Washing machine will not turn on
My simpson eziset605 will not turn on?, there is nothing wrong with the power point as i have tested them with other appliances, this machine is not very old but has run out of warrenty
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 17, 2010
Simpson washing machine ezi650 still wont drain after installing new pump
Why did you change the pump? Had you tested the old pump & made sure it was faulty? You need a multimeter and test the pump, the wiring for breaks and then check that power is actually getting to the pump. No power - No go!! If no power then probably a fualt on control board.
Jun 13, 2016 | Simpson Washing Machines
Simpson Enduro 801
turn the timer to a setting and pull out on the knob once
Apr 09, 2015 | Simpson Washing Machines
Simpson eziset 550 wont power up the power point definitely works and I have tested the machine on off switch
There is a fuse on the circuit board for this model. It just pops out of its holder. They go all the time.
Replace with a 4Amp Slow blow fuse.
They cost about $10 from Simpson (Electrolux), or you\'ll get a box of 6 or so from Dick Smith for a couple of bucks
May 26, 2014 | Washing Machines
I have a simpson EZI set 750 went to use this morning turned machine on nothing happened no lights on panel
Hello Barney - sorry about your washing machine and I can only offer you this link to some reviews of the machine. A couple of reviews down the page have links to Simpson representatives, who may be able to help you out with the issue. Take care. Kind regards,
Simpson EZIset 22S750L 22S750M
Mar 18, 2014 | Ariston Technologies AWD 121
Half way though washing load and the machine just stopped no lights go nothing the model is a simpson encore 555
Hi just read your posting.Good to hear from someone in Australia.I assume you are in Australia being a Bronco"s fan.Now to your machine.Did you check the power point with a small appliance such as a toaster ?If you have power to the machine and it does not power up then the fault could be either your ON/OFF switch or your computer board is faulty.Is your machine the model with all the buttons instead of a timer knob?Have you or can you borrow an electrical test meter to test the switch?Please reply with the additional information on the questions and I am sure I can help you further.
Jun 28, 2010 | Washing Machines
My simpson eziset605 came up with an error pu now it doesnt spin... i turned machine off and left it over night... tried again it washed ok but doesnt spin... the water drains out but the clothes are still...
PU is pump the drain pump probally has a hair clip or stone or summat interfearing with the **** impeller. if the pump doesnt function correct then it will not go into spin mode.
May 21, 2010 | Washing Machines
Model 805 Simpson top loader. No Power, lights, nothing at all. Have checked power point with another appliance and is ok, is there an inbuilt fuse in the machine, or could the on off switch be...
If its the model i'm thinking of, there is a fuse located on electronic board. disconnect power. acess by removing 3 screws along top rear, top panel comes off. locate fuse-if faulty, fuse should be replaced with a 4amp slow blow fuse.
Aug 08, 2009 | Washing Machines
Simpson front loader won't power up !
that wa the first thing that came to my mind i think your on the right track call a service department give them the make model number of the washer they should be able to help you locate a reset switch if it has one . good luck
Jun 22, 2009 | Washing Machines
Simpson washing machine not turning on
check outlet with multimeter for 120 volts .If voltage found check cord for 120 volts .If cord has 120 volts turn on timer jumper lid switch . did this help?
May 30, 2009 | Washing Machines
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
