Question about KLH ASW10-120 Subwoofer
Burns [blows out the 50v bridge rect] on power up. cant find the short??? all conds and resistors seem to check out OK ??? The four Z-diodes seem ok also ??? All transistors seem ok [no low ohms-only normal 15 & infinity indicated]
  • 547 Answers
I'd suspect the 6800uF caps, but I don't know for sure.
If it helps, here are the schematics for the upper and lower boards:
Upper board
Lower board
I wrote to KLH to ask for them, and explicitly asked for permission to post them here.
Posted on Jun 16, 2009
Brand new Midland 5001z blows fuses immediately after its turned on. I tried the power cord on Cobra 25 that has the identical plug configuration and its Ok. I don't have the receipt as I got it a
bad final also check for any burned resistors in the area. If the final caused the resistor to burn the just replacing the resistor it would burn the new one also.
Feb 05, 2012 | Midland 5001 40-Channels Base CB Radio
Soundcraft GIGRAC 600 pre-amp power supply keep blowing the low valve resistor 1ohm. they are the resistor just before the bridge rectifier, for the low voltage feed. Once resistors replaced the unit...
The resistor is acting as a fuse and will continue to blow until you fix the REAL problem. LIKELY the filter capacitor(s) beyond the bridge rectifier are failing. One needs to use test equipment to measure the current through the resistor and see if it is reasonable. The capacitors can heal briefly and then start to short. One should also check the rectifier in operation with an oscilloscope as one diode could intermittently short.
May 04, 2011 | Soundcraft Gigrac 600 Powered Mixer
Keeps on blowing fuse
Hello
If fuse blows off repetedly, it shows that there is a direct short inside the power supply section. You just check the mains rectifier diodes for short. iIf a rectifier stack is used desolder it out and check for short. In some sansui sets, ther is a metal oxide variste connected across the supply line inside directly. It is for line spike suppression and an overvoltage protection. If any of the above appears on the power line, the varistor will get shorted, and the fuse will go out, to prevent further damage to the circuits. Check that varistor for short. Check the resistance across main filter capacitor for any direct short. If it seems shorted, check the switching transistor for collectror to emitter leak, Resolder it out and check. These are the main reasons for blowing fuse. If the switching transistor has got leaked, you must check the entire SMPS control section, especially in case of used zener diodes, before replaceing a new transistor. OK.
If you wants anu further assistance, inform me through Fixya. Ok.
Nov 05, 2010 | SansuiS2746 TV
One (right) preamp blow! I've located the problem to the right C160 module. When disconnected everything seems fine. Diodes and transistors are apparantly ok measured onboard as are all resistors and...
hi...
transistors are not ok on the C160 module.
replace all the power transistors and emitter resistors for that channel.
www.bdent.com and www.ceitron.com are good for transistors
Sep 30, 2010 | NAD C370 2-Channel Amplifier
Ac power Symphonic sc309D blows fuse- Dc power ok
The most likely problem is a shorted diode, I suggest replacing them even if they do not test shorted while not under load. If it is not the diode rectifiers, there is probably a resister in the power supply that is shorted, remember also that it can also be both. Lastly, it can be a capacitor within the power supply.
I Wish You Well
Dec 03, 2008 | Symphonic SC309D 9 in. TV/VCR Combo
Power supply shorted out and there is only a 30 day in-store warranty . they told me to contact you directly. it shorted out our console also but we got microsoft to send us a new one.
any reason to void warranty if you opened it warranty is void ok check ac volt at power cord then open power supply check fuse if burned replace it if again blows then check bridge rectifier diodes
if faulty replace it
Oct 16, 2008 | Intel (ATX350P4) 350-Watt Power Supply
Pyramid 14G power supply
Hi.
It very unlikely the voltage went down. I think you should re measure what the voltage should be yes it 13 volt is after the bridge you wil get this with dual 6.5 volt ac from the transformer, they don't change voltage unless you have a short at the output, and if you did you will blow the transformer, is your reading from 2 wires or is it three wires, output, the center to the end should be 6.5 and end to end maybe 13.8.
I would need to see the schematic to know what voltage you should be getting.
I wouldn't look on a bat transformer but ether, bad bridge or wireing.
I hope this help's
What About Bob
Feb 10, 2008 | Audio Players & Recorders
Fuse blows when it gets plugged in
No it doesn't sound like a resistor, it sounds like you have a short in power supply, you can look for bad Diodes in bridge rectifier,or solder bridge, or transistor short, start from beginning to end. It is definately a short and most of the time resistors open and this will not cause a blow just a dead set.
Sep 21, 2007 | Emerson EWF2703 27" TV
Shorts
Could it be in the HV circuit? first you isolate h/output section from power supply. make power supply output ok. check h/output section for short circuit 1 print short near eht 2 diodes or cap.near eht 3 yoke H winding just by removing connector 4 EHT transformer regards
Sep 12, 2007 | GE 25GT270 TV
KLH ASW10-120 Subwoofer Logo
220 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
woodzowl307
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
