Question about Pentair Superflo 1 1/2 Hp In Ground Pool Pump
I am trying to install a SuperFlo 1 1/2 HP 115V pump The GFI breaker trips as soon as I try to turn it on.
    Novelist:
  • 172 Answers
Pumps should not be connected to GFCI circuits they do pull a lot of juice at start time and this causes your GFCI to trip
Posted on Jun 16, 2009
I have a brand new 1 1/2 hp superflo. I wired it in and turned on the power, it hummed for a few secounds and trip the breaker. now it it wont work and just immediatly trips the breaker. Any ideas as
It sounds like the motor shaft is stuck. The back end of the motor has an end cap that comes off so you can access the end of the motor shaft. Try this with the power off; Remove the cap (center rear of the motor),Using an open ended 9/16 wrench you should be able to turn the shaft back and forth. A motor that has sat for a while will sometimes act like yours did. A nudge with the wrench usually breaks it free. Remove your wrench and turn pump on. If it still won't start the motor may be defective.
Dec 28, 2012 | Pentair Superflo 1 1/2 Hp In Ground Pool...
My brand new 1.5 hp, 230/115 v pentair runs for several minutes, gets hot and then shuts off. (not tripping the breaker) ...wiring was already in place on previous 1.5 hp, 230/115 jacuzzi brand pump for...
It is probably only getting 115V from your circuit which will cause it to overheat and trip the overload yet it will not draw high current which would trip the breaker. Can you confirm your line voltage with a meter? If it is suppoed to be a 230V line then look for a bad leg of power, again, checking each leg to ground using a meter.
John
May 28, 2011 | Pentair 15 Hp Superflo Swimming Pool Pump
Jandy Stealth 2.0 tripping GFI after heavy rain. Been a week since storm.
Very possibly a bad GFI. GFI's are cheap and worth replacing if in question. also might try hooking up directly to another source and see if it trips a breaker
Sep 13, 2010 | Jandy PHP High Head Pump 2 HP Up rated
The pump comes factory set for 230v. Power to the motor is 115v so I switched the jumper as indicated. The jumper is set on 2 posts with an arrow pointing to 230v. I moved it to 1 post and the arrow now...
CHECK YOUR BREAKER IT MIGHT BE THAT YOU ARE 230V .. IF IT IS A WIDE BREAKER ITS 230 OR IF IT IS A SLIM BREAKER ITS 115V , A VOLT METER IS YOUR BEST FRIEND.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 29, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
Pump plugged in to grounded receptacle trips the
If by "trips the breaker" you mean the GFI then you are leaking current to ground, GFI's trip when there is an imbalance between the current going to the motor on the HOT side and returning from the motor on the NEUTRAL side, if it is tripping the GFI it is likely the sign of a failing motor.
May 27, 2010 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
Switching my hayward pool pump from 230v to 115v. I was told i could just move the jumper, line up the arrows for 115 and be fine but my gfi keeps tripping out?
Setting the pump for 115V wont by itself cause the trip. There is either a ground in the circuit or the GFI is bad. You may want an electrician to test any further than this.
Jul 03, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Pump trips breaker
If the seals are damaged, water will leak into motor section and cause GFI to trip and yet the pump will seem that it is running fine if plugged into a non-GFI receptacle
May 28, 2009 | Tsurumi Pump s Submersible Trash Pump -...
Pentair Superflo 1 1/2 Hp In Ground Pool Pump Logo
439 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
