Question about EliteGroup K7VTA3 V5.0 Motherboard
My computer can not boot -BIOS ROM checksum error
Hi!
I have the problem wit boot of my computer. May be you can help me!System: Athlon XP 2200, Socket A, motherboard: ESC, K7VTA3 V5.0, VIA KT333/VT8235
Computer can not boot, on the screen is following message:
Award BootBlock BIOS v1.0
Detecting floppy drive A media...
It is no possible to overwrite BIOS using awdflash exe (ver. from 8.22 to 8.87). The older versions of awdflash are showing error message "System was not new BIOS vesion! Please update ROM BIOS first", the newer versions are detecting Flash type -WINBOND 49F002U/5V and the programm hungs up after warning message "Don't Turn Off Power Or Reset System!".
I have changed CMOS battery, cleared the content of the CMOS memory using jumper on the motherboard - no changes.
I can boot DOS using floppy drive, but I can not rename or copy any file on the floppy disk.
How to resolve this problem? Is it possible, that flash memory is not damaged, or I have to change flash?
    Problem Solver:
  • 16 Answers
To be honest if you have tried to re-flash your bios, and it did not work you still either have hte wrong version or the disc drive your using to flash it from is faulty. try another floppy drive/disc and try again. if that dont work. to be honest it's not worth getting it repaired just go out and spend £30-40 on a new mobo. sorry i'm not more helpfull but i dont believe it's worth spending that much time and effort on an old system like that with this kind of problem. good luck to you. let me know how you get on ok.
Posted on Jun 15, 2009
Bios rom checksum error, boot block bios vI.0
Error BIOS ROM CHECKSUM - SYSTEM HALTED.
Cause Bad Hardware
Solution Unfortunately this indicates that your computer BIOS ROM chip or Motherboard is physically bad. It is recommended that you contact your computer manufacturer or take the computer into local service center for repair.
If you wish to repair this issue yourself the motherbard will need to be replaced.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Apr 14, 2012 | ASUS A8N-E Motherboard
Compaq Presario 2500 stopped loading windows XP with a prompt STOP: c0000221 {bad Image Checksum} The image COMCTL32.dll is possibly corrupt. The header checksum does not match the computed checksum.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen) you should see Adjust date and time tab
hope this helps you
Sep 09, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
Can you please help me how to fix the BIOS ROM CHECKSUM ERROR. TO MY MOTHERBOARD (TRINITY 400 S1854 AGPX4-PCI-ISA) i reformat the windows NT version 4, and after i restart, the message come bios rom...
turn the computer off
now turn on and hold down the delete key until the bios screen appears
in the boot tab select first boot as the cd disk, install the cd for win nt in that drive
close down the cd and then restart and it will boot from the cd
BY reformatting the hard drive win nt you have wiped the win nt operating system from the hard drive
Feb 17, 2018 | Tyan Trinity 400 S1854 Motherboard
sounds like your bios is corrupted, try going to the motherboard site and update your bios software. It could also be bad memory modules.
Nov 01, 2009 | HP Computers & Internet
Bios ROM checksum error (Compaq SR5237CL with M2N68-LA MB)
A BIOS checksum error can be caused by a nearly flat BIOS battery.
I would replace the BIOS battery first before attempting to upgrading the BIOS.
Some motherboard BIOS firmware is upgraded by running a program that has been copy to a DOS boot disk or the upgrage maybe done from within the BIOS setup. These firmware upgrage and instructions are on the motherboard WEB site, in your case the Compaq/HP WEB site. Make sure you select the upgrade for your model motherboard.
NOTE it is possible that if you make a mistake you could ruin your motherboard, if you are not sure seek help from a computer savy friend.
Use this link :-
http://h18000.www1.hp.com/cpq-country/cpq_support.html
Sep 17, 2009 | HP Computers & Internet
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
Checksum error
Hi Oliver, the most common error related to the message,
(Bios Rom Checksum Error). Someone has left a floppy disk in the floppy drive. Once the floppy disk has been removed press the reset button on the PC, your windows will start normally. Next place to look is in your bios.
Open your manual to page 27.
Enter your bios & go to the title Advanced BIOS Features. Check First, Second & Third boot devices they should be as follows. Floppy disk drive, CD-ROM drive & primary hard disk drive. If both of the above are ok than try clearing the cmos/bios by resetting the cmos jumper (JP1) location on page 5. Descriptions of page five on page 6. CMOS settings on page 9.
When your system restarts re-enter your cmos & reset up your bios settings. Lastly if none of the above has fixed the error message, than remove the cmos battery & check its voltage. It should maintain 3volts. If yours' is lower than 3volts replace the cmos battery. There is one other possible fix. It’s an option not given lightly. Flashing a cmos/bios is not recommended unless all other options have failed.
Bios link for the EliteGroup P4VMM2 V8.1
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=436&DetailName=Bios&DetailDesc=P4VMM2%20%20(V8.1)&CategoryID=1&MenuID=82&LanID=0
Main web site;
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=52&LanID=0
Good luck Oliver!
Mike
Aug 23, 2008 | EliteGroup P4VMM2 V8.1 Motherboard
Biostar P4M900-M7 SE BIOS ROM Checksum Error
The bios upgrade procedure stopped at half , leaving the bios corrupted. The computer now cannot do a regular boot procedure, this is the reason why it cannot recognise some device. If you are still able to boot from floppy, you can restart bios upgrade procedure from floppy. Just download floppy version upgrade and re do setup. Even if you do not find latest bios version, just download a floppy upgrade that is working, so that you can restart your machine regularly , and then do the update to latest version.
If you are not able to complete the bios setup, the only way to fix your motherboard will be flashing the CMOS chipset with a chip programmer device that will reinstall bios straight into cmos chipset.
You can have this done at the service point, in this case consider also replacing your motherboard.
Regards
Apr 03, 2008 | Biostar P4M890-M7 Motherboard
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
EliteGroup K7VTA3 V5.0 Motherboard Logo
717 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
