Question about Maytag Neptune FAV6800AW Top Load Washer
WASHER READING CODE DC - Maytag Neptune FAV6800AW Top Load Washer
  • 335 Answers
Hello jdebruler44 ,
If it’s a FAV6800AW then you probably have an issue with a clutch malfunction, dry or rusted up oneway Roller Clutch Bearings. Take a look at this post , I have helped a lot of folks thru the issue. That link will also steer you to the Service Manual on this sight. If you or someone you know has basic mechanical skills sets you can perform a roller clutch bearing clean up or clutch assembly replacement if necessary.
I would estimate that a repair service that knows how to troubleshoot dc/UC errors would charge $300+ for a fix. I’m an owner like you not a repair person and anyone that wants to get involved can do this. I also recommend a $50 dollar clutch which I have put into my Series 16 FAV6800AWW (first two digits of your S/N is your series number the S/N is located on the back right side of the console) and it works fine, I can’t tell any mechanical difference from it and my original clutch. If you can get away with a roller clutch bearing clean up you could back in service today.
This machine is designed to go into spin cycle with a fair amount of water in the tub. I feel the design team did that to help dampen out tub oscillations when entering spin cycle…. Anyway you can pump out excess water when you fail in spin cycle with dc/UC unbalance errors with this process from the SM……
Close the lid and enter the Service Mode by pressing and holding simultaneously the Enviro Plus and Spin Only keys for three seconds or the display reads “00” Next press the Delicates key this will lock the lid. Now press the Presoak key the drain pump will turn on . Stop the test as the SM states with the off button or hit the Presoak key.
The TDS test is in the SM I’ve typed it out if you want to give a quick check. I’m sure you will pass and find the oneway roller clutch berings are dry/rusted and causing the dc unbalance condition.
3.0 Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
3a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
3b. Press the Super Wash key display reads “in”…something like that.
3c. Press Delicates the Display will show “UC” (Unbalance Closed).
3d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
3e. Press Hand Wash.
3f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). If you get these results your Tub Displacement sensor should be OK and I believe it’s not the component failure producing dc/UC errors in spin cycle. I would remove the clutch for inspection and re-lube. There is a more technical troubleshooting method to check Tub Displacement Sensor in the Troubleshooting guide and Service manual.
Shout out if you have questions or need help. Rich
Posted on Jun 15, 2009
What does error code dc mean?
DC error code means: "Unbalanced load". It can occur if the washer:
1. is overloaded (too many clothes inserted),
2. can't balance the load within a few balance cycles,
3. has a damaged balance sensor,
4. isn't regulated properly (vibrates abnormally).
IMHO you just overloaded the washer :)
Jan 19, 2015 | Samsung Washing Machines
What does samsung washer error code dc mean?
Product: Home Appliances > Washers & Dryers > Washers > WF218ANW
dc = Unbalanced load prevented the washer from spinning.
What Do the Information Codes Mean on the Front Load Washing Machine
Jan 03, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
Samsung VRT error code dc
dc means clog in the filter. look to the lower left front of the washer for the filter door. Take off the door and pull out the short hose. Empty the water from the hose, this could be lots of water be prepared. Then pull out the filter on the right by twisting counter clockwise and rinse the filter. Put it back together and the error should go away
Oct 20, 2012 | Samsung 3.5 cu. ft. High Efficiency VRT...
Washer has a DC error code what does that mean?
dc--Unbalanced load preventing washer from spinning
Jan 05, 2011 | Samsung WF328AA Front Load Washer
Not finishing the spin cycle and have a code that says dc
here is a website you can view a bulletin on the error code DC pertaining to your washer
http://fixitnow.com/wp/2009/06/11/e3-and-dc-error-codes-in-maytag-mah6700-8700-and-9700-washing-machines/
May 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune FAV6800AW Top Load Washer: My Neptune washer is showing error code dc..Once i...
See this post Clutch Fix if you want to DIY I will help you.
Post back if you have questions……..Rich
May 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a DC code that comes up when the washer is in the spin cycle.
See this post for dC/uC error code in Spin Cycle for the FAV6800A or FAV9800A.
http://www.fixya.com/support/t2070219-model_fav6800aww_will_not_pump_water_out
Post back if you have questions or concerns.....Rich
Mar 31, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Samsung washer wf218anb/xaa has code dc and wont spin clothes they are still wet
The DC error code is an unbalanced laundry error. Try putting less clothes in and if that doesn't fix the problem, then replace the hall sensor( located behind the drum, underneath the rotor).
Mar 03, 2010 | Samsung WF337AA Front Load Washer
My radio display is reading E DC and the radio
u need the code from the dealer or look up the books that came with the car firest u might find it
Oct 07, 2009 | 2007 Mitsubishi Eclipse Spyder GT...
Maytag Neptune FAV6800AW Top Load Washer Logo
186 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
