Question about RCA S2001 MP3 Player
Fat error - RCA S2001 MP3 Player
PROBLEM SOLVED!!!!
try this steps...(pardon my english)
1. if you have another flash disk drive, connect it to your pc...
it should say " removable disk (E)or stuff.. haha)"
2. right click on it and select "format"
3. tick the quick format box and change the format type into FAT
4. do not start yet! as quick as you can, conect your f*%ked up RCA device...
5. wait till the "removable disk (E)" appears or whatever the letter is, just make sure that it is the same as the previous letter in step1 was... then click start... you may not actually wait
it worked for me...
goodluck guys!
ivo_88@ovi.com message me for feedbacks
Posted on Oct 01, 2009
Error! reformat external media with sigma telfprmatter
Posted on Sep 08, 2009
What does Err3 mean on taylor body fat scale?
Remove your shoes and socks and wet your feet slightly with a damp cloth if you receive the "ERR3" error. ERR3 is a contact error and your feet should ideally be bare and wet to achieve an accurate body-fat reading.
  • Step off the scale and wait for it reset. Remove your shoes and socks and wet your feet slightly if you receive either the "ERR4" or "ERR5" errors, which means your body-fat or body measurements are out of range.
  • Reset the scale if it doesn't work or you continue to receive error messages. Remove the battery and set the scale on a flat surface. Stand still on the scale for five seconds and step off. Re-install the battery and place the scale back on the flat surface. Place one foot on the scale until it displays zeros or dashes. Remove your foot and wait for the scale to turn off. Step back on the scale to weigh yourself
  • Sep 28, 2016 | Taylor Health & Beauty
    Tip
    How to fix No Bootable Media Error Message
    FAT (File Allocation Table) is one of the most widely used file systems used now-a-days with various versions of Windows operating systems and memory cards. Every logical partition contains a FAT that consists of file allocation information and the information of free allocation units that need to be assigned to files. Although the FAT file system is reliable, corruption still occurs due to various reasons. In such situations of FAT corruption, your system becomes unbootable, resulting into inaccessibility of data saved in FAT based hard drive. To access the data after FAT file system damage, an easy way is to restore the data from an updated backup. But, with inaccessibility of data backup or backup falling short to restore the required data, an ideal option left is to use an advanced FAT Data Recoveryapplication that can recover the lost data.
    To illustrate the above scenario, consider a practical case the below error message pops up when you attempt to boot your system:
    “No Bootable Media”
    As the above error message appears at the time of booting the system, you wont be able to access the data saved in the hard drive.
    Cause:
    The above error message because the FAT file system has been corrupted. Few main causes for file system damage are improper system shutdown, human errors, and virus attack.
    Resolution:
    To isolate the above error message and to access the data after the above error message appears, you will need to follow the below steps:
    Run CHKDSK utility to repair the FAT file system. If the problem persists, format the hard drive.
    While the latter resolution resolves the above error message completely, it also deletes the data saved on your hard drive. In such cases, if the backup is not available, then you can only recover your formatted data by using an advanced third-party FAT Data Recovery software.
    A FAT Partition Recovery utility thoroughly scans a FAT based hard drive and recovers almost all data, even after formatting. The data recovery utility can be downloaded from the Internet.
    Stellar Phoenix Windows Data Recovery is an efficient FAT Partition Recovery tool that recover lost, deleted, and formatted data from both FAT (FAT12, FAT16, FAT32, VFAT) and NTFS (NTFS, and NTFS5 ) based hard drives. The detailed help manual attached with the tool allows even a new user to perform recovery easily without any technical knowledge. It supports Windows 7, Vista, XP, 2003, and 2000.
    on Jun 30, 2010 | Computers & Internet
    How do i fix format error C:13:01 from my sony memory card
    CHANGE U R FORMAT MEDIUM FROM, FAT TO FAT 32....IF IT IS ALREADY IN FAT 32 THEN CHANGE IT TO FAT AND FORMAT.....
    Feb 25, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
    Digta 410 fat error
    Try formatting the memory - or try using an external memory card (SD).
    May 28, 2010 | Grundig Digta 410I Digital Recorder (32 MB...
    FAT Error on Insignia MP3 player
    ok kathlessk
    do one thing
    go throught disk management and locate your mp3 digital player.
    try to format it fat file system
    it must work after this
    ok...
    Nov 20, 2009 | Insignia Audio Players & Recorders
    Sansa fuze FAT error
    Plug your Fuze into your computer. Open "My Computer," right click your Fuze and click "Format," a window will pop up with settings on how you want to format it, make sure it's set to FAT, then click "Format."
    May 09, 2009 | SanDisk Sansa Fuze MP3 Player
    Error
    window xp professional does not support FAT 16 thats why you need to formate xp with FAT 32 or NTFS.you wont get that error any more
    Feb 26, 2009 | Microsoft Windows XP Professional With...
    E3 Error
    here are the codes i found
    E-1 Electrodes were not firmly grasped. Grasp the electrodes correctly.
    E-3 Hands are dry. Slightly moisten hands with
    a wet towel.
    E-4 Body Fat Percentage and BMI values are outside themeasurable range. verify your personal data is
    correct.
    E-5 and E-6 Irregular Operation Turn the unit off, then on. Take another measurement. If the error occurs again contact Customer Service at 800-634-4350
    have a great weekend!
    Jan 29, 2009 | Omron Body Fat Analyzer from
    Fat error plz connect ums
    my mpc 983 say fat error connet ums how i can fix
    Mar 11, 2008 | Audio Players & Recorders
    RCA S2001 MP3 Player Logo
    165 people viewed this question
    Top RCA Audio Players & Recorders Experts
    Gyula Lacz
    Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
