVM-V (MS-7057-010) Motherboard
My usb ports dont want to work
If i plug in my ext hd nothing happen( i have a 786 msi motherboard)
  • Paul Siwek May 11, 2010
    is your external hdd powered by usb only or does it actually need a power supply plugged in also, as there may not be enough power from 1 usb port to power it, even if it's a laptop hdd, it more often than not depends on the caddy the hdd is in than the hdd itself.
    clarify what usb hdd you are using.
    ta.
  • 31 Answers
Did u install driver of the motherboard properly, if not download the driver of ur motherboard if stil not working my only advice is u buy a pci or agp usb card its look like a video card something like that then try input the new hardware or connect to the mother board what if ur card asign.
Posted on Jun 19, 2009
Front usb ports are no longer working after I plugged in an external 2.5" SATA drive. The computer automatically powered off and I had to reboot. Now when I plug in even a flash drive nothing happens....
Hello
The connector of front panel may gone disconnected, you need to check the connector inside the compute and re-connect it properly.
Hope it helps, do rate the solution if so
Dec 26, 2010 | MSI 7529-050R Motherboard
Hello, Recently I tried to back up my computer onto my EXT HD but it was not successful because of lack of storage size. Coincidintally, my EXT HD will not turn on. It all happened at the same time. I...
the problem could be from your USB. The USB of your computer might not be powering the drive.
Secondly, the hard drive wire that passes from the computer to the external drive.
Lastly, the Hard drive case could be defective and not make the drive power on.
Therefore, connect the external hard drive to another computer, in other to be sure whether the problem is from your computer's usb port or from the hard drive. This will let us know where to focus our attention.
Let me know what happens thereafter.
Take care.
Aug 15, 2010 | Computers & Internet
Failed usb headers
1) Power down or reboot your system.
2) As the pc is restarting, press the F2 button to pull up the "Setup" screen.
3) Right Arrow to the "Advance" tab
4) Make sure that all devices are enabled
5) Arrow down to "Miscellaneous Devices"
6) Make sure "External USB Ports" is also enabled
Feb 01, 2018 | Evga X58 SLI LE (25139) Motherboard
USB port problems
You need the motherboard specs, which you can look up on the internet, based on the maker.
With the USB ports, the front ones often don't include power.
So plug a powered 4 port hub into the front port, and then the hub will supply the power after that.
Jun 26, 2009 | MSI K7N2 Delta-ILSR (MS-6570-030)...
Problem with accessing my external hard drive
It's probably NOT the voltage, but the current available at a given USB port. You might try using a USB cable that has two "A" connectors on one end that connect to the computer, one for power and data, the other is just for extra power. The other end of the cable should have the appropriate connector for your external drive. By connecting the second "A" plug to the computer, you double the current available to the external drive.
Apr 28, 2009 | Computers & Internet
Onboard usb
VIA needs to stop making USB chipsets... lol... Are you sure you have USB legacy support enabled? Moreover, the default Windows XP drivers are not error free when used with a VIA Rev 5 USB Host Controller because it's actually a VIA Enhanced Host Controller. Every time I have USB problems with the VIA Enhanced Host Controller I go to there website, download the driver, and it usually fixes the problem.
USB 2.0 (VT6202, VT6212, VT6214/L)
Moreover, I have plugged in a Microsoft Wireless Optical Mouse and Windows XP could not detect it until I installed Microsoft Intellipoint; if you can believe that. Try also installing the mouse drivers as well...
Nov 27, 2008 | MSI 865GM3-LS (MS7043020) Motherboard
Creepy 'USB' issues...
During setting up computer with drivers etc. System file could have become faulty some files not registered in System
You could have System file errors these files are the heart of O/S
whereas the reg is the blood if System file are faulty things do not work properly.
Go to C:\ right click properties / Tools / error check new box popsup
tick little box to fix errors and reboot
On reboot windows will check disk for errors and fix them
If this does not help please email me at thoughts001au@yahoo.com.au
Give a details description of what happens
Aug 27, 2008 | Compaq Evo D310M 845G P4 Motherboard
MSI 845GVM-V (MS-7057-010) Motherboard Logo
109 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
