Question about DonJoy IceMan Model 1100 Classic System
Water won't go into pad How do I fix? Where is the filter cap (besides "under the pump assembly). I don't even know where the pump assembly is!!
  • Patricia Cross Sep 05, 2017
    Its under the filter pump thats in the donjoy..just unscrew the 2 screws holding in on and push it in a little whereas you can see the bottom of the pump..you'll see the filter,if its clogged or dirty just wipe it off,worked for me..then screw everything back and make sure you have the wires put back where they came from
OK,
water goes in but the return doesn't work. I cleaned the filter cap, the pad is not plugged, now what?
Posted on May 10, 2018
  • Scott Turner
    Scott Turner Aug 04, 2018
    Al and anyone else with this issue. My issue was the same as Al's, in that the inflow to the wrap was working, but it was filling up and the return flow was not working. This caused pressure to build up in the wrap and it to not cool down.
    I checked the filter cap as in a previous solution but it was fine. I then disassembled to temperature control housing that's in the middle of the tube section, there are four screws and then it opens on one edge with a hinge on the other edge. The temperature control dial rests inside of a round plastic inset, and you can pull the dial out. In my case, the inset was filled with sludge. The return appears to come in via one pinhole and go back out through two different pinholes, so any kind of material in there will clog it. In our case the unit had sat unused for over a year so there was some weird slime in it.
    Once I rinsed that area and reassembled the unit it worked perfectly. I can't tell you exactly how to reassemble it, but it really only fits together one way, but when you first open it you may want to take some photos before doing anything else in order to be able to orient everything back the way it was originally.
Kenmore 90 series washer won't drain and go to spin cycle
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
Apr 02, 2013 | Kenmore 15864/15862 Top Load Washer
Can't get blue bypass cap off to put water filter
are you sure what you're turning is a bypass cap? KitchenAids don't usually have bypass caps.
If it is a bypass cap though, make sure you're turning to the left. It could be tougher because it's under pressure, so turn the water off going to the fridge and run the water out the dispenser if there is any.
Mar 09, 2012 | KitchenAid Refrigerators
Dishwasher won't drain when cycle is complete. Not even when press on the Cancel/Drain button. Engine starts working (at least sounds like something is going on) but not water goes out to the sink...
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Dishwashers
Kenmore washer model111, will fill, agitate but won't drain? i am assuming that it is the water pump, but why would it fill up???
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Not sure about your question "Why would it fill up" Why wouldn't it fill up? Like walking through an entry barrier and then discovering the exit is locked, at the time you go in, you don't know you can
Jul 07, 2011 | Kenmore Washing Machines
It wont spin or drain. washes fine. checked the lid switch but cant tell if thats the problem or not
This is probably simply a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the debris trap/filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the debris trap/filter. Depending on the model (not familiar with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 04, 2011 | Kenmore 24032\24036 Top Load Washer
Have replaced the starter solenoid, spark plugs, plug wires, fuel filter, air filter, water pump and battery all within the last two months. When the truck gets hot it will not crank. Has electrical power,...
If you haven't already done so, replace the distributor cap and rotor. There is most likely corrosion inside the cap that is causing a crossfire condition.
This is a common problem on that engine.
Don't know why being hot would aggravate it, but start with the cap.
Jun 14, 2011 | 1990 Chevrolet Suburban
Just want to know where the oil filter is at for 2002 alero 2.2
For the 2.2 L, working from top the engine (yep - I crawled around under looking), on the oil filler cap side, look down beside the power steering pump and you'll see a black plastic cap with a fairly large hex head (1 and 1/4") for removal.The filter is a paper element unit that comes up as an assembly when you remove the back cap. I removed the air filter duct and sensor wire for ease of access. But you use a bar extension (like 10 ") connect to an adjustable wrench to loosen gently and up it all came without the usual mess and disassembly of air filter duct and sensor wire. Just different. To close, the torque is 25 Nn.
Jun 02, 2010 | 2002 Oldsmobile Alero
I wonder why there is still water left inside my front load after draining. It used to be totally drained. But now as you turn the drum by hand you can hear water inside of it. My samsung is Wd 6102
Hi the likely problem is a blocked drain filter or a bad pump. Their will either be a small door at the front right or a removable panel under the door. gain access to the pump and beside the pump there will be what looks like a gas cap on a car. unscrew it and clean the filter. If you don't see too much that would block the filter then your problem is the pump replace it. If you have any other questions please feel free to comment. Mike
Dec 06, 2009 | Samsung Washing Machines
Overheating
Make sure you don't have a bad head-gasket. Check for excessive pressure in radiator or hoses. Check under oil cap for creamy/milk like residue or actual antifreeze in oil or the opposite oil in antifreeze. Let me know what you find. Good Luck
Dec 12, 2008 | 1995 Chevrolet Monte Carlo
DonJoy IceMan Model 1100 Classic System Logo
2,142 people viewed this question
Top DonJoy Event Planning & Celebration Experts
JonSnell Electronic
JonSnell Electronic
Andrew Taylor
Andrew Taylor
Geoff Tuke
Geoff Tuke
Level 1 Expert
Are you a DonJoy Event Planning and Celebration Expert? Answer questions, earn points and help others
