Question about Xtreme Sound WMS6100RW 10-Disc CD Changer
Our changer works, the remote doesn't.
Is the unit faulty, or are we missing a step?
  • k_stettner Jul 09, 2009
    Thank you...as it turns out, there was some wiring not attached properly at the vehicle-end of the new system, so the remote was/is fine. Thanks very much for your response!
    Kelly
  • 55 Answers
My remote doesn't work on the new clarion nx 501 either. The shop that installed it gave me a new one but that doesn't work either? The battery has power but the remote does nothing. Any...
the unit may be faulty from the factory most shops will try every thing other than swapping out the unit because that cost them time and money unless it is a bluetooth remote then the radio will need to be programmed to except the signal the remote is putting out hope this helps if not let me know and i will do more research on that unit good luck
Oct 10, 2011 | Clarion NX501 Car Video Player
Tuning problems
Hi, This sounds like an inshop repair. The technical term for the changer being set to 88.5 but works in 97.5 is "frequency drift" and could be rectified with the use of a calibrating instrument/frequency counter and an alignment tool assuming no component replacement required. Frequency drift can be caused by component failure, humidity, temperature etc.; The part "my car off the changer stays on" could be faulty trigger on inside the changer, faulty remote trigger on in your head/radio/controller unit. Good luck and hope this gives you a few ideas. Kind regards.
Aug 23, 2007 | Toshiba Sony CDX454RF CD Changer
Clarion VCZ625 6-Disc CD/Video CD/DVD Changer
I would say to take it back regardless of what the problem is. I would say the unit is bad. Does the remote work the other functions? if it does not then the remote could be bad, if the remote does work the other functions, I would think the unit is bad.
Jun 23, 2007 | Clarion VCZ625 6-Disc CD/Video CD/DVD...
Keypad numbers no longer work to input/change channels, but the up/down channel changer still works -- how does one fix?
Connect the remote to your computer and launch the software that came with your remote. Chose the device that your having an issue with (I'm guessing the tv) from the devices tab. Click on settings. Customize Buttons. Check at the bottom of the screen if the numbers are in the command column of not. If the are missing provide them. Press done and follow the prompts If that does not fix it. Repeat the previous steps to get back to this screen and choose reset defaults. Press done and follow the prompts
Jul 06, 2011 | Logitech SST-659 LCD Remote Control
My 6 cd changer has quit working
Try to disconnnect power to it so it will reset itself then try using a cd cleaning disc in it. If the problem still persists the unit is probably faulty. Cd changers was 90's technology it is time to step up to an MP3 source or music on a usb drive. You can store much more music.
Oct 10, 2009 | 2004 Chevrolet Silverado 2500HD
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 14, 2009 | iLO CA3000V CD Player
I have a kenwwod ddx 6027 double din head unit in my car, what cd interchangers will work with my head unit?
Any kenwood changer will work. That head unit also supports DUAL changers
Any FM Modulated changer wil also work.
Changer Control Features
  • Dual Disc Changer Control Capability (CH1/CH2 & AUX)
  • DNPS (Disc Name Presets) with Compatible CD Changers
  • DNPP (Disc Name Preset Play) by Remote
  • CD Text Ready with Compatible CD Changers
  • Direct Access with Remote
  • Random/Repeat/Scan Play (Disc/Track)
Jan 09, 2009 | Car Audio & Video
Remote malfunction - panasonic dvd stereo system
The remote control and main unit are factory-set to “REMOTE 1”
mode.
If your remote control affects other equipment during operation, you
can switch to operate in “REMOTE 2” mode.
To switch to “REMOTE 2” mode
1 While pressing and holding [AUX] on the main unit
Press and hold [2] until “REMOTE 2” appears on the
main unit display.
2 Press and hold [ENTER] and [2] for at least 2
seconds.
The main unit and remote control are now set to operate in
“REMOTE 2” mode.
To return to “REMOTE 1” mode
Do steps 1 and 2 above but use [1] instead of [2] for both steps.
(“REMOTE 1” appears on the main unit during step 1.)
The remote control cannot work with the main unit if their
modes are different.
“REMOTE 1” or “REMOTE 2” appears on the main unit display when
you operate the remote control.
If “REMOTE 1” appears (The main unit is in “REMOTE 1” mode.)
Press and hold [ENTER] and [1] on the remote control for at least
2 seconds.
If “REMOTE 2” appears (The main unit is in “REMOTE 2” mode.)
Press and hold [ENTER] and [2] on the remote control for at least
2 seconds.
Feb 21, 2008 | Audio Players & Recorders
CC, SAP PIP
1) Try hard reset = unplug TV for some time,plug-in,try again.
2) Follow guide instructions carefully = one missed step is all it
takes
3) Consult owner operator manual
4) Further help? provide Model # off back of set..................T.
Jan 02, 2008 | RCA Universal Remote Control
Pioneer cdx fm653 6 disk changer won't power up
first try to get another display, maybe it's broken (could be the cable cutted), the changer with a motor noise in the moment you plug it, tell me that its ok (95%).
Sep 12, 2007 | Pioneer CDX-FM653 6-Disc CD Changer
Xtreme Sound WMS6100RW 10-Disc CD Changer Logo
239 people viewed this question
Top Xtreme Sound Car Audio & Video Experts
Aaron Hackbarth
Level 1 Expert
Are you a Xtreme Sound Car Audio and Video Expert? Answer questions, earn points and help others
