Question about Whirlpool Duet GHW9150P Front Load Washer
Electric cord hook-up
I'm trying to hook up a new 4-prong cord, and am not sure where the black, white, and red wires should go. Can you please tell me where each color goes left, middle, and right as you face the back of the dryer?
Model #GEW9250PW1
    Sergeant:
  • 222 Answers
White wire connects to the neutral (probably the center terminal), red and black to the most available terminal after the neutral lead is connected. Green wire is for ground... There should be a ground screw in the connector panel, but if not, be sure to securely attach the Green wire (ground) somewhere on the frame of the dryer. Be sure it makes connection with the metal (i.e. scrap off any paint, etc., where the terminal will be attached).
Posted on Jun 15, 2009
Replacing the power cord on a Frigdaire model FDE546RES1
if your new power cord had three prongs then you will hook up the white wire to the machine's white wire, red to red and black to black. if you have 4 prongs you will have extra green wire this will hook up to a ground screw
hope this helps
Jul 03, 2012 | Frigidaire Electric Dryer
Maytag neptune dryer
Hey white to white, black to black red to the multi colored pole, and the green one is the ground wire,, . I done that before,, lol,, good luck ,, thanks
Oct 05, 2008 | Maytag Neptune MDE6700A Electric Dryer
Don't know how to switch from 4-prong to 3-prong power supply
Your new 3 prong power cord needs to be wired up just like the 4 prong you just dont have the seperate ground . in the use of a three wire cord ground runs thru neutral .Hook black to black on the terminal block on unit. hook red to red on the other side of block and white to white or green in the middle reinstall the cover ....Plug in and your ready to dry
Aug 14, 2010 | LG DLE2532W Electric Dryer
Dryer cord
Your four prong cord has 4 wires. Black,Red,Green and White.
Remove the 3 prong cord from the dryer.
The Black and Red wires go to the outside terminals on the dryer. The White wire goes top the center terminal. The Green wire goes outside the terminal cover to any nearby screw for grounding.
Jan 03, 2010 | Roper REX4634KQ Electric Dryer
The 4 prong to a three prong..here goes it its a cord that is 1-2-3 all facing the u that connects them, old cord off new cord on 1-2-3 one to white one to red one to black same order ...the man a t sears...
If I understand you are using the 3 prong cord now. The L shaped prong is the middle one or white. The 2 flat ones are for the red and the black. If tho original cord was 4 prong there was a ground (round prong). There should be a ground strap connecting the white post to the cabinet in the 3 post setup. Ask me to clarify if this is not clear, better to be sure than hurt..... Eric
If you had a wire incorrect it may have blown a fuse or worse depending on which wire was wrong.
Jun 17, 2009 | Frigidaire FEQ332E Electric Dryer
Maytag De4000 Electric Dryer Wire Hookup
black and red wire, will hook to either end of terminal posts, as long as the white wire connects to the center post. the green wirewill then atach to the cabinet of the unit,( usually a green ground screw just outside the termoal box anyhow!
Apr 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
Changing from 3 prong to 4 prong cord
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 19, 2009 | Dryers
3 prong dryer to 4 prong
green is ground, white is netural. red and black are L1 and L2
or in other words on the dryer there is a 3 screw holder red and black go on the outer ones white goes in the middle and green goes to the cabinet of the dryer
Oct 31, 2008 | Frigidaire FEQ332E Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
117 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
