Question about HP PhotoSmart C4280 Laser Printer
Doesn't scan. Only print and copy. Say's no USB
I have the USB hooked up. Everything else works. No scanning though. What's up?
    President:
  • HP Master
  • 1,996 Answers
Did you install it properly, and wait until prompted to connect the usb cable? See here.
See links to scanning functions for your printer here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 15, 2009
    Sergeant:
  • 222 Answers
Usually the scanner and printer have separate drivers, even though both are included in one machine.
Check HP's website to see if there's a separate driver for the scanner or a program which installs both drivers from the same setup program. You might have to check device manager to see if a scanner is listed and if the driver is properly installed.
In XP and VISTA, go to control panel/device manager and see if there are any yellow caution signs by the 'imaging device' icon. If there is no 'imaging device' icon, either the driver is not installed or not installed properly.
One additional factor... HP usually requires that the driver be installed before the hardware is connected. After drivers are installed, New Hardware Wizard should find your HP devices and install them properly. If not, you might want to unistall them altogether and reinstall.
Hope this helps.
Microtek Scanner thinks it's busy when it isn't
Check using a new USB cable. Unplug everything else plug into USB except for mouse and keyboard. If not work. Un-install driver and software. Download driver and latest software. Reinstall printer using driver only. Then use Paint to test it.
May 05, 2017 | Microtek MRS-1200X6U ScanMaker X6 Flatbed...
I just bought a apple macbook pro and would like to use my printer over the network rather then having to connect usb every time i want to print. how do i do this i have a big pond wireless modem its the...
you can buy a print server to connect to your printer to the network. however could you please list the printer type you have? some printers do not work over the network with a print server on mac.
the printer will still function as long as you got a phone line to it for faxes however some features like scanning will not work over the network.
Mar 07, 2011 | Computers & Internet
I've connected my IR1023iF to the network. The printer and fax work fine but the scanner doesn't work at all.
If you've hooked up the copier via ethernet cable then it needs to be setup for scan to email, FTP or scan to folder (smb). This can be done through the copiers web interface which is accessed by typing the copiers IP Address into your web browser. If you've hooked the copier up via USB, then there is 'toolbar' software that you would use for scanning. If you need the software, let me know and I can post it on an FTP site. Just an fyi...I'm pretty sure that you can't hook up both ethernet and USB at the same time.
Nov 11, 2009 | Canon imageRUNNER 1023iF Black and White...
We use Abby 8.0 finereader with kofax VRS. We can not gt the scanner or Abby to reconize the VRS with the scanner hooked up. Everything works fine with another scanner.
Use CapturePerfect ver 2.0 downloadable free. Ver 3.0 is priced. http://software.canon-europe.com/software/0022439.asp?model= though this is under Canon 5020, it works with 9080C.
Have you loaded Device drivers, if not download from http://software.canon-europe.com/products/0010035.asp
Once the driver is loaded you can even use Microsoft Imaging to scan. CapturePerfect is easy and brings out the added features of Canon 9080C.
S. Mohan, Chenai, India
Aug 12, 2009 | Canon DR-9080C Path-Through Scanner
MFC425CN will not scan through network
In my experience with printer all in ones they never scan over the network. So your best bet it to just hook the printer to a pc scan it and then you can share it on the network.
Jul 24, 2009 | Brother Network Ready All-In-One InkJet...
How do i hook up my ps3 controller? It's not working!
probably battery is low, try connecting the controller to the usb port for an hour and press the home button and it should connect.
Jun 09, 2009 | Sony Playstation 3 (PS3) Console
Scx-4521 imaging device driver, scaner
Try changing your usb printer cable with a different brand. I have had lost of machine not wanting to scan because of faulty usb cables, even though you can print it refuses to scan. If this still is not helpful, try downloading the latest drivers from samsungs website.
Mar 21, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Problem scanning
Uninstall software and re-install with usb cable unplugged. It will instruct you in the installation when to hook it back up.
Jan 07, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Canoscan 4200f Problem with Vista 32 bit
I got mine working after experiencing the same problem.
I had mine hooked up to a USB hub, after I hooked it directly to the USB ports in the back of my computer, everything just worked fine.
Weird that it worked on the USB hub on XP and not vista though.
Dec 31, 2007 | Canon CanoScan 4200F Flatbed Scanner
HP PhotoSmart C4280 Laser Printer Logo
185 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
