Question about Refrigerators
GE GSS22WGPJ CC Side by Side
Our ice maker is working fine and making cubes, but our water dispenser is not working. I have checked that there is water to the fridge, I have changed the filter, but for some reason the change light never came on so it was 2 months late and there was some rust stuff dripping down the back if that matters, it makes a good pressure noise when it is removed, the light was reset, I have turned the fridge temp up and waited and then down and waited, I have held the water dispenser on for over two minutes. Please help!!
  • Refrigerators Master
  • 4,625 Answers
Re: GE GSS22WGPJ CC Side by Side
You should have two water solenoids in back of fridge and near bottom where the water supply comes in. It is possible that one of the solenoids is stuck (the one supplying door)closed or clogged with trash. Also possible the selector switch on door is not making a good connection when selecting water. When someone is trying to get water touch a metallic object to solenoid in back to see if the magnetic field pulls the iron from a safety pen or screwdriver. There should be a click when the water valve opens if not stuck, dirty or bad solenoid. Also try switching water lines around (ice water to water and back) Let me know if this helps, Sea Breeze
Posted on Oct 31, 2007
0 characters
3 Points
Ice maker not working on GE side by side
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
GE GSS25LGM Ice maker
one of the valves could be open circuit. ice build up where the pipe enters the cabinet or sadly if not that then the complete ice maker. hope this helps
Feb 11, 2008 | GE GSS25LGM Side by Side Refrigerator
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Dec 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
978 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
