Question about MSI Wireless-G RG54G3 Router
I have reset my router... so the user name and password too... what are the user name and pasword from now on ? because i cant connect to my wirelees connection or even http://192.168.1.1
  • Carl Navarro
    Carl Navarro May 11, 2010
    Most Wireless routers have you connect to the unit via WIRED connection first to set it up. Since the msi web site is pretty thin of content, you might refer to your user's manual for instructions.
    Master:
    Sergeant:
  • 226 Answers
Should be admin password should be either blank or password
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Posted on Jul 20, 2009
I AM CONSTANTLY FINDING THAT MY USER NAME OR MY PASSWORD ARE BEING REJECTED(& AT TIMES WHEN I ENTER MY HUSBAND'S PASSWORD THAT IS ALSO REJECTED AND SO I WOULD LIKE TO GET A NEW PASWORD AND USER...
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then go to admin tab and change user and password.. Let me know if you need further assistance. Thanks for using FixYa.
Jul 06, 2011 | Computers & Internet
Tried to reset password..seemed easy enough,done.. reset router name easy, reset password easy. reset ssid easy..in fact my password was the same for everything to make things easy. Now i go downstairs...
Router paswords are chase and space senitive, Reset the router and choose a different password that not been used. then repower the router, and connect using the new password.
Oct 24, 2010 | Linksys Wireless-G WRT54G Router
How can i reset my user name & pasword ??
If you don't know the user name password of the router then try the default one. For D-link routers the default user name is admin and password is blank (means nothing, leave it empty). If this doesn't work or if you have changed it in past then to put it back to factory settings you need to reset the router.
To reset the router please try the following steps:
1. At the back of the router you will find a reset hole. 2. Press and hold down the reset button for 15-20 seconds with the help of a pen or a paper clip.
Note: Router should be turned on while doing the reset. Also, after reset you need to reconfigure the router means the internet and wireless settings.
Please revert in case of any issue. :)
Regards,
Rashish
Aug 02, 2010 | D-Link Computers & Internet
Someone is acsessin my router and useing my internet without my permission i need to change the password but i cant
Reset both password (1) pasword for access router via GUI (2)Wi fi security password WEP or WPA or WAP
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Then click on administration and change password .
Then Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Apr 17, 2010 | Belkin Computers & Internet
How can I make my router private so no one else can connect to it?
to make your router private u will have to get acces to ur router firs if u cant just reset the router from the back the log to the internet and if u cant conect type this192.168.1.101 the brand name of the router appear then enter the user name and pasword if u cant type ADMIN in the user then press enter then go to settings and chose WEP share key and type your password recomment to use a strong password ok then click save. also create a user name while u in thre ok. that will reset the router after that go to my network conection right click on ur wireless router name and go to propertis then chose the WEP share key and type the password then ok. that will set ur router privated ok. good luck
Feb 07, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I am trying to hook up a netgear wirelees router having when get to the screen with user name admin and ask for a password on back of the router that the password is password? it keeps kicking me out of...
you may be best reseting the router. It looks like the password or username are not the factory default. You will see a small reset button on the back, put a paperclip in here on hold down for 5-10 seconds until the lights flash and the router restarts. You will now be back to factory defaults - IP, username and password
Nov 25, 2009 | NetGear RangeMax WPN824 Router
Need Code
connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.Click on wireless and If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Nov 18, 2009 | Linksys Wireless-G WRT54G Router
Lost my user name and need to add new computer
Are you trying to connect to the wireless network ?
Or your new computer will be connected to router with the cable.
If it is hard wired to the router and the router is working for the other computers then you don't need to change anything on the router.
If you are trying to connect to the wireless network then you should know the wireless settings of the router.
Click Here for step by step solutions
Nov 06, 2009 | D-Link DIR-300 Wireless Router
Access to password
yas thats encryprion key it is set for your internet security.
http://192.168.1.1
try both this link it is default ip for access router.
but if this ip not works then u must have to reset your router with reset switch it in back side of your router.
thewn u can access router with this link.
then it propmts for user name and password.
then user anme: "admin"
paasword :"admin"
or
reamin pasword blank.
then u got some menu.
go to advanced security then u se encryption code.it is which u prompt when u connect your wi fi internet. ceck those pasword and type wehn u coonect yourinternet .
thats it.
Dec 29, 2008 | NetGear DG834G Router
MSI Wireless-G RG54G3 Router Logo
232 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
