Question about Craftsman 21 hp 42 in. Deck Yard Tractor - CA Model
Removing pulleys from 42 inch Craftsman mower deck
I ran over some deer netting and it wrapped extremely tight around one of the mower blades and pully assembly. I removed the deck, removed the blade and tried cutting and used a propane torch to melt the netting entwined around the shaft but the shaft still does not turn easily. I am trying to remove the entire puuly assembly from the deck but cannot get the pully detached from the blade assembly. Any suggestion as to how to get this done. I believe if I can disassemble this and get whatever netting is still around the shaft, and then grease the shaft I should be OK.
  • 376 Answers
Put the blade back on the star on the shaft and tighten it down. Now you have some backup for the pulley nut. You may have to wedge a 2x4 between the blade and deck. THe EASIEST way is get an impact and zip it off. :-)
Posted on Jun 15, 2009
    Sergeant:
  • Craftsman Expert
  • 417 Answers
Your torch torched the plastic races in the bearings. Get a new spindle, they're maybe 30 bucks on eBay. You probably cooked the pulley bearings as well as the spindle bearings. Just get a new set, it beats taking it to a shop or buying a new mower.
Posted on Nov 21, 2013
Model # 917257620 need a diagram on how to put the deck belt on!!!
From the lower motor pulley moving back to inbetween the two smaller inside forward pulleys, around the back of the pulleys and out to the front of the larger blade pulleys. Around the blade pulleys to the back and across the back of the deck to the other pulley.
It is easier to visualize it that way, but putting it on start with wrapping it around the blade pulleys and then go to the back side of the smaller idler and tension pulleys and then inbetween them to the motor pulley.
Let me know how it goes, but that should get you going.
Aug 02, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Turn off mower blades the electric clutch spins and the two green
There should be a metal "anchor" that bolts to the chassis or engine. It has a rod that sticks downward, fitting into a notch in the clutch to keep it from turning. It must be missing or broken, or maybe the clutch is the wrong model, and that's why the clutch itself spins and rips out the wires. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
42 deck craftsman riding mower. how do you get blades off? md 91721880.
On most riding lawnmowers, you can remove the blades reaching underneath the deck while the deck is set to its highest position. This may not be possible on lawnmowers with three blades; however, most 42 inch mowers have two blades.
The blades are usually held on with either one or two bolts (on each blade). Oftentimes, too, there is a lock washer underneath the bolt.
If you have auto ramps, it might help to push the front end of the mower up on the ramps. This can give you more room to access the blade bolts.
If the blades have not been removed before, those bolts can be on really tight. You might need to use some kind of breaker bar on your wrench to give you more leverage.
Oct 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 inch cutting deck riding lawn mower. I can not get the mower to to ingage. The belt appears to be tight and has not follen off the pulley.
Some of the 42 inch Craftsman mowers Have a cable that goes from the blade leaver to the deck some have a linkage if it has the cable check it to see if it has broken. Find where it connects to the deck pully and pull on the cable wire not the cable cover and see if if comes out also make sure it is connected to the top of the idler pully. If it has a linkage there is a clip that holdes that linkage to the deck it most likely came off.
Aug 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
42" craftsman mower deck belt 144200 to tight on the deck
Manual lists the incorrect number for this model! i learned through many difficulties. Correct belt is a # 144959, 1/2 " by 95"
Aug 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have vibration in the deck and have checked for a warped deck, busted spindles, and bent blades
depending on the machine?? check or replace the cutter belt and also check the v pulleys for alignment
Jul 19, 2009 | Oregon Scientific Oregon Fusion Blade For...
Have to overlap about half my cutting deck to get clean cut.
A: Is the blade on right?
B: Is the belt on the pulley?
C: Is the blade tight on the spindle?
D: Does the spindle turn freely with the belt off?
I can't think of any other possibilities
Jul 03, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
42 inch Craftsman blades won't engage
model 917258862 mower was given to me. sat outside numerous years. I've managed to get it to start run and drive, but cant get blades to engage. don't know what the wires are for or do that go to some sort of pulley attached to the bottom of motor. can somebody help me pls ?
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need to put a blade belt back on my Craftsman yard tractor
If you disengage the Blades like you normally would, this will give you plenty of slack in the belt to put back on. There should be a pulley or lever that tensions the belt when it is engaged and that is what is causing it to be too tight to put back on. Hope this helps
Apr 25, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 21 hp 42 in. Deck Yard Tractor - CA Model Logo
824 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
