Question about Boating
What is the fuel/oil ratio I should use with my 1980 9.9HP outboard motor? Also what should the spark plug gap be? Any other tips would be very helpful. Thanks.
  • Dean
    Dean May 11, 2010
    What brand motor?
  • 23 Answers
What kind ? Evinrude,mercury,ect
most 50 to1
Posted on Jun 19, 2009
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
http://www.cottagetips.com/tips/boat-motor-gas-to-oil-ratios
Apr 15, 2016 | Boating
Mariner outboard engine 4cylinder what type of spark plugs do I need
marine spark plugs are of the anti foul type so it will have 2 or 3 or no side electrodes ( earth point) and this is to prevent fouling of the plug across the gap. They are available from most car spares shops but you can get them from the outboard shop . The reach ( length of thread is very important) and you can get a range from cold plugs to hot plugs depending on the age of you motor and how much fuel or oil you use . Talk to the marine dealer for exacting advice.
Jul 31, 2013 | Boating
Yamaha 200hp 2001 manual
  1. Fuel
    • A common problem with an easy solution, Yamaha boat engine trouble could arise due to inadequate levels of fuel or engine oil. All Yamaha outboards take unleaded gasoline as a main fuel source with a pump octane rating of 86 or higher. The type of engine oil varies according to motor size and can be found in the "Specifications" section of a particular outboard's owner's manual (See Resources).
    Electrical
    • Problems with the electrical system can also prevent a Yamaha outboard's engine from working correctly. Troubleshoot the electrical system, first removing the main fuse that's located underneath the electrical panel on any electric-starting outboard. If the connection at the center of the fuse is broken, it must be replaced by a fuse of the same amperage. The battery should also be removed, cleaned and fully charged when troubleshooting the electrical system.
    Spark Plugs
    • Owners should also remove and inspect the spark plugs during the troubleshooting process. If the insulator tip of any plug is burned, that spark plug should be replaced. The number and type of spark plug depends on the specific outboard. Additionally, owners should ensure that each spark plug gap is set to the width stipulated in the owner's manual (see Resources).
Jan 20, 2013 | Motorcycles
Homelite ut 10695 spark plug gap, gas oil ratio?
Gap the plug at 0.020", and the fuel to oil ratio is 50:1. Be sure to use a modern synthetic saw oil, fresh fuel, and mix in it's own container (don't make up more than a gallon at a time unless your business is sawing). Be sure to shake the container thoroughly each time just before adding fuel mix to the tank to prevent oil starvation. Hope this helps!
Nov 04, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Fuel ratio for 1968 mercury 9.8 outboard
The fuel ratio is 50/1. Eg.50 gallons of fuel to 1 gallon of oil.
On an older motor and newer cleaner burning oils,you may bring that down to 45/1.Hope this helps
May 28, 2010 | Boating
L was driving my boat and the out board motor stopped l tried to start it but it smelt like it was flooded .l pulled the spark pulgs out cleaned them and tried to start the motro without the spark plugs to...
If i had year make and model I could give you detailed instruction. You can do a few simple test to make the troubleshooting easier. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard owner you will always need them. Troubleshooting (1) check compression. without the year make and model I'm giving you a average numbers. Look at your Clymer manual for exact numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten.Ethanol gas is proven to stay stable in fuel systems for only 30 days in 90 + degree heat. It turns to a gummy residue called varnish. It clogs up carberators and fuel injection system. I don't know year make and model so i dont know what fuel system you have. clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine cover clean it. mercury fuel injected outboards has a canister fuel filter under engine cover. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing on fuel delivery system. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
Nov 04, 2009 | Boating
Not getting gas to motor on 150 efi,engine will try to turn over
need year and make? Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard owner you will always need them. Troubleshooting (1) check compression. without the year and make I'm giving you a average numbers. Look at your Clymer manual for specific specs. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten .Ethanol gas is proven to stay stable in fuel systems for only 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine cowl clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the make so I guessing what fuel injected system. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works. without the test information I would guess the electric fuel pump. but test everything first because a mercury efi fuel pump will set you back 600.00
Sep 15, 2009 | Nitro Boating
Skipping, lack of power, 4 stroke mercruiser
has your boat been sitting more than 60 days. ethanol gas has been proven to only stay stable for 30 days in 90 degree + weather. Labor cost can be up to $100.00 per hour. CHEAP TEST- compression, spark, and fuel. TOOLS(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard owner you will always need them. TROUBLESHOOTING (1) check compression. without the year model I'm giving you a average numbers. Look at your Clymer manual for specific numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing its fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
Sep 08, 2009 | Light Outboard Motor Boat Bass Fishing...
Need fuel mix ratio & plug gap 4 husky 154 sg chainsaw
Hi there, No problem.
Recommended fuel mix ration if using Husqvarna brand premium Two-Stroke Oil is 50:1. If using another two-stroke air cooled engine oil, you should use 25:1 fuel:oil ratio.
Regading the spark plug, the recommended plug is a Champion RCJ7Y with a plug gap of 0.5mm (or 0.020 inches).
Mar 14, 2009 | Husqvarna Garden
Boating Logo
215 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
