Question about Dell Dimension 8200 AUD System Board (0F141) Motherboard
Broke power button dell dimension 8200
The wires have been cut. I need a hand hooking them back up properly
    Problem Solver:
  • 16 Answers
Your best bet would be to take it to your local computer repair shop in the hope they are willing to just help you out as it's a very easy repair. failing that ask them if they have a spare switch of the samae type you need and repair it yourself. they normaly have lots of spare bits lieing around they might just give to you.
Posted on Jun 15, 2009
Dell Dimension 8200 Desktop PC shuts off after it has been on for a long time. It shuts off like power has been removed from the CPU although I have an APC hooked up to it.
Sir you should check the power supply of your system.If its working properly then its because of the heat sink of your motherboard...Try to mother heat sink fans in the pc and your problem is solved......
Aug 02, 2010 | Dell Dimension 8200 PC Desktop
I recently moved and when i hooked all of it back
open it up check all the connections memory and add in cards for security.
connect it and try again. Sometimes the bios battery can cause wierd problems, they are usually a 2032 battery on the motherboard. replace it if it's suspect. I would then look at the power supply. Big heavy capitors don't like being dropped, (neither do hard drives for that matter).
Jan 10, 2010 | Dell Dimension 8200 PC Desktop
Main power button LED is flashing or solid yellow
This is a major problem that crippled Dell. Moels Optiplex Gx260, Gx 280, and Dimensions of whose mdel number i don't remember have this problems. This signal shows that either a power supply or your motherboard is malfunctioning. If you have an insurance better use it now or else get some technical assistance.
Nov 03, 2009 | Dell Dimension 8200 PC Desktop
Wiring diagram from the LED power button board to the 0M686 CTRL PNL BOARD on a DELL DIMENSION 8200
Go to the Dell web site and type in you computer information and look for a pdf download for repairing the Dimension 8200. Dell is real good about giving you any information on fixing your computer. And it is usually free. I use them all the time. If you are having problems finding it on there site, you can call them and request the information you need...Hope this helps you,,,Darren
Oct 16, 2009 | Dell Dimension 8200 PC Desktop
I need the LED/power Button Cable Assy. for my Dell Dimension 8200 PC Desktop
Best way to get one of these is to go to a local independent computer service center and ask for what you need. The LED/power button wires are pretty typical in all PCs. So, they should be able to fix you up with little cost.
Oct 11, 2009 | Dell Dimension 8200 PC Desktop
Need to plug in the power button to the motherboard but can't find any place to plug it into. My system is a dell dimension 8200.
The dell Dimension 8200 motherboard like several other Dell boards uses a multi pin header for the power button. This plus is at the front of the board right behind the hard drive connectors. The plus has pins for power, hard drive light, sound, 2 USB ports, power light and microphone. Are you wanting to just coeect the power button and not the other pins? I may be able to get you a pin by pin wiring chart but other things really need to be pugged in too. This board will not work very well without the other things plugged in or if it is not in a Dell case.
Buddy
Corporate Computer
Jun 18, 2009 | Dell Computers & Internet
Dell Dimension 8200 won't power up
If the power button does not light up at all, I would guess the power supply has a problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 8200 PC Desktop
DELL DImension does not boot
Try removing your RAM handling by the edges, clean the terminals with an eraser and reinsert firmly. Reboot your computer. Make sure you remove static charges from your body by placing your hands on a grounded object.
Sep 03, 2008 | Dell Dimension 8200 PC Desktop
Dimension 8200 will not turn on
Try a new power button. Also does the machine power light turn on at the front of the machine? if so check that the CPU is seated correctly as if it has come out of position then the machine doesn't boot. I would like to think power switch though.
Thanks J
Jan 17, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 AUD System Board (0F141) Motherboard Logo
124 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
