Question about Kenmore 22422 Top Load Washer
Clicks when it agitates and does not agitate very well
Kenmore Top Loader 110.82183110. Just replaced belt and cannot remove inner agitator.
  • silverstarav Jun 16, 2009
    More info: Definitely old: 26 yrs and 9 months. I was able to observe the shift pin not always dropping and engaging. If I stop the washer when it is suppose to be agitating, and rotate the agitator then it will drop.
    When I changed the belt I had the washer on its front and oil from the xmission leaked (2 tablespoons??). Would the loss of oil affect the operation of the pin? If so how do I replace the oil? and what type of oil do I use?
    The wig wag soleniods are OK.
    When we had the washer on its front and had the xmission off to change the belt we heard a metal thunk as if something falling. We never did identify it.
    So where is this ball bearing located? Inside the xmission? If so should I buy a new gasket and do I use a gasket sealer?
    Thank you
  • Kenmore Master
  • 8,220 Answers
Look on the wigwag solenoids. their are 4 wires a white common wire on both solenoids and 2 different wires one on each solenoid. Check each solenoid for continuity. now here is the secret. This washer is getting age on it. The solenoids have shift pins mounted on shift levers to change the action from wash to spin. the motor on this model does NOT reverse. It relys on the wigwag assembly to do the shifting. The shift pins get rusty and won't move. Remove the shift pins and sand them down so they will slide easy when the solenoids are energized. if you feel like it is something wrong with the solenoid or the time you cans witch the none white wires and it will spin instead of wash and vice versa. This washer is a good un but an old un. unless it starts leaking i would hang on to it as long as possible. Let me know if you have more questions.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 15, 2009
  • Dan Webster
    Dan Webster Jun 16, 2009
    use GS90 motor cycle oil and like I said sand the shift pins. In the parts look up they called the shift pins forks or something or other. The loss of oil would not but if the small ball bearing that goes beneith the tranny should fall out while you was replacing that belt then she won't act right.
  • Dan Webster
    That ball goes right under the agitator shaft
How to remove agitator separate two parts
Removing the agitator on a Kenmore top loader involves the following steps:
1. Remove the agitator center cap or softener dispenser by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16 inch hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8 inch to ½ inch ratchet adapter to remove.
4. Remove the lower portion of the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make any repairs much easier.
5. Place your hand over the top of the agitator and separate the upper portion (auger) of the agitator from the lower portion and turn the top half over in your hand. The agitator cam assembly will come out in your hand.
6. With the cam assembly in your hand, pay careful attention to how everything is assembled. The cam asembly and associated parts usually wear with age and will cause the agitator to slip. If any of the cam assmebly parts appear worn, now is a good time to replace them. The entire assembly is usually sold as a kit for $20 or less.
7. When reassembling the agitator, carefully align and reinsert the upper portion of the agitator to the lower portion. Make sure the two pieces align correctly. If equipped with an inner cap, make sure it seats and seals properly. This provides an air gap to prevent water from rising in the agitator shaft and getting inside the transmission.
8. Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
If any replacement parts are required, they can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
The agitator cam assembly should be listed under the agitator parts listing. If you have questions, please post back and let me know. I hope you find this information helpful.
Feb 22, 2011 | Kenmore 22622 Top Load Washer
Trying to remove the agitator from a kenmore top loader. took off agitator cap but there is no nut down inside. i see metal but nut drivers and sockets won't fit, down opening. should i just pull up on the...
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 10, 2010 | Kenmore 24972 Top Load Washer
How to remove agitator from kenmore washer
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 20, 2010 | Kenmore 24032\24036 Top Load Washer
Describe your kenmore 90 series washer removing agitator
Jun 14, 2010 | Kenmore 24032\24036 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
Jul 18, 2009 | Kenmore 24032\24036 Top Load Washer
Can't remove lower agitator - Kenmore 110 top loader
Mar 15, 2009 | Kenmore Washing Machines
Kenmore 70 series washer making humming sound and won't agitate
Mar 04, 2009 | Kenmore Washing Machines
Mod 20922 top load washer will not agitate or spin.
Feb 21, 2009 | Kenmore 15944 Top Load Washer
Remove agitator on Kenmore 90 series
ok take the top off the agitator there is a cap carefully remove this cap and then some have a inner cap with a handle remove that also in side the agitator it has a 1/2" or 7/16" head bolt remove the bolt and then pull up really ******* the agitator. to replace dogs you have to break the taps holding them in not the agitator be careful
Jan 10, 2009 | Kenmore 22422 Top Load Washer
Removing Agitator from Kenmore Model 110 Top Loader
How to replace Whirlpool/Kenmore washer
dual action agitator ratchet ‘dogs’, kit # 285770
Tools needed: Screwdriver, 3/8" drive ratchet wrench, 7/16" socket (older models), 3/8" drive to 1/2" adapter (newer models), long 3/8" drive extension, small amt liquid detergent
1) Pry the agitator cap off by inserting a screwdriver into the cap’s notch
2) Pull the inner cap (if present) off – most Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator
(Earlier models used a 7/16" hex-head steel bolt)
(Recent models use a 1/2" square drive plastic nut – use a 3/8" X 1/2" ratchet adapter)
4) On older models, grasp the bottom portion of the agitator and pull the entire ***’y off.
(Recent models allow just the top portion’s removal to access these ‘dogs’)
5) Older models – place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once the ratchet ***’y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All‘4-dog’versions use the 285770 kit, regardless of the cam ***’y style. (Older agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***’y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***’y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap’s rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap’s o-ring too – makes it easier to snap into place)
9) Reach around and pat yourself on the back! You just saved at least $75.00!
Dec 31, 2008 | Kenmore Washing Machines
Kenmore 22422 Top Load Washer Logo
157 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
