Question about Brother HL-2040 Laser Printer
Same problem - Paper LED light is flashing, but no paper jam
Have tried all the troubleshooting in earlier threads
When I restart the printer it makes the beginnings of the noise for checking the paper but it stops fairly abruptly
There were 2 missings screws that held the rear of the paper tray together that have been reinstated
Boss says he hasn't changed anything
Brother HL-2040 not printing at all, even after making all the funny noises, have checked everything and tried to re install, but it does not even print a test page after I just re plugged it and connected it
Posted on Jun 17, 2009
  • 133 Answers
Try on pressing start buttom for 1 min to reset the machine.
it should be working fine after that.
Posted on Jun 16, 2009
Canon iP1800-alternating flashing lights. 1 long green, 3 short orange. How do i troubleshoot this? It is a ''Service Error 6000''. Which translates to a paper jam, however, there is no paper in the...
1- Please open the cover and inspect the inside of the printer carefully. There might be a little piece of paper or a tiny object jammed in there and is causing this error message. Also get some canned air and clean the inside of the printer. 2- Restart the printer.
Feb 12, 2010 | Canon PIXMA iP1800 Printer
Paper light keeps flashing. no paper jam and there is paper in printer. what else could it be?
Here are the led codes. Have you tried pressing the go button, and holding it down for a few seconds to reset the memory. Then press it again and see if the paper light is out.
Check also to make sure the paper setting in tray 1 is not set to undefined, but specifies your paper size. (Printer properties>Tray settings)
Then pull the tray all the way out, and look above where the paper sits for a little lever that hangs down to sense the paper. Make sure it's moving freely and not broken. Also check that there's no paper jammed in the back of the printer somewhere....
Jul 30, 2009 | Brother HL-2040 Laser Printer
Paper led light wont stop flashing
Pull the tray out and make sure the back guide is pushed against the paper. The back guide tends to move easily on these models
Jul 15, 2009 | Brother HL-2040 Laser Printer
Brother HL-2070N red "paper" light flashes after a paper jam
http://welcome.solutions.brother.com
Try this
[LED Indication]
The Paper LED is flashing.
Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document.
Clean drum unit:
The corona wire needs to be cleaned.
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Jan 23, 2009 | Brother HL-2070N Laser Printer
Red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
iskandarsugandi@yahoo.com
Jan 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Brother printer problem
Manual Feed Command.
1. Press the Job Cancel button to cancel the print job. Delete the print
job in the print queue on the computer. You can quickly access the print queue by double clicking the Printer icon in the task
tray or dock.
2. Turn the printer power switch OFF on the right side of the printer.
Check that the front cover is closed.
3. Turn the printer power switch ON while holding down the GO button
until the Toner, Drum, and Paper LEDs are lit.
4. Release the GO button. All LEDs will be off.
5. Press the GO button 8 times. The green Status LED will flash briefly
while the printer is reset. After the printer is reset the Status LED
will be lit green.
6. Print the Print Settings by pressing the GO button three times. If
the Print Settings pages do not print and the Paper LED is on again skip
to the next section - No Paper in the Paper Cassette.
If the Print Settings pages print, the problem is isolated to printing
from your computer. The Paper Source of the Brother printer driver or
program you are printing from may be set to MP Tray or Manual, instead
of Auto Select, Tray 1, or Tray 2 (if the optional paper tray is
installed). To check the Paper Source setting of most programs, click
File and Page Setup or Page Layout. You may need to click the Paper
Source tab or Paper tab depending on your software application. Verify
that in the Paper Source section does not list MP Tray or Manual. Choose
Auto Select, or another relevant source such as Tray 1. Click OK. Try printing the document again.
No paper in the paper cassette.
1. Pull the paper tray completely out of the printer.
2. Insert the letter or legal size paper into the paper tray with the
top edge of the paper first and the print side down. Make sure that the
paper is flat in the tray and below the maximum paper mark. If using a
paper size other than letter or legal, the paper should be loaded in the
MP Tray. The MP Tray can print on paper from 2.75 in. by 4.57 in. up to8.5 in. by 16 in.
3. While pressing the blue paper-guide release lever, slide the paper
guides to fit the paper size. Make sure that the guides are firmly in
the slots. For legal size paper, press the lever located at the back of
the tray and pull out of the back of the open tray.
4. ReinstalI the paper cassette back into the printer. Press the GO
button. If the alarm clears, no further troubleshooting is needed. If
the alarm continues, follow the steps below.
Paper Jam at Paper Pick-up.
1. Turn the printer power switch OFF on the right side of the printer.
2. Remove the paper cassette from the printer.
3. Elevate the front of the printer slightly to locate the jammed
paper.
4. Gently remove the jammed paper.
5. ReinstalI the paper cassette back into the printer.
6. Turn the printer power switch ON. If the alarm clears, no further
Oct 02, 2008 | Brother HL-2040 Laser Printer
Flashing red lights and letter E on my hp printer
basically for this printer I have found that just restarting your computer will solve almost anything. make sure there is no paper left jammed in the printer and restart. sometimes you have to delete the print job in the printer que. there should be a printer icon down my your clock, right click, open active printers, and delete your file. restart your computer and try again
Sep 18, 2008 | HP DeskJet F380 All-In-One Printer
My brother laser printer HL-5050's paper light is flashing, which usually indicates a paper jam. i've checked 5 times and there is no paper jam. have shut off printer and restarted 3x. when i try to print,...
Hi
I've nearly the same problem....My printer(HL5050)  takes only a little bit of the sheet, then paper led flashes.
I've found a block into the paper feeder. This printer is impossible to disassemble.!!...even if I've the service manual, because for taking away a simple pressed paper block , it's necessary disassembling  almost all the machine!!! No comment
So I'd an idea:
I've sprayed into the paper feeder a great quantity of a cleaning spray (without oil) , in order to get the paper block wet, then , by means a school-book plastic cover, used like a paper sheet,  and  manually acting on the gear, I've pulled this plastic sheet up and down several time (spraying in the same time)in order to  remove these hard paper blocks. Now my feeder seems free. Tomorrow I'll try to test it.....
Regards
PS To do this it's necessary the only removal of left cover, in order to reach the gear which allows the paper to advance manually.
Apr 21, 2008 | Office Equipment & Supplies
Brother HL-2040 Flashing Paper LED
Try send one paper manually, then it will pick up paper from the try automatically.
Feb 06, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
227 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
