Question about Car Audio & Video
I need a schematic for the pioneer gm-62 mini car amp. can anybody help?
    Filmmaker:
    Uploaded 5 video answers.
  • 182 Answers
Here is a link
http://akamaipix.crutchfield.com/Manuals/130/130GM6200F.PDF
Posted on Jun 29, 2009
I need wiring for pioneer gm 3000 amp?
Here is the pinout. You need to solder your own connections.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Oct 15, 2014 | Pioneer Gm-3000t Car Amplifier
I have 2 pioneer 6x9 400w, pioneer GM 6500f 760w amp and a kenwood KFC W1012 sub, how d i get the best sound from these?
pioneer gm 6500 is a 4 ch amp rated at 60w-4 way to small of an amp to run your sub. UNDER-POWERING your sub is more likely to damage spkr than over-powering. my advice,get mono-block to run sub
If you need further help, I’m available over the phone at https://www.6ya.com/expert/stephen_fa62cb6d50fe05e8
Jan 04, 2013 | Pioneer 6X9 5WAY 400W SPKR Car Speaker
W__How do i wire two pioneer GM-D9500F amps i only have two rca outputs on head unit one sub output that is being used with a D class mono amp for sub the other rca to one pioneer GM-D9500F amp but i have...
Hi, you can split the preamp RCAs with Ys available everywhere. The amp input impedance shouldn't cause much load on the head unit. Let us know if you have more questions, and thanks for using FixYa.
Jan 18, 2011 | Car Audio & Video
Ccan it be bridged with a 5 ohm subwoofer?
Hello cameron_cran,
The information I found on the amp is that is a 2-channel and is bridgeable. It is stable in bridged mode to 4 ohms. You should be able to bridge a single 4 ohm sub without damage to the amp.
Hope this helps.
Apr 22, 2009 | Pioneer GM-X322 Car Audio Amplifier
Pioneer GM-5200T problem
i dont think transistors are bad . you should check the amp controlls they may need adjusting
Jan 20, 2009 | Pioneer GM-5200T Car Audio Amplifier
Pioneer GM-232 Amp
amp%20specs%20001.jpg444bbca.jpgcc2af91.jpgthese are from the actual owners manuel-i used to have this amp also. hope these help
Dec 29, 2008 | Pioneer GM-232 Car Audio Amplifier
AMP Problems
may have blown an output transistor. Remove the wires from the speaker terminals and see if the problem still persists. If the light comes on with no load, it will need servicing by a technician.
Dec 22, 2008 | Pioneer GM-D510M Car Audio Amplifier
Sub woofers dont give clear sound on high volume
THE AMPS PERFORMCE IS DIRECTLY RELATED TO THE STATE OF THE BATTERY AND THE CONNECTION FROM THE AMP TO THE BATTERY, CONNECT THE AMP DIRECTLY TO THE BATTERY TO SEE IF THE SAME PROBLEM EXIST OUTSIDE THE CAR
Aug 28, 2008 | Pioneer GM-X924 Car Audio Amplifier
Need help
It should be better to use the Pioneer GM-7200M Amp with your subs.
For 8 ohm setup hook up this way:
Amp out+ to Sub1 +
Sub1 - to Sub 2 +
Amp out - to Sub2 -
For 2 ohm setup hook up this way:
Amp + to Sub1 +
Sub1 + to Sub2 +
Amp - to Sub1 -
Sub1 - to Sub2 -
Nov 09, 2007 | Kenwood KAC 6201 Car Audio Amplifier
Need help
u should connect at least six 12" subwoofers (preferably 1000W each) to that pioneer amp of yours. Crank it up and enjoy. Your amp shouldn't cut off now. If it does cut off, you should change the fuse on your amp to a higher ampere.
Oct 30, 2007 | Pioneer GM-7200M Car Audio Amplifier
Car Audio & Video Logo
881 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
