Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
I have a ryobi CS26 it started and ran for a minute and stalled and won't start back up?
  • 1,040 Answers
First, you will need to check the fuel lines for cracks/breaks.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
(NOTE: If the carburetor parts are more than four years old, and depending on the use, you will need a new carb. kit if the cleaning doesn't work.)
If you need further assistance, just let me know.
Jim
Posted on Jun 18, 2009
  • Jim Parker
    Jim Parker Jun 21, 2009
    Did this solution solve the problem?
    Jim
My ryobi tiller has new gas,started right up.ran for ten minutes,then i hit something and it bogged down, no power and then stalled.restarted gave it gas and did the same thing.any ideas?
Does it have A Filter on it some were ? does it have Bottom Screw in the fuel pump Carb ?Does it have new Plug try this first see what Happens
May 26, 2014 | Ryobi Garden
Runs rough dies
change the fuel filter and check the fuel pressure
May 25, 2013 | Ford Expedition Cars & Trucks
I bought a Ryobi CS26 and used it for about 3 minutes. It seemed to overheat and automatically shut off. I have not been able to start it again since.
Hi, now if i bought something that cost that much and only ran for 3 min, i'd have it back to where i bought it in a hurry. I am assuming that you did have the proper mix of gas and oil, or oil if its 4 stroke.
if its a oil, gas mix and you did'nt put oil in,,,the motor is shot, otherwise, take it back. Not meaning to sound rude here, but thats really all one can say
Sep 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi cs26 won't start
My 39500 will not start. I change the plug and replaced the fuel lins and bubble
Aug 13, 2010 | Ryobi 26CC, 22 In. Hedge Trimmer
How to start a Ryobi Gas trimmer CS26 RY26500B? I
turn switch to on possition press primer bulb 5 to 7 times choke pull rope then turn choke off
Jun 27, 2010 | Garden
My ryobi cs26 will not continue to run after it starts when it is in the RUN position. To keep it running I have to leave the carburetor lever in the START position.
The reason you have to leave it in the start position is it is starving for fuel. Make sure fuel tank and lines are clean.Take a can of carb or choke cleaner and clean the carburetor out its probably gummed up inside. you will probably have to readjust the carburetor when done.
Mar 18, 2010 | Ryobi Garden
Ryobi 720r weedeater. Starts, stalls, won't start.
When you rebuilt the carb did you remove and replace the welch plugs. If you did not, then that is probably where your problem is. Debris, varnish and corrosion can build up under the welch plugs and the unit will not pass fuel.
Sep 06, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I HAVE A MODEL775R RYOBI GAS TRIMMER 31CC IT HAS NO SPARK.
you probably made the mistake of leaving it in the shed over winter with gas in it.
in the carb there is a diaphgram that oumps this fuel in via the motor vibrations.
said diaphgram had been ruptured due to drying gas in the carb. the solver to this is to either have a small engine mechanic replace it or the whole carb or get a new one, and i would suggest you get the cs26 model instead. i have a cs30 and cs26 and i have had less problems with 26. it only has two chokes.
you prime it.
you push lever to start, closing all but a little bit of carb,giving engine much richer mixture.
you squeeze trigger, opens halfway/full, as there are two chokers in the carb, on controlled by lever and another by throttle.basically now you haave half choke.
you release trigger, goes back to 7/8 choke to keep at idle but not running. your ready to go.
on the cs30 its much more complicated:
ful choke
prime 7x.
pull 4x
half choke
pull till start.
wait ten seconds of running at idle rotate to run
good to go. but these guys have porr design. if you take off the back cover and look above fuel tank on cs30, the crank is RIGHT SMACK THERE and not better secured like in the '26 model.
that's what the little circular hole is in it.
anywho, the diaphgram is ruptured, and you probably haven't noticed that in addition you have gas leaking out the carb's air intake.
May 30, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
1,990 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
