SOURCE: Wii won't connect to Wi-Fi network.
Please note that your wii console has a lower internet signal (less bars) and you must get a little closer to connect. Or your wii must have another problem i cant solve.
SOURCE: error code 52030 Unable
the Wii may not allow the usb since you may not have a wire-less internet so the usb may work fluently but a router is required
SOURCE: We're trying to set up
I'm think that you need to enter a code, I have attach a doc that should help you out. I found this link at Nintend.com
Asked to enter a security key?
If you are prompted to "Enter the
Password or Key," then the wireless network you are trying to connect to
has wireless security turned on. You will need to type in your security
key or password and select "OK."
Don't know your router's security key?
Let us help you find your router's security key.
Select the brand of your router below and we'll provide you with the
default information for that brand!
Linksys Netgear DLink
Belkin Apple 2Wire
All other brands
SOURCE: error code 051110-1 How and where do you enter
Go onto the Ds game that your going to play wi fi
go to multiplayer
then Wi-fi
then go into settings and it should come up with 3 boxes of connections , click on and go from there :)
SOURCE: Error Code :51100 Nintendo Wi-Fi
Error Code: 51100
The WEP key for the Access Point you are attempting to connect to has changed since you last connected. If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
What to do:
