Question about Texas Instruments TI-83 Plus Calculator
I put the equation into y= and then i hit graph. when i do, the screen comes up as ERR: INVALID DIM. help i need to graph!
Dont you have to chose if its quadratic or not? I'mnot 100% sure if thats right my calculator isn't working so i cant check if thats what your doing wrong ir if thats for something else
Posted on Jun 16, 2009
So on my graphing calculator i put my equation x^3-x^2-10x-8. then i hit graph and it says err:invalid DIM.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd then stat plot, and then select 4:PlotsOff. By the way it is easy to graphing function y=x^3-x^2-10x-8.
See captured images: full graph and detail of the left side max
As you can see this function have zero values in the points -2, -1 and 4
Mar 04, 2012 | Texas Instruments TI-84 Plus Silver...
Why do I get an ERR: Invalid Dim 1:Quit Whenever I hit the graph key?
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If this doesn't do it, could you post the exact function you're trying to graph?
Nov 16, 2010 | Texas Instruments TI-83 Plus Calculator
My calculator will not graph the equations i put in under the y= button. it says "ERR:INVALID DIM 1:QUIT"
Oct 25, 2010 | Texas Instruments TI-84 Plus Calculator
Will not graph
Having gone over a month without a response, I assume turning off the stat plot features did the trick.
Apr 14, 2010 | Texas Instruments TI-83 Plus Calculator
I am trying to graph an equation and the following appears when I hit graph: ERR:INVALID DIM 1:Quit Do you know how to fix this? The same error comes up when I try Y=X
Feb 07, 2010 | Texas Instruments TI-83 Plus Calculator
When trying to graph anything, ERR: INVALID DIM appears..
The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-84 Plus Silver...
Cannot graph invalid dim error
This error show up when you are graphing out of the plot menu. If you are not graphing data points from list menu, you need to turn the plots off. In the y= screen, you will see the words plot 1, plot 2, etc across the top of the screen. If one of the plots is highlighted (black box over the words), you need to turn it off. This can be done by arrowing up and highlighting the box and pressing enter. When you arrow back down, the plot should be off and you will be able to enter an equation in the y= lines and graph.
If you are graphing from the plot menu, this error lets you know that one of the lists you are graphing is longer than the other.
Another way to fix the problem is to reset the calculator by pressing 2nd button then plus sign then 7 then 1 then 2. This will reset the calculator however if you are graphing from lists, your data will be erased. Hope this helps.
Oct 02, 2009 | Texas Instruments TI-83 Plus Calculator
ERR: INVALID DIM (That's the error message I receive every time I try to graph an equation)
[2nd][MEM][7:Reset][1:All ram][2:Reset] [ENTER]. Screen shows RAM cleared. Clear the screen and use [Y=] to enter the functions you want to graph.
Hope it helps.
Sep 27, 2009 | Texas Instruments TI-84 Plus Calculator
INVALID DIM error! help me!
Here is what the manual says
INVALID DIM : The dimension of the argument is incompatible with th current operation. (As dimension of a matrix, a list).
You can tell us more about what your were trying to do, we may able to help. Reset memory to default, the error may disappear.
[2nd][MEM][7][2][2] Defaults set.
Hope it helps.
Sep 02, 2009 | Texas Instruments TI-83 Plus Calculator
Graph and trace buttons don't work
This is probably because you have the stat plot on. You would need to go to y= and then go to the top where it says stat plot 1 and un highlight it if it is highligted. That should fix your problem.
Sep 16, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-83 Plus Calculator Logo
273 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
