Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore he3t washer had power, but no response to selections and wouldn't start...now, no power present at all. any suggestions?
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
My HE3t Kenmore washer will not start. All the lights come on and you can select the cycle but the start button will not start the machine. We did unplug it to reset the machine but that did not wor
This may be a stupid question...but is the water turned on? Stranger things have happened!
If the drum inside doesn\'t turn, it may be an electronic issue. Hopefully the washer is under warranty. Best of luck!
Oct 09, 2014 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Have a Kenmore Elite HE3T washer. Put appropriate detergent, fabric softener in, selected NORMAL cycle, spin speed, etc. Just sits there. Pressed START button several times. Nothing. Little cycle lights...
I own a 18-year-old Kenmore front-load washer so I'm not sure this will apply, but here goes... My washer requires me to press and HOLD the start button for a few seconds before it will start. At that point the door will lock and the washer goes through its startup phase. I think that is a "safety feature' to keep from accidentally bumping the button and starting the washer. See if that help. Good luck!
Nov 22, 2017 | Kenmore HE3T Washer
Kenmore HE3t Frontloader Fills Up With Water After Cycle
inlet valves have possibly gotten dirt in them and need replaced . quick fix , is turn the water valves off behind the machine
Nov 07, 2017 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have a Kenmore HE3t 2002 model washer that the buttons light up but the washer will not start when the start button is pushed. You can select any cycle ad it lights up.
There is a black plastic piece that sticks out from the machine. It is located at about
2 o'clock. You probably broke off the piece as I did with mine. If you have a wooden skewer (or something like it), stick it in and depress the button. You can glue the skewer in place.
That should fix your problem.
Aug 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore he3t door locked cant reset or open
Kenmore HE3t sanitary cycle setting has changed. Water temp selection only allows Hot/Cold selection but should offer the Extra Hot selection. All other settings test out properly. Is there a way to reset factory settings for cycles?
Jul 08, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Oder inside washer
On newer other machines, there is a cleanout cycle that uses 2/3 cup of bleach, no detergent and I believe uses more water. Suggest you use a load of white towels, no detergent, the bleach and put it through a normal or soak cycle where the bleach has a chance to kill off the germs and other bacteria, then rinses itself clean. They also recommend that the door be left open on these machines to allow the moisture to clear and dry assisting in curtailing further development of the same. The cleanout procedure they present is suggested for monthly using their special cycle which doesn't exist on my HE3T either. Hope this helps some. NOTE: There are cautions about leaving the high level of concentrations in the washer for extended periods or too often.
Sep 08, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
HELP my clothes and sheets are being held hostage !!!!
first unplug the power cord and plug it back.
select drain/spin with no spin after the cycle completed the door will open.
Jul 29, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
118 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
