Question about Black & Decker 4 1/2" Small Angle Grinder
Angle grinder issue
I am using a 4 1/2" diamond blade to cut through 2 " of concrete, but the blade keeps falling off.
  • Dean
    Dean May 11, 2010
    Do you have the securing nut on the correct way? Basically the inner surface of the nut needs to be flat against the blade for it to work correctly and hold the cutting disc in place Usually the nuts are reversible to fit either flat discs or rounded disc heads. It's either that or you do not have the right size bore on the diamond disc for your grinder.
  • 285 Answers
Posted on Jun 20, 2009
Angle grinder
diamond will do it
Aug 16, 2016 | Blade Saws
Hi, I need to cut off a series of 1/4 inch stainless bolts inside a boat. Access is limited. Is a demel up to it? If so, should I use the 1-1/4 inch reinforced fibreglass disk? I do not want to use an...
I got a blister pack of diamond coated disks from Harbor Freight a couple of months ago. They are about 1 inch diameter, and very thin. And they are very cheap. I used one for a couple of bolts and was amazed at how well it worked and how well it held up. You do have to be careful to keep the blade straight. Good luck, Al K
Oct 25, 2010 | Dremel 700 03 Super Accessory 185 Piece...
Angle grinder eats carbon brushes
Yes, the rock dust is what's destroying your brushes and armatures. It gets sucked into the rear vent slots and gets to those parts and eats them away quickly. I don't know of any vacuum systems make by Makita but there are some companies that make them for their systems. Blastrac is one that comes to mind but they can be real expensive systems. I don't know of any grinders with sealed brush/armature systems, they have too much heat to disipate. To make your Makita grinders last longer make sure you are cutting with the side of the blade that directs the dust away from the case and try to have a strong airflow blowing the dust away from the grinder to minimize the dust taken in at the back of the grinder.
Jul 15, 2010 | Makita 9005B 5" Electric Angle Grinder
Breaks support rings in all blades
are you using the proper inner blade flange?? that is the only thing that I can think of that would cause your problem
Jun 12, 2010 | Makita 9553NB 4" Angle Grinder
While using the rz10 tile cutting wheel the saw has no tourque any kind of resistence the wheel stops
The only tile that they are any decent at cutting would be ceramic, slate, or terracotta. Anything else is way too hard and even cutting the listed tile it's no joy to do. I would suggest using a 4 or 4 1/2" grinder with a diamond blade coupled with a wetsaw. hope this helps and good luck.
Mike
Jan 02, 2010 | Bosch RotoZip Spiral Saw RZ10 - 2100
Unable to loosen flange to remove disc on angle grinder
What sort of disc do you have on there at the mo? If its just an abrasive disc the easiest way to remove it is to use a hacksaw to cut the disc sideways so that you are actually sawing it out between the lock nut and rear flange. This will release the pressure on the nut. If it is a diamond blade and you have already snapped a pin spanner then I would suggest securing the blade in a vice and using a set of stiltsons/pipe wrench. While in the vice you could also try using a punch in the pin holes to shock it round a bit, then the pin spanner (and leverage if needed).
Nov 08, 2008 | Black & Decker 9"/230MM 5,000 Rpm Large...
Grinder support
They range in blade composition, number of teeth (cutting bits or surfaces), the amount of set (the width of the kerf removed by the blade), and the blade quality. * One of these circular saws will probably have a plain HSS (high speed steel) saw blade in it when it is bought new. * TCT (tungsten carbide tipped) blades are much more durable, especially in tough hardwoods. Also plywood and composite boards are hard on blades so TCT blades are needed on them. o Blades with fewer teeth (say 28) and with less rake to the face of the teeth, are designed for ripping along the length of timber, with the grain. They typically give a quick rough cut. They are cheap to buy and cheap to sharpen, since they have less teeth. o Blades with more teeth (say 40) are designed for crosscut type work. They give a lot neater cut in most circumstances. * Abrasive blades are made from carborundum or other abrasive materials bonded together in a resin or other synthetic binding material, and are used for cutting concrete or metal. They tend to wear away rather quickly, but for small projects, they are inexpensive and make fast cuts. * Diamond rim blades. These blades are made of special alloy metals with industrial diamonds embedded in the rim (around the outside diameter of the blade), and are for cutting hard concrete, cement composite materials, and masonry products like block or brick. * Special tempered allow blades. These blades have tempered carbon steel teeth, which are very fine (small, and closely spaced) for cutting sheet metal like galvanised roofing metal, or aluminum, copper, or brass tubing. * Dado blades. These are blades which can actually be adjusted to cut different width kerfs (the width of the material removed in the blade path). These blades make it much faster and easier for cutting dados and rabbetts, used for joining lumber. * Trim and panelling blades. These blades have fine teeth for making smooth, accurate cuts on finished materials like mouldings and panelling.
Aug 27, 2008 | Speed CGW ABRASIVES 35606 "24 GRIT" HIGH...
Grinder Usage
grinders are versatile tools that shape, grind, polish, and cut quite a few materials. A grinder can also be used to maintain your other tools that may need sharpening with blades, cutters, or bits.
Aug 27, 2008 | Dewalt DW802G Heavy Duty 4 1/2 Inch High...
Black & Decker 4 1/2" Small Angle Grinder  Logo
246 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Frank Mangiapane
Level 1 Expert
Mike
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
