Question about Rockford Fosgate Punch P325.1 Subwoofer Mono Amp - 175W Punch Series 325W @ 2 Ohms Remote Punch Ba... Car Audio Amplifier
Rockford Fosgate p 325.1 amplifier problem
Alright so my amp (RF p 325.1) has not been working since winter time and I think I have found the problem, the spot on my trunk which I used as the ground was completely rusted up along with the washer and screw and ground terminal. I cleaned up the terminal, got new screw + washer but my amp will not even power up. When I disconnected the ground terminal from the car body, the amp will power up but the thermal light stays on. Is there something wrong with the grounding wires or is my amp messed.
  • Richard Neely
    Richard Neely May 11, 2010
    well, if the amp powers on at all with the ground disconnected then there is a ground fault in the amp allowing the body of the amp to be a ground. This could be a hundred different things
  • Rockford Fos... Master
  • 637 Answers
Time to invest in a volt meter. A test light can show voltage and not actually be a 12+ volts.. A capacitor will store energy for yoy but first verify correct voltage.
A thumbs up would be greatly appreciated if this answer is helpful to you. Rockford Fosgate p 325.1 amplifier problem - rockford-fosgate-p-325-1-amplifier-peeu4x5nsxvd53n2rwetiqa4-1-0.jpeg
Posted on Dec 19, 2014
  • 32 Answers
I have the same amp basicly i think its your battery getting low and not as great of a charge i had to go and buy a 50 dollar capictor works great now
Posted on Jun 18, 2009
What is the screw size for the amp cover?
Everry amp is different in the type of screws they use end the size of them, If you have any screws around, They are a fine tread screw, Just keep on trying untill you find some that will work,
Nov 11, 2012 | Rockford Fosgate Rockford X6.a Fosgate...
Where is the power input cable on my x6 rockford fosgate amp
RF uses some pretty funky cases in order to hide the wiring.
usually a screw or 2 on the top will allow its removal and expose the wiring terminals
May 08, 2011 | Rockford Fosgate X6 Type RF 1-Channel...
How do u bridge the rockford fosgate p325.1?
Hello... sorry you are having a problem. If you are running the 325.1, that amplifier is strictly a mono-block amplifier (1 channel) so it is not possible to bridge it. There are 2 speaker connections on the amp but both positives and negatives are connected on the circuit board in the amp. Hope this helps. Good luck with your venture.
20 year car audio/video installer
Bay manager
Mar 16, 2011 | Rockford Fosgate Punch P325.1 Car Audio...
2 12 p3d212 2 ohm hooking up to a rockford fosgate p325 .1 mono amplifier can it work? and how?
Hello a_brake11,
The P325.1 is relatively small to power a pair of P3's. You'll only get 325 watts RMS at 2 ohms (162.5 watts per sub). The P3's power range is from 100-500 watts, so they will work, but don't expect them to be really loud.
For best power, your subs should be wired with the voice coils in series and then the 2 subs paralleled to the amp resulting in a 2 ohm load.
Hope this helps.
Aug 26, 2009 | Rockford Fosgate Car Audio & Video
ROCKFORD FOSGATE X7a Amp, I need compatiable remote control knob.
It will NOT work!
You need p/n AP-3212. If you are in USA then contact Rockford for this part number.
Aug 11, 2009 | Rockford Fosgate Type RF X7 Car Audio...
Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
Apr 27, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
Amp gets very hot in as little as 5-10 min.
Whats the omh load and how old is amp??? The old Rf amps always got hot that how they worked.... No ventilation????
Nov 05, 2008 | Rockford Fosgate Punch 700S Car Audio...
301x amplifier
Good luck. Rockford Fosgate does not sell or release any service parts/diagrams AT ALL. They want you to buy a new one or send it in to them to be repaired at an exhorbitant price. Also, from my experience, most RF amps are unrepaairable due to their construction design. the outputs are case soldered and cannot be removed individually. Time to upgrade.
Sep 07, 2007 | Rockford Fosgate Punch 301X Car Audio...
Car Audio & Video Logo
701 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
