Cars & Trucks Logo
b
billy Posted on Apr 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
High idle mercedes E350 2010 when i turn heater on leave heater off and car will idle at 550rpm
Start my E350 in morning with all electrics off and the car will idle at 550rpm, put heater on and car will idle at 850rpm
steve
Level 3:
  • Mercedes-Benz Master 3,718 Answers
  • Posted on Apr 02, 2014
 steve
Level 3:
Answers
3718
Questions
Helped
964370
Points
12533
Thats because the electrical system is using more power than the alternator supplies at idle so the ECU increases idle so that all electrical systems i.e fuel delivery etc have enough power supplied absolutely normal
5 Related Answers
Anonymous
  • 70 Answers
  • Posted on Apr 19, 2009
SOURCE: 97 dodge intrepid 3.5 revs high motors kicks when put in gear
its your idle control valve
Anonymous
  • 1071 Answers
  • Posted on Aug 06, 2009
SOURCE: Same problem
throttle is probably going out you can try to clean it but they are usually bad when the epc light is on
Anonymous
  • 236 Answers
  • Posted on Dec 16, 2009
SOURCE: Starting problem for 1999 Lexus GS300
make sure the air filter lid has been put back into proper place, if they left it loose the engine would **** more air while trying to start, so you need more fuel to balance it out.
Testimonial: "Thanks a lot for your help!"
Jason Johnson
  • 1619 Answers
  • Posted on Apr 15, 2010
SOURCE: mercedes e220, horn, heater fan and electric
Horn and heater may be fuse related. The headrests have nothing to do with fuses. The switch is bad or going that way for the seat or the motors for the headrests are out.
The horn fuse spin it, or replace as corrosion from aluminum fuses cause problems. I suggest replacing them all with new copper barrel fuses. The blower motor fan is a strip fuse on the driver side strut mount in a tootsie roll sized case.
Anonymous
  • 2926 Answers
  • Posted on Nov 28, 2010
SOURCE: Car has strong gas smell. Hard start up in
High idle is associated with a vacuum leak from the engine hose's or gaskets. The check engine light is on...telling us there is a problem with one or more of the engines actuators or sensors. The first place any tech would check is for a DTC (trouble code) in the engines computer memory. You will need to see what the trouble code is and proceed with a diagnosis from there, otherwise you will be guessing at this point. It may be the IAC motor on the throttle body, but again, this is just a guess. Autozone will connect a code reader to your engines computer and read the code for you for free if you do not have a code reader. You HAVE to do this part in order for us to help you, and not waste time and money guessing on parts to replace.
Why won't it turn over?
I had the exact same problem with the exact same Van. I simply adjusted the throttle cable under the hood. So that instead of trying to idle around 350rpm, it is now idling between 500-550rpm. Hope this helps.
*I did, at first, change the Mass Airflow Sensor and new Air filter. That seemed to help a bit, but I would still get low idle code. And it wouldn't idle until the engine warmed up. After adjusting the Throttle cable, I've had no more issues.
My 1993 Mercedes Benz 300E is Hard to start in the morning
See my post on fixing vacuum issues
then Temperature sensor at rear of engine test it
then is check vacuum cutoff sensor toward front of engine
Idle air control valave (IACV) clogged?
Voltage regulator? behind battery
Fuel Pump Relay behind battery
20+ year old 124s have these issues all are inexpensive to repair just be slow and maticulus
Also note ther is a clod start fuel injector leave it alone except run techron with three tanks of fuel
Good luck
1997 chevy blazer has a rough idle
probly a vacuum leak-will set lite cause car runnin lean--listen for noises or chec hoses and gasket quality--problem wiil go away w increase speed--some leaks are hidden like egr valve condition-but it isnt stalling--------may want to try a scan w factory specific equip since car is old--cheap littl code readers wont cut it--dont go to a dealer-softwear dont go back that far
1989 mercedes 560 sel, gas, w126/ Car cold starts every morning and idles for 10 min. then stalls
the idle control motor probly worn-on the throttlbody--also the tps sensor - get intake area inspectd--a haynes manual will xplain complete car-partstore hazit--------starter fluid is used for low compression or weak spark
High Idle only on cold start up and Heater is on.
To find out information on engines idling high or low visit http://autorepair.about.com/od/enginetroubleshootin1/a/TS_idle-speed.html---------------------------------------------------------------------------------------
xprog-m
2010 Mazda 3 idling high when i first start it
Its normal .. its the automatic choke,,, no problem,,, the high idle should last longer in the winter.. when it "cold" in Florida.. hehehe...
Yesterday my Mercedes 220 CE had a major service and on this morning it stalled twice before leaving the driveway. It is also very shaky when it is idle. What is wrong with it?
One of vacuum hose is out of the place can cause this problem. That usually happens when a major service performed. Have it towed back to the place where the service perform so it can be corrected. Good luck.
3helpful
Car dies when heater turned on
Assuming your charging system is working properly-You probably have an idle speed control problem. Behind the battery there is an over voltage relay with red top and a 10 amp fuse in it. This relay powers the a.b.s. and the idle speed control unit. Make sure fuse is o,k, and that the relay is not corroded. Next there is 2 micro switches on the throttle linkage(you will have to remove the air cleaner. This switches are tested with an ohm meter and show continuity in one position and open in the other(don't worry if the ohm reading is high).Next to the over voltage relay there is 2 black relays(one fuel pump the other is climate comtrol) The one that says klima is the climate control. Make sure it is not corroded and a lot of times the electrical connector gets bowed and you will lose contact. This relay is really more of a control unit and gives input to the idle and c.i.s. control units as far as the a/c and heater operation. Hopefully I have been helpful
1999 Mercedes e-320 water pump
Good morning;
does this critter have a radiator fill w/cap? I've run accross som large Sotrd trucks that don't.
Well, anyway, it soesn't make sense you would need to fill the radiator via the resenoir. That is only good for short pressure relief and cook down vacuum recovery of coolant. 60/40 is the mix ratio. If it hs a resevoir it should have a radiator cap.The air in system will purge itself as it starts to circulatte cioolant. turn heater off till your system is full, then on when engine reaches operating temp. then if needed top iff coolant. Leave radiator cap off while waiting for coolant to start circulating. When thermostat opens out comes the air. Then put coolant mix in reservoir to fill line. check for leaks and all hose clamps are tight and you should be set, Good luck - Ned
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
