Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Don't stop in the rigth position
I have a 1/2 hp garage door opener model (j391535j37) that when it stop
makes a loud noise because don't stop in the rigth position .. i can see inside it two sticks that oprates with a flat screwdiver to fix it ... where can i find the technical manual of it to fix it
    President:
  • 3,197 Answers
I think the two sticks you are talking about are the up and down limit controls. If you look at the cover you will see an arrow over each hole. If you turn the control in the direction of the arrow the door will travel further. The opposite is true if you turn the control against the arrow. It should be easy to adjust the door now.
Posted on Jun 15, 2009
Loud, grinding noise from garage door opener
Remove the cover from the motor housing and check the drive gear.
Jul 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
My daughter's garage door opener (Chamgerlain 1/2 hp screw drive)makes a loud snapping noise when it starts to open (closing works OK), door shakes then opens rest of the way properly. Noise is loud...
what you have is,, the part that connects the door to the shaft is beginning to strip, this is pretty common in the screw type doors , its the part with the door release lever on it, you can find these at any home depot or Lowes
Aug 18, 2011 | Vacuums
I have a chamberlain whisper drive garage door opener. When I open the door and it reaches the top it starts making a loud noise. It's like the motor is still trying to pull the door up but it can't...
SOUNDS LIKE THE UP LIMIT IS EITHER OUT OF ADJUSTMENT OR NOT WORKING.
TURN IT ABOUT THREE TURNS COUNTER CLOCKWISE. THIS SHOULD BE ENOUGH TO MAKE IT NOT OPEN ALL THE WAY. THEN ADJUST IT 1/2 TURN AT A TIME THE OTHER WAY UNTIL IT GETS CLOSE THEN SMALLER ADJUSTMENTS TILL YOU ARE HAPPY WITH WHERE IT STOPS.
HOPE THIS HELPS
Nov 04, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Liftmaster 1/3hp garage door opener
When i try opening the garage door from the wall button the door only opens 3 inches or so, then stop but makes several loud clicking noises. I've played around with the travel limits as well as the open force switch but the same thing keeps happening. Any suggestions?
Jun 21, 2010 | liftmaster Chamberlain Garage Door Opener...
Access Master 1/3 HP garage door does not close, blinks
Most likely your door sensors are out of alignment. Make sure they are pointed directly at one another.
Apr 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Older model 1/3 hp craftsman goes up not down with remote
Your door sensors are either bad or need simply to be aligned. They must be pointed at one another to work properly. Each of them has a small light that will be lit when they are pointed correctly.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
118 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
