Question about Homelite Mighty Lite Lawn Trimmer
What do i lubricate the flexible cable, inside the shaft of the line trimmer, with ?
  • 3 Answers
I use a black molybdenum disulfide grease to lubricate the flex shafts. I remove the shaft, wipe off all of the old grease, apply a new coat of grease, and reverse the direction of the shaft when re-installing (top becomes bottom, bottom becomes top) to more evenly distribute the wear on the flex shaft.
Posted on Jun 03, 2012
  • 284 Answers
White lithium grease works well
get it in a spray can and spray it in the tube where the flex shaft goes and then coat the flex shaft and reinstall
Posted on Jun 15, 2009
Talon 25cc line trimmer. Sounds like drive shaft is rubbing on inside of aluminium shaft. Is there a bearing or bush missing? Quite loose down at trimmer head..
inside the tube ( shaft ) there are a number of rubber bushes(guides) that hold the cable ( bent shaft or late straight shaft) or the steel drive line ( straight shafts )
These rubber bushes can move out of place and that will allow the cable to hit the shaft especially on bent shaft units
They can wear out but I am not sure if replacements are available ( check mower shops for that)
Jan 30, 2018 | Garden
Stihl fs 55r head won't turn
Check drive shaft. Some models have a flexible cable drive shaft that is prone to breaking. also make sure the drive shaft is engaged in the clutch drum and in the gear head end.
Mar 25, 2013 | Stihl Garden
Internal metal cable from flexible shaft is broken 54-4770-4
hello,,There are only three things to cause trimmer head not to turn.
1.Outer shaft has sliped down from engine because screw has fallen out and ring has come loose,
2.Shaft has broken due to excess stress,such as putting on a differant trimmer head or binding up,
3.Trimmer head striped.
hope this helps,any comments welcome,thank you.
Jan 23, 2012 | Garden
How to replace flexible drive shaft on Poulan Twist n Edge, TE 450 CXL LE string trimmer. I have removed the lower string assembly - can't remove shaft.
Shaft needs to come out the top, will have to split the case or remove motor from shaft to pull cable out
Aug 29, 2011 | Poulan Garden
I have a Talon electric line trimmer AT2307A. When I press the start button, the bottom attachment with the nylon line does not spin even though the motor is running.
Halfway down the shaft of the line trimmer, you can detach the line trimmer attachment ( this in so you can fit a lawn edger attachment if need be). Unclip the line trimmer at that halfway point and the start the motor and see if that rod inside the shaft is spining, if so, reattach the line trimmer attachment and see if the nylon line spins, if so, it wasnt attached correctly, if not, then there a break in the flexible rod going to the trimmer head, most likely at the bend.
Dec 29, 2010 | Garden
The flexible shaft on my Ryobi EL15 trimmer shifts
Check the outer tube has not moved forward out of its housing at the engine end as this would make the inner too short.
Mar 04, 2018 | Ryobi 15" Electric Factory Reconditioned...
I strip the cable inside my lawn trimmer it would turn my cutter below. Is this something I can repair or must I take it to shop?
Hi and welcome to FixYa. I am Kelly. When you say you stripped the cable I am assuming that your talking about the flexible drive shaft. This can be replaced at home. However,.... ou did not state if this was a gas or electric model. At the moment I am assuming it is a 25cc Gas trimmer. To replace the flexible drive shaft the motor will have to be unmounted from the drive shaft housing. It will have 4 flat sides on each end that must mate correctly into the slots of the motor and the power head or you will not be able to re-mount the engine.
With a good model number I can provide you with a source of the replacment parts and probably what mounting hardware that has to be removed to change the fl;exible drive shaft.
Thanks for using FixYa.
Kelly
Jun 15, 2010 | Ryobi 15" Electric Factory Reconditioned...
Our B&D electric trimmer is now noise maker
Yes you should be able to repair it. Is it a flex or shaft drive? If it'a a shaft, it is the coupler at the motor. If it is a flexible drive the cable may be broken. B&D is is seldom worth repairing. The majority of lawnmower shops won't repair them because of cost.You can try, but you need the owners paperwork to order the right parts. Good luck and at the least, tear it down and see what failed. Start at the string end.. Good luck and make sure it's not plugged in. - Ned -
May 28, 2010 | Black & Decker 14" Grass Hog Xp...
Ryobi 700r how do you replace flexible drive shaft. Boom and trimmer get very hot after the trimmer runs for a while. I think the flexible drive shaft needs to be lubricated. I can not figure out how to...
it comes out but you have to lossen the screws holding the engine on at the base and pull it out? the other end has a locking nut remove the spool and loosen
Aug 27, 2009 | Garden
Replace a flexible curved shaft
If you go to www.homelite.comin the red area up top click on order parts then click - click to launch homelite parts catalog, then scroll down thru agreement and click agree and then you will need to know your model number and you can get a breakdown of your trimmer wich will give you a good idea of how your machine is put together.
Dec 16, 2008 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
332 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
