Question about Epson Stylus 2200 InkJet Photo Printer
EPSON 1280 SILVER INK JET PRINTER, Stopped printing on glossy
Photo paper. At first the printer worked fine. Then for unknown reason
it stopped feeding and printing on glossy photo paper. I did everything
in the manual, but nothing corrected the problem.
  • Epson Master
  • 511 Answers
Problem with paper feeder. Replace paper feeder or replace just pick up rubber at paper feeder mechanics. You can add thickness of rubber by adding black double tape (flexible) (about 1mm).
Posted on Jun 16, 2009
Why won't my Epson Printer XP405 print a photo on Epson Glossy Photo paper
Your printer may need you to replace the "matt black ink" with "gloss black ink".
May 19, 2015 | Epson Office Equipment & Supplies
Correct setting for Epson Workforce 7520 printing on gloss paper
You need to start with photo glossy paper that's designed for an Epson printer. HP paper may not work well, and some other papers don't work either. Try some Epson paper, and that should work fine.
You can also try other paper settings, such as "transparency" or "matte paper", as the paper setting governs how much ink is laid down. I think getting the right paper is really what you need, though. Ink "puddling" is a common Epson complaint, and it's almost always the paper.
Nov 02, 2014 | Epson WorkForce WF-7520 Wide Format...
Epson Photo Stylus 1280 print heads do not work
The problem is the print head, The ink cartrige for this printer is just a little bottle of ink. What really causes problem in it IS THE CLOGGED HEAD. If you have skill to reach thepen of the head (part that touchs the paper) use a quill tip or rag soak on water and clean it. Or go to EPSON SITE AND ORDER A HEAD CLEANNER FLUID TO POUR INSIDE THE HEAD AND CLEAN IT.
Oct 23, 2012 | Epson Stylus Photo 1280 InkJet Printer
My R1900 is over 1 year old. Profiles are set for Epson glossy and matte paper. Epson ink is used. Colors are now very green when printing to glossy or matte paper. However, if I use the plain paper...
The difference in choosing the paper type will have an impact on how head squirts ink onto the media. For Epson printers, the best choice to fit the color is plain paper.However, to the maximum dpi (best photo or photo rpm), plain paper does not support.This can be overcome by adjusting the color management of the program that we use.Or convert to bitmap all objects (such as Corel Draw), or also in print as bitmap option.
Feb 22, 2011 | Epson Stylus Photo R1900 InkJet Printer
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Epson printer that can print at art glossy paper
Epson's ink uses a dift technology so far better result you need to check what brand of glossy or photo paper you can use. You can purchase an epson photo or glossy paper for best results.
Your printer would work best using the list below:
Paper Types
  • Supports a variety of Epson plain and photo papers. Supports plain, bond, air mail, Epson Premium Bright White, Glossy Photo Paper, Premium Glossy Photo Paper, Premium Semigloss Paper, Premium Luster Paper, ColorLife paper, Matte Paper Heavyweight, Double-sided Matte, Inkjet Transparencies, Self-adhesive Sheets, Photo Quality Ink Jet Paper, Greeting Cards, High Quality Banner paper; labels; envelopes, Iron-on Transfers and Photo Stickers; Printable CD-R/DVD-R; Panoramic 8.3" x 23.4" Photo Paper
If you may have other questions pls feel free to ask.
Just rate me Fixya if your issue has been resolved.
Cheers.
Jun 17, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson C120/ Stops at Perforated line
the sensors cant see paper on the perforated part/side.
same goes for transparencies, the printer can't see it
Your printer supports the following media types:
Epson Bright White Paper
Epson Iron-on Cool Peel Transfer Paper
Epson Photo Paper Glossy
Epson Photo Quality Self-adhesive Sheets
Epson Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-sided
Epson Presentation Paper Matte
Epson Ultra Premium Photo Paper Glossy
Jan 23, 2008 | Epson Stylus C60 InkJet Printer
Epson 1280 Printer breakdown
it is the wasted ink pad, they are full.
to have your printer work again
turn off the printer.
press and hold the ink and paper button while turning on the printer, wait for 5 seconds then release the button and press the paper button for at least 10 sec.
if done correctly , you will see the carriage start moving
Jan 20, 2008 | Epson Stylus Photo 1280 InkJet Printer
Black ink on glossy paper looks like leopard spots
printer need head cleaning , after cleaning check nozzle , if solid color appear w/out space on black color it means good and clean nozzle.
Dec 27, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Black and yellow ink not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Nov 18, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus 2200 InkJet Photo Printer Logo
219 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
