Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
L.E.D lights at back constantly blinking, garage door won't open
Both remotes do not work 90% of the time, wall unit the same. Began as a gradual thing. Would work fine for a short time after switching power outlet then back to not working. Craftsman 139.53648SRT
  • kenjico Jun 16, 2009
    It was helpful but didn't solve the problem but helped narrow it down. Finally, when I had a remote in one hand and tapped on the side of the door opener 2 or 3 times, it opened. Most likely now looking for a loose connection inside the box.
    President:
  • 3,197 Answers
If the LED is blinking randomly it is normal. If it is blinking rapidly you have interference from somewhere. To eliminate any interference start unplugging anything electrical and watch the LED. Some things will interfere that you wouldn't even think of like a heater in an aquarium. Check everything especially in the garage.
Posted on Jun 15, 2009
Garage door opener won't work
Motor has overheated; the motor unit does not operate or trolleyis stuck on stop bolt = Motor unit hums briefly; RPM Sensor =Short travel 6-8" (15-20 cm).• Unplug unit to reset. Try to operate motor unit, check diagnostic code.• If it is still flashing 5 times and motor unit moves 6-8" (15-20 cm), replace RPMsensor.• If motor unit doesn't operate, motor unit is overheated. Wait 30 minutes andretry. If motor unit still will not operate replace logic board.
Aug 30, 2012 | Craftsman 3/4 Hp Garage Door Opener System...
I have a liftmaster Model 1240. Door will open by remote or wall opener. The door will only close while holding wall opener button down. If i try and close via remote, light starts blinking and door...
The only thing that will cause the main light to flash 10 times and the door to reverse to the open position is a sensor problem. Make sure the light on each sensor is on and not flickering ever so slightly. Make sure they are not moving when the door starts to close. Lights on sensors should not blink. One light should stay on constantly and the other sensors light should go off when you block the sensors.
Jan 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman Garage Door Opener Model 139 18860. I can't get the remote to work. The Keypad works and I have fresh batteries in the remote but the system won't recognize it. How do you program the...
First of all make sure the small light in the wall control is not blinking. If it is press and hold the lock button on the wall control for 3 seconds and release. The light should stop blinking and the remote will work.
To program the remote you should first locate the smart/learn button on the rear of the motor unit. Now press and hold the button down on the remote while you press and immediately release the smart/learn button.
If neither of these work your remote is bad.
Nov 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
The green light on the wall switch is blinking constantly yet it works to open/close the door. The remote does not work. Any suggestions?
Press and hold the lock button on the wall control for 3 seconds. The light will stop blinking and your remotes will work.
May 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
The wall button has a green light that is blinking and the car remote will not operate the garage door but the wall button works
this just happened to us today as well. the wall pad has three buttons: one large back-lit button pad to open it and a lock button and a light button. the open button was blinking quickly and would open the door, but the car remotes did not work. I found that by pushing both the "lock" and "light" button at the same time for about 3 or 4 seconds, the back-lit "open" pad stopped blinking and went to steady green. I went back to the cars and checked the remotes there. both opened the door.
hope this helps someone out there
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not open or close with remotes
Put new batteries in the remotes.
Check the DIP switches in the opener
Check the dip switches in the remotes. They must match the opener.
Feb 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens on it own and light blinks
  • Stuck remote control button. Check all remotes. check LED on receiver.
  • Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
  • Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks pbstation771@verizon.net
Aug 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Jun 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
410 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
