Question about Kodak Easyshare M893 Digital Camera
I turn on my m893, it turned on and then immediately turns off
I thought it was not charged so i have tried to charge it twice, but it does not help.
    Problem Solver:
  • 7 Answers
The cameras do that only when there isn't sufficient power to run the camera, your battery needs to be replaced, or if your charging it, the charger or the battery may have gone bad.
Posted on Jun 28, 2009
Xperia u dont turn on just red led blinking after charge up
I experienced the very same problem twice.
The red led would either stayed on all the time when charger was connected or it blink whenever I'd push the power button on the phone, but the phone would not turn on.
My solution was to unplug the charger, take out the battery and the sim, keep them separated for at least 48-72 hours, then put back the battery, connect the charger again (don't use your computer's usb port, use a real wall charger, preferably the original one), turn on the phone.
If it doesn't turn on immediately, let it charge for a few hours and then try to turn it on.
I revived this phone twice using this method, first time I thought I was just lucky, but apparently it's reproducible.
Hope it works for you too.
Apr 04, 2013 | Sony Ericsson Xperia U Black Rubber Gel...
My camera is not working. my camera does not turn on and when it does it turns off
Welcome to FixYa.
For camera's that won't turn on or will turn on but automatically turn off. First thing you need to check if the battery was fully charged.
Second, check if the battery was placed in right direction.
If those two solution was done, You need to removed the battery and re-insert it again.
Also try to install new fully charged battery.
If this issue will continue you need to contact your service center because this might have a camera malfunction.
Feel free to send us your comments or suggestion if this solution was helful.
Thank you for using FixYa.
Apr 07, 2011 | Kodak Easyshare M893 Digital Camera
My Kodak will not turn on...it's been charging for a while now and when i turn it on all it does is turn on for about a second and then turn off..what could i do to fix it?
1/ Make sure your battery is still good (holds charge). If it does hold charge, 2/ then turn the camera on by pressing the play button. If it turns on, your camera's lens is faulty
Aug 17, 2010 | Kodak Easyshare M893 Digital Camera
I was using my Koday M893 one day, and i sat it down for a second, when i picked it back up the screen was blank, and the lens is still out. The camera will not turn back on, and i feel like i have tried...
What exactly did you try?
Check these:
  • Fully charged batteries
  • Taking batteries our from the camera and reinserting
  • Other set of batteries
If you did try all of the above without success, the only thing you could do is take the camera to a local electronist, or Kodak dealer for repairs.
Apr 09, 2010 | Kodak Easyshare M893 Digital Camera
My kodak M893 IS 8.1 will turn on then off right away.
Your battery might be faulty or your battery contacts in need of cleaning. 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 24, 2010 | Kodak Easyshare M893 Digital Camera
HAVE A KODAK 8.1 MODEL M893 CHARGE IT WHEB YOU TURN ON IT'S ON YOU GO TO TAKE PICTURE IT SHUTS OFF
Are you suing the recommended battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001? If no please purchase KLIC7001
Now in case you are using this KLIC7001, How do you charged the camera or battery? USB cable or AC adaptor? If your using USB cable actually some of the M893 will not charged using USB cable you need to update the firmware or download the firmware before you can successfully charge it using the USB cable
Now if the AC adaptor make sure when you plug the adaptor theres a light indicator on the camera and charged the battery for 4hrs., and still the camera will shuts off everytime you take a picture please call kodak toll free 1 800 235 6325 have your camera repair. Gudluck!
Nov 05, 2009 | Cameras
Camera turns on then off immediately
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
MY M893 CAMERA WILL NOT POWER ON...IT DOES NOT SEEM TO HOLD A CHARGE....THE CHARGE LIGHT BCOMES ON FOR BA FEW SECONDS...AND THEN SHUTS OFF....HELP!! CAMERAB IS NOT A YEAR OLD....
Try to clean the battery metal contacts try to turn on the camera
If it did not work do the following:
Try to insert battery the other way around.
Try to charge the camera 4-8hrs
If it didn't work follow the guide on www.kodak.com/go/stepbystep
If the guide did not resolve the issue proceed with warranty repair process on the website. You can process the warranty repair by yourself.
After accomplishing the warranty repair process you will receive email from Kodak giving you instructions how to send your camera for service.
Lester
Kodak Technical Support
Oct 04, 2009 | Kodak Easyshare M893 Digital Camera
Camera turns off immediately after being turned on. thought it was the battery, bought new one charged it and even though it says full charge, the camera still wont stay on.
This fault is usually caused by a lens problem.
Over 95 percent of lens problems are from Knock damaged or sand/grit in mechanism. Try turn it on in playback mode and see, does the lens come out and go back in before it turns off?
Cheers.
Sep 30, 2009 | Cameras
Will Not charge
It happens, one of the cell in the battery went bad.
Try new battery.
Mar 19, 2009 | Kodak Easyshare M893 Digital Camera
Kodak Easyshare M893 Digital Camera Logo
302 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
