Question about NEC MT1075 Multimedia Projector
My projector nec mt 1075 asks me to clean filter. How do i do it?
As soon as i switch on my projector a message appears on screen to clean fiter, i tried earlier but didnt work can any one help me
All you need to do is use a vacuum hose to vacuum the dust that collects on the filter. The filter cover is on the side of the projector with horizontal slits. You can vacuum through the slits, or remove the cover and carefully vacuum the filter itself. Then go into the menu and reset the filter timer. Find this reset button in the "setup" menu item. Then your clean filter reminder won't show until another 100 hours of usage.
Posted on Nov 12, 2009
How can I fix the iris problem on an NEC PA500 projector?
NEC NP PA550W User Manual Troubleshooting Indicator Messages ..i know yours is a pa500 but this is all i could find on the internet i just thought it might help you find out how to sort your 500.
it gives faults and what could be wrong.
Sep 28, 2016 | NEC Computers & Internet
Picked up a nec MT1030+ on a gov auction with no remote. Lamp hours have exceeded the 2100 and projector is shut down. With out remote how do I get it back on? I guess I should be specific here. I have...
First make sure that you have install the bulb correctly. There are number of issues that can cause this problem.
1.Check for dirty air filter and clean if need. Make sure the air filter cover is on all the way. Make sure the cover to the lamp is on all the way, and that the screws are tight.
2. First turn off and unplug the projector. Then remove and reinstall the lamp, with cover firmly fixed. Make sure are cover are properly fastened. You should get the projector to turn on by pushing the power button on the unit. Wait for an hour if you keep having this problem, then plug the unit back in.
3. Then reset the lamp timer. Sorry I don't how to reset the timer. I home manufactured an LED lamp for mine, so I don't have to worry about replacing lamps anymore.
You might want to ask someone here on the fixya forums how to do a hard reset of the timer and unit.
You might find projector central.com helpful, where the owers manual for the MT 1030 is available in PDF version.
http://www.projectorcentral.com/NEC-MultiSync_MT1030+.htm
May 13, 2010 | NEC MultiSync MT1030 Multimedia Projector
I cleaned the filter, but keep getting "Clean the Filter" Message. Is there something else I need to do?
Hello :
In some projectors after cleaning the filter you need to reset the projector .
Please check this video .
Please don't forget to rate !
Apr 12, 2010 | NEC VT670 Multimedia Projector
Clean Filter - NEC VT700 projector
Need to go into the menu and find the option to reset. Choose the "reset filter hours" option.---Rick
Sep 04, 2009 | NEC VT700 Projector
Lamp and user's manual for a NEC Multisynch MT Projector
The manual can be downloaded here: http://safemanuals.com/user-guide-instructions-owner-manual/NEC/MT600
The part number for the replacement lamp is MTLAMP600/800 and it may be ordered from www.partstore.com
Mar 02, 2009 | NEC (SPPL1063) Projector Lamp for MT600,...
Resetting Lamp Hours Procedure On Nec-MT-1075
Hi - You can download the manual by clicking the link underlined in blue below:
Nec-MT-1075
See page E-55:
As in the note replacing the lamp automatically clears the lamp hours.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 05, 2008 | NEC MT1075 Multimedia Projector
Shutting off Filter Cleaning Message
you need to turn OFF the message function under the expert tab on the "on screen menu"
In the state of Power ON, press each key in the order of: HELP, UP, LEFT, HELP
Press the Menu Key to display the menu and confirm that Expert is displayed below the menu.
Once you go into Expert mode, go to the Expert2 tab in the onsreen menu and set the message to OFF.
Hope that helps.
Aug 19, 2008 | Office Equipment & Supplies
"clean filter" prompt
Hi there
Not at all. This promp automatically appears after a certain amount of hours.
To get this message away , all you have to do is go into the Menu and reset the Filter Timer.
Apr 14, 2008 | NEC VT676 Multimedia Projector
NEC Model VT48 - need to clean filter
This is a solution for the VT 480 by NEC for filter clean. on the left side there are two slots that have dust filters which can slide vertically to reveal micro screens that one can blow, tap vigorously, or vacuum to remove any dust build up. I hope this helps you with your unit.
Tech-no
Nov 11, 2007 | NEC MultiSync VT48 Multimedia Projector
Changing the lamp
There is a small cover plate, about 3"X6", that 'just' snaps off. You might have to use a small screw driver to pry it open. The bulb can then be pulled out. Align the new bulb and press it down into the socket. Be careful not to touch the bulb with your hands; use gloves or a lint free cloth.
Aug 13, 2007 | NEC MT1075 Multimedia Projector
NEC MT1075 Multimedia Projector Logo
496 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
