Looking for jumper conections for main board 6674hppav3
    Problem Solver:
  • 5 Answers
Search online and at stores
Posted on Jun 15, 2009
Tip
How to Test the Relay Board on Stairmaster SM916 Stepmill
How to Test the Relay Board on a Stairmaster SM916 Stepmill Disconnect power from the machine.
Disconnect the main cable from the relay board J1 terminal. Main cable should remain disconnected for the duration of the relay board tests.
With the Power ON, place a jumper wire across the GND/BLK and RLY/RED test points. (Ensure jumper wire only makes contact with the designated test points.)
  • Verify that the Relay LED is lit. Remove jumper wire.
With the Power ON, place jumper wire across the +/WHT and FLD/BRN test points. (Ensure jumper wire only makes contact with the designated test points.)
  • Verify that the Field LED is lit. Remove jumper wire.
With the Power ON, place jumper wire across the +/WHT and with the other end touch the ALT/C, FLD/NC, and RES/NO.
  • Verify that the Field LED lights.
If any of these jumps fail, replace the relay board and or power supply.
Stairmaster SM916 Stepmill Relay Board Testing
on Feb 25, 2015 | Stairmaster SM 916 StepMill
I have an insignia 46" tv I replaced the main board, the tv works except the picture is upside down, what will correct this problem
Flip the TV over! Just kidding!! When you installed the main board was it identical to the old main board? If so, you might want to look at the old board and ensure there are no jumpers that needed to be set on the new board. Some companies make generic control boards for tvs but have different jumper settings for different models. The jumpers are just little black blocks that connect different pins to each other on top of the circuit board.
Dec 03, 2014 | Insignia Televison & Video
What does a jumper look like
A small 3mm x 2mm plastic block with copper or gold clip inset which is used to complete an electrical connection, typically on a computer main board or on a circuit board plugged into a computer. They come in varying colours, the colour has no bearing on the electrical properties of the jumper but can be used for easy identifycation.
Jul 20, 2014 | Dell Computers & Internet
Dell 4700 need to reformat but need to get admin code for the bios. already took bios bat out and unplugged all cords on inside and re-plugged them. got system code, but still need bios admin code is there...
I believe that you need to set up the CMOS jumpers inside the main circuit board. For details click on this link (Click Me)
1. Look for 3 pin CMOS clip that says CLR CMOS on the mainboard 2. Take out the jumpers from 1 and 2 3. Put it in jumpers 2 and 3 and wait for 5 seconds 4. Put it back to jumpers 1 and 2
Figure 1. Schematic Diagram of Main Board Dimension 4700
Thank you for choosing Fixya
Jul 06, 2011 | Dell Dimension 4700 PC Desktop
Chassis intruded problesm in my asus p5kpl am se motherboard
hello ranjanpal18
my name is ausi
chassis intrusion can be enabled or disabled in two ways. 1- by a jumper on the main board or 2- by a bios option.
i had a look at your main board, could not see a jumper on it so i can say it is a bios option.
when you start the computer press the ESC key. this takes you to the bios section of the main board.
look at the menue listing to see if there is anythig call security settings. it should be there. if there is nothing with security in it then you look at other options such as boot options or on board .......
hopefully this has been helpful. if so please vote for me.
Jan 11, 2011 | ASUS P5KPL-AM SE Motherboard
I need to reset jumper 1, I forgot my password, where is jumper 1 what does it look like
ok..u don't need reset the jumper..i'll try make it simple..disconnect all input mains power sources.."just remove or pick open the cmos battery (+3v) from the main/mother board and resit/fit it again carefully"..hope it'll work..
always better to hv professional supervision, contact ur system admin/vendor....
Oct 31, 2009 | Chaintech VNF3-250 Motherboard
How do I force a defrost on a ge sxs gss20iepcww It is not a touch pad control ref. It has 2 knobs
on all ge electronic models produced since 2000 the main power lead to the main board can be jumped to test either defrost or compressor operation.to do this unplug the unit and locate the 3 wire plug (usually blue in color) .unplug the harness from the board and create a jumper wire to by pass the board.the terminals on the board will be identified as line,compressor and heater.to put unit in defrost install jumper between line and htr or def .this will ck the defrost sys.once unit is plugged in with jumper in place the heater will come on.if the heater does not come on look for a defective heater or defrost t/stat.hope this helps.
Jun 03, 2009 | GE Refrigerators
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
