Question about Bosch 24 in. SHU53 Built-in Dishwasher
Bosch smu2046uc doesn't drain completely (water sits in the very bottom of the drain) and mildew builds up inside the dishwasher quickly--makes dishes dirty. How do I solve?
  • 6,784 Answers
Check the following parts for their operational value. replace any failed part.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Jun 15, 2009
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
Dishwasher not completely draining
Make sure the drain screen is not clogged at the bottom of the dishwasher or that you water drianline is not pinched or clogged behund the dish washer. if you are confidant in doing this you may be able to troubleshoot it. It possibly could be a water pump issue too.
May 16, 2010 | Dishwashers
Major calcium build up. what will cut through it?
Hello there and happy new year as well
How to Clean a Dishwasher Dishwasher manufactures tell us that the inside of dishwashers should not need cleaning---after all, it is constantly being cleaned as you wash your dishes. You know better. There is a slimy feeling on the walls or door gasket of your dishwasher---or there is something black "growing" at the bottom of the dishwasher by the drain---or it doesn't smell very nice---or there is a white coating on the heating element (even manufacturers acknowledge this one as common). What do you do? The first thing is to try to prevent as much of this as possible: 1) Be sure your water is coming into the dishwasher at a minimum of 120°; 140° is even better. If your water heater is a long ways from your dishwasher, before you turn on the dishwasher you may need to run the water into the sink until the required temperature is reached. If the water is not hot enough, the detergent (even gel detergents) won't completely dissolve, and you get the slimy feeling on the walls and gasket of your dishwasher. You also foster the growth of bacteria and mold or mildew in your dishwasher. 2) Be sure you are using the right kind of dishwashing detergent. Manufacturers usually recommend using certain brands. That is because they have tested those brands in their machines, so they know they will work. Others may do fine, but they haven't been tested. 3) Be sure you are using the right amount of dishwashing detergent. Ironically using either too much or too little can cause similar problems. The amount you need depends on the hardness of your water, not the amount of food left on your dishes. Okay, you've got all that under control. Now, how do you clean the dishwasher? Problem 1: Slimy feeling on walls and gasket ---Use good old soap and water (yes, soap to clean soap residue!) and clean away. Be sure to rinse well. If you don't you may have suds coming out from around the door the next time you use the dishwasher! Problem 2: Something black "growing" by the grates at the bottom of the dishwasher ---You have a mold problem. This is also what causes a bad odor to "grow" in the dishwasher. The mold is caused by food particles not getting fully pushed through the drain hose when the dishwasher drains. The drain hose is corrugated, and bits of food particles can sometimes collect on the ridges and in the valleys of the corrugation. Given the right circumstances, this can cause a gradual buildup inside the hose, just like cholesterol in our arteries. The presence of moisture and lack of sunlight in the hose allows mold to grow on these food particles. You will want to remove the grates at the bottom or back of your dishwasher (usually removing just a couple of screws will do it) and clean with bleach water (a cup of bleach in a gallon of water) as far down as you can reach. After you have done that, replace the grate, put the rest of the bleach water in the bottom of the dishwasher and run a regular cycle (no dishes, please!). Why not just put the bleach water in and run the cycle? Because that will kill the mold, but will not remove its build-up. You want to remove the build-up first, as far as you can reach---it's easier to remove when it's live. Then kill what's left in the drain. If your problem was serious enough, you may want to replace your drain hose, too. Problem 3: Brown spots on the door gasket ---This is mildew. Mildew can also cause a stale odor in the dishwasher. Use the bleach water recipe to clean the gasket, and then run the rest of the bleach water through a cycle, just as for Problem 2. Problem 4: White coating on the heating element ---This is a build up of minerals, mostly from your water. You may have heard people recommend putting TANG® Drink Mix in the dishwasher and running it through a cycle. This does work to help remove the calcium from the heating element. That is because there is citric acid in TANG®. However, the sugar in it may contribute to other problems you have been trying to clear up. So why not just use plain citric acid---what an idea! You can often buy the crystals in a drug store or in the canning section of the grocery store---it is used for making jelly with a fruit that does not have enough acid in it to allow it to jell. Fill the dispenser cup with the crystals (3--4 ounces), and run a cycle. If the build-up is unusually thick, you may need to do this a second time. So, now you have a clean dishwasher! How do you keep it that way? After all, who wants to have to go through all of those steps every so often? The best thing to do is occasionally run it empty with a cup of white vinegar and a cup of baking soda. How often depends on your water quality, how often you use your dishwasher, how much food you leave on your plates, etc.o there and happy new year as well
Jan 01, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
DISHWASHER DRAINING POORLY
Check to see if you have a plugged, kinked, drain hose or screen. Do you know how to disassemble the bottom of the diswasher to get access to the drain hose? Also, is the dishwasher drain and hose properly vented?
Aug 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
New Bosch water not draining
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch dishwasher will not drain - causing moldy odor
Hello Mimhoff it depends on how much water is down there. The sump area always has a little water in it to prevent the circulation pump seals from sticking. Usually around 1 to 2 inches. If there is more than that, check the slots at the bottom of the sump on the left side for being clogged and check the end of the drain hose to make sure it is clear. If you are getting a moldy/odor from the dishwasher, try running Dishwasher Magic or Tang thru the dishwasher. This will remove any build up of food or detergent from the dishwasher. If you are running the dishwasher every few days and just scraping your dishes, then either leave the door ajar or run the rinse & hold cycle to help keep the odor down. Bosch doesn't reccommend running bleach thru the dishwasher as this can cause damage to the rubber seals. However 2 tablespoons of bleach once a year won't hurt.
Feb 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch 24 in. SHU53 Built-in Dishwasher Logo
427 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
