Question about Maytag Dryers
I have a maytag dryer, fairly new and not used that much. It is overheating and shutting off. This weekend, we took it apart and found sand in the lint trap and cleaned it all out. The vent is clean too. However, it is still shutting off as if it is not venting properly. Any ideas on what could be wrong?
  • 6,784 Answers
Check the entire exhaust system for blockages. check all components that make up the entire exhaust system. this includes the vent hose and blower assembly as well. if the exhaust system if free of obstructions, this will confirm a faulty High limit thermostat. replace this failed component asap. During the exhaust check, make sure when the unit is drying that, it is blowing at a high rate. you should feel a good forceful air flow out the vent. if its weak, you will need to clear the blockage.
Posted on Jun 15, 2009
Dryer has very load high squeal at start, lasting few minutes, then high quieter sqeak rest of load. Spins and heats ok
Belt is stretched out and slipping on drum, pulley or both. Time to replace it.
Replacement Belt Part #33002535
http://www.repairclinic.com/PartDetail/Drive-Belt/33002535/791135?ss=c7-x6d646534303030&mr=1
RDU Appliance Repair Washing Machine and Dryer Repair
Jan 02, 2015 | Maytag Neptune MDE4000 Electric Dryer
I took my dryer apart and found a staple on cushion of barrel. I did not remover circuit board and may have damaged something. When torn dryer on the timmer light shimmers and will only dry for 30 mi
sounds like u may have a motor winding going bad will usually run 20-30 minutes then shut off and if u run agin right away it will run 10-15 minutes and shut off agin. run an hour later and u will get 30 minutes or so agin? or u may have bad venting causing an over heating prob
Oct 28, 2014 | Maytag MDE2400AYW Neptune Electric Dryer
Screeching sound coming from Maytag dryer. Blower wheel, motor?
Probably bad motor if dryer is shutting down after few minutes of operation
Aug 27, 2017 | Maytag PYG2300A Gas Dryer
Help - problems with screaching/grinding sound - small smell of burning
Did you remove the filter chute? My dryer was making a heck of a racket and I found a wire inside the blower housing:
Service manual and more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 14, 2011 | Kenmore 659 Electric Dryer
It takes the dryer too long time to dry the laundry even on 80 degrees.
I took my dryer apart and found the vent shoot and exhaust needed cleaning. Also the exhaust vent pipe going out side should be cleande.
Dec 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
When turning on dryer you here a humm noise like the engine is trying to turn but it wont and shuts down. And smells like electrical burning. took apart to see if belt not belt nothing jammed.
sounds like you have a faulty motor burning smell means overheating or shorting could also be faulty wiring or control you should cal an appliance serviceman good luck let me know how you went
Nov 12, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer not starting
You must replace the hi limit thermostat and the thermal fuse.
They come as a set and must both be replaced.
They are located on the heating element.
Feb 21, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Dryer will not start again
Check list:
clear vent pipe
dryer clean of lint
blower wheel tight
drum turns freely
fuse tight against heater.
Wires not shorted on high limit mounted above heater
electric bill paid.
Feb 07, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
98 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
