Question about Brother MFC 3820CN All-In-One InkJet Printer
Error 41 how do i clear error 41
  • 832 Answers
Re: error 41
You cant clear error 41. It means that the printhead is rotten.
Do call brother hotline and ask for free replacement. They have changed the warranty because this is a faulty design by brother!
Posted on Oct 31, 2007
0 characters
3 Points
What does code: H4-00 mean
The H4-00 is a low temp error in the fuser. This can normally be reset by doing the following at the machine:
On the button panel hit
pound, star, C, star
then enter 14, hit start, then execute on the screen.
This should clear any one-off errors EquipMyBiz
Aug 04, 2014 | Sharp MX-4101N Multifunction Printer Color...
Dear Sir I have a technical error 41 and i dont know what to do.
When did the problem start on the printer
Aug 06, 2008 | Brother Printers & Copiers
Canon Pixma MP210 will not recognize high yield PG-50 & CL-51 cartridges.
The canon pixma mp 210 uses PG-30, CL-31, PG-40, CL-41
It will not recognized the PG-50 & CL- 51
See if you can return it and exchange it for the PG-40 & CL-41.
If not, the only other way is to transfer the ink into the other ink cartridges.
The cartridge cap can be removed by a sharp tap at the back end of the cover.
You can glue back the cover.
If there is an E 1,6 Error code, Ink has run out after you install your ink cartridges
Press and hold the stop/reset button for about 10 seconds to clear the error code.
Dec 24, 2010 | Canon Printers & Copiers
41 device error
i have a problem 41 device error in the toshiba dp80f
Feb 17, 2010 | Toshiba DP80F Printer
Error 41
error 41 is a printhead fault. The only repair is a new printhead. The price went up this year so a new one will cost you at least $89.00 plus labor.
Jul 29, 2009 | Brother MFC 3420C All-In-One InkJet...
Error 41 near empty black and near empty cyan.
first, the error 41 will eventually come back sooner if not later.
error 41 means that your printhead is failing.
the error that its giving you now is that your black and cyan cartridges are empty. there are 4 colors in your prnter.
May 31, 2009 | Brother MFC 3220C All-In-One InkJet...
Brother MFC 3100 Printer/fax
This is the only reference I could find on error 41: How can I clear the message Machine Error 41 from the display? (ME41)
Machine Error 41 indicates a mechanical malfunction of the Brother
machine. Unplug the unit from the power source and then plug it back
If the error message continues to be displayed on the LCD, please call
Brother Customer Service at 1-800-284-4329 for assistance. The Customer
Service center is open Monday through Friday, from 9:00AM to 7:00PM,
excluding holidays If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | Printers & Copiers
Machine error 41
Machine Error 41 indicates a mechanical malfunction with FAX/DCP/MFC.Often, unplugging the unit from the power source and then plugging it back in again can clear this error message.If the message continues to be displayed on the LCD, please contact YOUR PRINTER Customer Service for more options.
Sep 16, 2008 | Printers & Copiers
Machine Error 41
Error code 41, Print cartridge is bad and gone out. Needs to be replaced by authorize dealer for just under $100.00 ($55.00 part & $40.00 Labor).
Nov 14, 2006 | Brother IntelliFAX 1800C All-In-One...
Brother MFC 3820CN All-In-One InkJet Printer Logo
130 people viewed this question
Top Brother Printers & Copiers Experts
Jim Yeh
Level 1 Expert
Jesus  Colon
Jesus Colon
Level 1 Expert
Rick Johnson
Rick Johnson
Are you a Brother Printer and Copier Expert? Answer questions, earn points and help others
