When starting the dishwasher the chore light will initially light up then it powers off and will not start a cycle
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
SOURCE: Whirlpool dishwasher will not start
There is a small replacable part on the control panel circuit board which is like a fuse. It actually is a temperature fuse and it blows when the environment gets too hot for the circuit board. Unplug the dishwasher and take the door apart so you can see the circuit board. If you trace the power wires one of them leads to a little white module with 2 electrical tabs. Unplug the 2 wires and unsnap the module. You can check it with an ohm meter. IF its good the meter will register almost a short. f it's bad it will be open. The parts place I went to didn't even need a model number and he says he goes through a lot of them.
SOURCE: The start light just blinks and the dishwasher wont start?
just found a web site that says crack door open, press normal, hot dry, normal, hot dry, then cancel to reset the controls.
SOURCE: ''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When
the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all
buttons are non responsive). It does this as a safety in case the
element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all
the lights will turn on briefly and the machine will start a diagnostic
cycle. You can press cancel or let the diagnostic cyle finish (1-2
minutes).
You should now be able to run the dishwasher as normal.
If
the issue returns, you could have a problem with the heating circuit
(ie. element, thermostat or wiring).
It rarely happens but it could
also be the door switch not engaging properly when the door is closed
(slightly bend the door latch down making sure it doesn't hit the door
when you close it).
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
• Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
• The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
