Question about Kenmore Front Load Washer
Kenmore 970-C42062-00 washer drum squeaky and bangs
Have a Kenmore 970-C42062-00 front loader that started to squeak during wash cycle. It then started banging loudly during the spin cycle. I've removed the lower front panel and inspected the shocks which look fine. I've also taken off the rear panel and everything appears fine. However when I manually spin the drum at the back of the machine, it clearly squeaks and bangs at one spot during the rotation. 10yr old washer. Can someone confirm the drum needs a replace, if so, I'm wondering if the cost means it would be better to replace the entire washer instead.
    Top Expert:
  • Kenmore Master
  • 52,784 Answers
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Posted on Apr 27, 2017
  • robert Apr 27, 2017
    I would guess the spider is rusted thru on one of its arms and when you rotate the tub, the inner tub drops when the broken arm is at the top and bangs against the outer tub. The spyder can be replaced and part is under $100. But the bols on the other arms will be rusted on and hard to get off. However, take it all apart and check it out and then order new spyder. Steps: top off, control panel off, front boot spring off, front off, boot off, hub bolt off, outer tub off, separate two halves of outer tub, pull inner tub out, check spyder(three arms that hold tub to hub). Check out repairclinic.com or appliancepartspros.com for how to videos. Good luck.
    Bols - bolts. Sorry
SOURCE:
SOURCE: kenmore 44832200 banging during spin cycle
YOU MIGHT WANT TO TGRY TO PAY ATTENTION WHEN YOU LOAD THE CLOTHES IN. TRY TO LAYER THEM LIKE A CAKE AND NOT JUST TROW THEM IN. I HAD THE SAME PROBLEM
Posted on Jan 11, 2008
  • 156 Answers
SOURCE: thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Posted on Feb 25, 2008
  • 188 Answers
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Posted on Mar 10, 2009
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Posted on Apr 03, 2009
  • 89 Answers
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
Posted on May 27, 2009
LG front loader washer squeaks when drum is rotated manually
Possibly front boot seal give it a spry with sillicon spray.
Apr 27, 2014 | LG WM1814CW Front Load Washer
Kenmore 43142 front loader bangs during spin cycle any ideas on what the problem might be?
always check the load to the drum is not to heavy on one side, this could cause it to bang.
Aug 25, 2012 | Kenmore Washing Machines
Loud clunking, banging sound during the spin/drain cycle.
the make , model and year are missing but if it is a top loader unit , it indicates that the tub suspension bar motion absorbers have broken and need replacing
Sep 06, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
My kenmore washing machine (front loader, model #970-C42062-00) is not spinning the clothes dry. sometime water is left in the drum other times not. the drum is making a squeaky noise as well. what...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 22, 2011 | Washing Machines
Kenmore front loader Model Number 970-C42162-00 bearing behind drum pully very noisy
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
Mar 16, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
Nov 08, 2008 | Washing Machines
Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
Aug 31, 2008 | Maytag MAH2400A Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Kenmore Front Load Washer Logo
329 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
