Question about Poulan Garden
Will not start its getting fuel and has spark
  • panilling9
    panilling9 May 11, 2010
    find a compression gauge remove plug and install compression gauge
    you need 70 psi or above unless its a homelite with a compression release
    you have below 70 your ring is stuck and or cylinder ruined or loose head to crankcase bolts or gasket blown
  • 1,041 Answers
First, you will need to check the fuel lines for cracks/breaks.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
(NOTE: If the carburetor parts are more than four years old, and depending on the use, you will need a new carb. kit if the cleaning doesn't work.)
If you need further assistance, just let me know.
Jim
Posted on Jun 18, 2009
  • Jim Parker
    Jim Parker Jun 21, 2009
    Did this solution solve the problem?
    Jim
Changed both electric fuel pumps and also the fuel filter and had the carburetor overhauled when sits to long I have to crank it oer an over too start 86 R/V Ford 460
Air, fuel and spark are the 3 things you need to start and run. Too much or not enough fuel or not enough air will prevent starting. After you try starting, smell for excessive for fuel. A freshly rebuilt carb does not mean you are getting fuel from the tank to the carb. Fuel pump may not be working or the line couple be clogged. If you confirm fuel coming in, check for the spark. Pull spark plug from 1 cylinder, have a friend ready to attempt to start the vehicle. Use an insulated glove if available, but have the spark plug wire connected to that spark plug and hold the electrode of the spark plug close (not touching) the engine block. If you don't see a spark, something is not letting the electricity get through. Potential for bad rotor, distributor/cap and/or wires. On a vehicle that old, replacing all of those with new would probably be beneficial anyways. Clean out the fuel lines and add fuel additives to get your system in better condition. E3 spark plugs are great and everything you would need as at any Auto parts store.
Mar 22, 2018 | RVs
96 ciera 2.2 ran fine. parkedat night next morn wont start.its getting fuel and fire but sounds like its not even trying to start
Check for spark.. pull one spark plug out set it on bare metal(away from cyl hole fuel could light from spark) turn vehicle over and look for spark should be a nice lightning bolt looking spark... blue spark is weak spark.. and see if it's getting spark...,, if not,,."try new plugs.,wires,distributor cap&rotor " also first.spray a little starting fluid down the injection system turn it over and see if it fires.if it does then it's a fuel issue prob not electrical... try that.hope it helps
Dec 31, 2016 | Cars & Trucks
Why does it turn over but won't start?
You need 3 basic things to make an engine run. 1 Compression, 2 Fuel, 3 Spark. So start buy checking for spark, remove a spark plug and plug it back into the wire. Now touch the threads of the spark plug to metal ( a good ground on the engine) and then turn the engine over (try to start it) and see if you have spark? No spark find the problem. If you have spark now see if you have fuel getting to the engine. You can try pouring a little fuel into the carb or throttle body and then see if the engine will fire or try to run. If it tries to run or fires you have a fuel problem. You need to find out why it is not getting fuel. Spark or fuel, 90% of the time are the main causes when an engine will not run. I hope this gets you started. Rod
Aug 17, 2015 | Cars & Trucks
Saw wont start, getting fuel and spark
Try starting it with the air filter removed. If it starts, clean the air filter. It could also be the fuel filter. If you replaced all the fuel lines, make sure you didn't get the oil line mixed up with a fuel line
Jan 25, 2015 | Poulan Garden
Why won't my 1991 camaro start?
Spark or fuel. Start with spark. There are inexpensive little test lights that will let you know if you're getting spark. If you have spark, start looking for a problem in your fuel system. Do you hear the pump kick on when you turn on the key before you start cranking? Is its air choked off? In line fuel filter that could be clogged? Fuel pressure? Injectors firing? Start with the easy stuff and rule out possibilities one-by-one until you find what's keeping the engine from getting spark, air, or gas.
Jul 21, 2014 | 1991 Chevrolet Camaro
Have a 1985 buick centruy with a 2.5 seems like its loading up with to much fuel wont start.I have spark timing is good, compression good, and changed the temp sensor. tried a different maf sensor(used)...
If you have spark, and the timing is good, you are either not getting enough fuel or there is not enough compression. If you checked the spark from the spark plug wires and got a spark, try changing the spark plugs. The spark from the plugs may be too weak to ignite the fuel.
Have you changed your fuel filter? This is a very common cause of a no start condition. Have your fuel pressure tested to ensure you are getting the correct amount of fuel. Also, you could try replacing your Fuel Pressure Regulator.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 17, 2011 | 1985 Buick Century
Van cranks but will not start
Hi, if the engine cranks over normally when you attempt to start you car, but the engine does not start, the problem may be NO FUEL, NO SPARK or NO COMPRESSION. The engine needs adequate fuel pressure, a properly timed spark and normal compression to start.
To find why the engine won't start, remove the air inlet tube from the throttle body, push the throttle open and spray a small amount of aerosol starting fluid into the engine. Crank the engine. IF it has spark and compression but NO FUEL, it will start and run a few seconds before dying. If it does NOT start, it probably has NO SPARK.
Another method to check for spark is to pull a spark plug wire off of a spark plug (if it has plug wires, coil-on-plug ignitions do not) and place the open end of the plug wire near a metal surface on the engine. Have a helper crank the engine while you watch for a spark. DO NOT hold the wire while doing this as it can shock you. If you see a spark, the problem is not spark, but most likely NO FUEL or NO COMPRESSION. If you do not see a spark, the problem is in the IGNITION CIRCUIT.
Proper fuel pressure is critical for fuel injected engines to start and run. You should hear the fuel pump inside the fuel tank buzz for a couple of seconds when the ignition is turned on (no buzz means the pump is not running and the engine is not getting fuel). You can smell the tailpipe for gasoline vapors after cranking the engine. If you smell gas, the problem is likely not fuel but NO SPARK. You can also remove the plastic cap and press the schraeder valve test fitting on the fuel rail to see if there is any fuel pressure to the engine (not a very accurate test because fuel pressure must be at a certain level for the engine to start, for that you need a gauge). Even so, no fuel at the fuel rail would tell you fuel is not getting to the engine.
Dec 22, 2010 | 1996 Chrysler Town & Country
My car wont start
If the engine cranks over normally when you attempt to start you car, but the engine does not start, the problem may be NO FUEL, NO SPARK or NO COMPRESSION. The engine needs adequate fuel pressure, a properly timed spark and normal compression to start.
1) To find why the engine won't start, remove the air inlet tube from the throttle body, push the throttle open and spray a small amount of aerosol starting fluid into the engine. Crank the engine. If it has spark and compression but NO FUEL, it will start and run a few seconds before dying. If it does NOT start, it probably has NO SPARK.
2)Another method to check for spark is to pull a spark plug wire off of a spark plug (if it has plug wires, coil-on-plug ignitions do not) and place the open end of the plug wire near a metal surface on the engine. Have a helper crank the engine while you watch for a spark. DO NOT hold the wire while doing this as it can shock you. If you see a spark, the problem is not spark, but most likely NO FUEL or NO COMPRESSION. If you do not see a spark, the problem is in the IGNITION CIRCUIT.
3)Proper fuel pressure is critical for fuel injected engines to start and run. You should hear the fuel pump inside the fuel tank buzz for a couple of seconds when the ignition is turned on (no buzz means the pump is not running and the engine is not getting fuel). You can smell the tailpipe for gasoline vapors after cranking the engine. If you smell gas, the problem is likely not fuel but NO SPARK. You can also remove the plastic cap and press the schraeder valve test fitting on the fuel rail to see if there is any fuel pressure to the engine (not a very accurate test because fuel pressure must be at a certain level for the engine to start, for that you need a gauge). Even so, no fuel at the fuel rail would tell you fuel is not getting to the engine..
Thank you !!
May 30, 2010 | 2002 Cadillac Deville
2001 expedition cranks but wont start
check your crankshaft position sensor
Mar 21, 2010 | 2000 Ford Expedition
"Cranks, but won't start". Replaced fuel pump, CKP, ICM & nothing
Aug 27, 2009 | Chevrolet Camaro Cars & Trucks
Garden Logo
69 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
