Question about NetGear WG111 802.11g/b Wireless Adapter
Netgear wg111 - I am connected to wireless network
I have an IP address
I am connected to the wireless network
I cannot connect to the Internet although I can connect to the Internet via a network cable directly to the wireless router...
I ALWAYS have problems with NETGEAR wireless adapters - I SHOULD HAVE BOUGHT A LINKSYS - I knew I was making a mistake when I bought this stupid adapter.
Anyone else figured out how to make it work???
  • 87 Answers
I have seen issues with wireless USB adapters. Can you try another USB port on the computer? Also delete the adapter and let it br reinstalled. If this does not help, I would suggest returning it and getting a Linksys adapeter.
Posted on Jun 16, 2009
Netgear 111v3 usb linksys wireless router windows xp pro NG wizard shows all dots 90% + for signal strength, but cannot renew IP address so no internet
Do you have encryption enabled on your wireless router? There is a strong possibility that you have entered the wrong encryption key (network key) while connecting to the wireless network.
Apr 24, 2011 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear adaptor says its connected to the router but will not connect to the internet.the ip address its showing is not correct how can i change it on the computer?
Ive had a lot of trouble with netgear adapters, id basically buy a decent one instead, but after changing lots of settings then changing them back the only way i managed to connect was to change the router encryption to wep from wpa
Nov 30, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Hi I have installed a netgear wireless usb adapter wg111v3 onto a PC (on another PC i have a netgear DG834GT router). After installing the adapter the "signal strength" is EXCELLENT and the "status" is...
You might not be getting a correct ip from your wireless router.
first, try to power down the computer and your netgear router for about a minute or two. turn the router on first. once the lights are stable on the router, boot up your computer. if your still not able to access the internet. try this
go to start > control panel > network and internet > network connections or network and sharing center > right click on wireless network connection and go to properties > highlight "internet protocol version 4 (TCP/IPv4)" > left click on properties, the wireless network connnection properties will then be opened.
make sure that the radio buttons are on "obtain an ip address automaticaly" & "obtain DNS server address automaticaly".
Sep 17, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
After manually installing my netgear adapter,it cannot find my IP address,and hence cant connect to internet
Type cmd into the run box (xp), or command into the search bar (vista 7) and open the command prompt.
Type ipconfig
All your network details are there
Aug 12, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I've connected everything using Wireless-G USB Adapter WG111 - yet I still can't access the web or even find an icon to access the web. What am I doing wrong?
you need to connect the wireless adapter then you need to configure it i.e need to enter username,password in the page u get when u enter the IP address u got with the adapter in internet explorer
May 28, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear wg111 problem
When you say server I guess you mean a file server. So go into your server and be sure the directory you wish to see is shared, and that you have permission to see it (Be sure file sharing is on and checked). I would recommend you static the ip address on the server (And for the XBox System Static it also). I think the IP addresses for Netgear is (IP- 192.168.0.XX and subnet is 255.255.255.0 and gateway is 192.168.0.1 don't worry about DNS which is givin by you ISP). If you wish to add this info, go to command prompt and type ipconfig /all , this will give you all your network info (If you have internet now). Hope this was some help. Thanks Jimmyriggs
Jun 08, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Connection problem
you need to type 192.168.0.1 into address bar on internet explorer if this does not bring up a password prompt then you need to set your ip addresses on both computers this is done by clicking start - my network places - on left view network connections - right click on wireless for wireless and on normal lan for lan - click properties scroll down to tcp ip sttings - right click - click properties - click use the following ip address - type 192.168.0.2  - click sub mask it will auto fill then default gateway needs to be 192.168.0.1  - then click use the following dns server and type 192.168.0.1 click ok and your done for every computer you add to the network you have to change the last digit of the ip address such as 2 then 3 then 4. go back to internet explorer type 192.168.0.1 you will get the password prompt the user-name is admin and password is password
once done you need to check it is connected to the net it should say on the first page. if you need anymore info msm me moc.liamtohat1202gniksirhc
Oct 27, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear WG111 usb 2.0 adapter lossing connection
you need to set your ip addresses on your computer this is done by clicking start - my network places - on left view network connections - right click on wireless for wireless and on normal lan for lan - click properties scroll down to tcp ip sttings - right click - click properties - click use the following ip address - type 192.168.0.2  - click sub mask it will auto fill then default gateway needs to be 192.168.0.1  - then click use the following dns server and type 192.168.0.1 click ok and your done for every computer you add to the network you have to change the last digit of the ip address such as 2 then 3 then 4 this only applies to netgear routers
Oct 18, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Connection problems
If Internet sharing is set up correctly one pc will be the one that connects directly to internet, the other will connect through a gateway or other device connected to your network. Check they have'nt both got the same IP address. Is this related to last problem, did you get the wireless card working wirelessly online?
Nov 20, 2006 | NetGear : WG111 54 Mbps Wireless USB 2.0...
NetGear WG111 802.11g/b Wireless Adapter Logo
294 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
