Question about Kenmore Washing Machines
Washer will not spin. everything else works. have check reset switch and the spin switch and the switch is good. Could the selenoid not let it engage.
  • 15,935 Answers
It appears your lid switch/door latch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Whirlpool AWM 312 front loading washing machine motor does not spin.
Hi Sachinl, Before you check out the link below read how To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components.(This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
If that did not solve the problem then it may be the "Lid Switch". Top loading washing machines that have a faulty lid switch will not turn the agitator and the spin cycle will not start. However on some washing machine models it will still agitate but not spin. To properly check this you must remove the lid switch.
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 03, 2016 | Whirlpool Washing Machines
1979 sportster - selenoid has 3 wires, 1 batter +, 1 starter, 1 starter button, other side of starter button goes to power, hit starter button motor turns over, release starter button, starter keeps...
Or the big washer in solenoid is burnt & sticking take apart sand big copper washer & part it touches reassemble .. you may also ask this ? at harleytalking.com they have helped me...
Apr 21, 2011 | 1979 Harley Davidson XLH 1000 Sportster
2 problems
Sounds like the selenoid valves are backwards. Or the water hooked up backwards. Or actually like the cold water one isnt working at all. Either the selenoid or the screen stopped up. Even on cold water i noticed that some washers use warm. But all of them uses cold water to rinse. At least the last rinse. So when it uses cold water there isnt any. First of all, Switch the two wires with each other and wash on hot and see if cold works then. If not Take the selenoid out and apart then clean the diaphram real good with soap and water then pup back together.
May 31, 2010 | Maytag MTW5600TQ Top Load Washer
GE WHDRR418 top load washer won't spin at high speed; the washer does the complete cycle, and agitates in both directions and does physically spin, but it will not go into the 'high speed' spin that...
we can eliminate the motor and the switch since that part is working. sound like your timer might be faulty, timer make everything work in persistence cycles, if its goes bad sometime it tend to jump/skip cycles.
Jul 21, 2009 | GE WSXH208A Front Load Washer
Washer does not "click" to drain and spin cycle
Hi, Check the lid switch. Most models will not drain or spin when the lid switch is bad.
If I can get the model#, I wil try and asist you further.
Vic
Jun 21, 2009 | GE Spacemaker Washer and Dryer Electric...
Operates correctly on all wash,rinse,soak cycles but does no spin
Check the door switch, if it's faulty the spin cycle will not work, but everything else will.
Apr 02, 2009 | Asko W6021 Front Load Washer
Will agitate but won't spin
You could have a bad door switch, always make sure your appliance is disconnected from it's power source before performing work on it, if the door switch is defective your washer will do everything but spin in the spin cycle, it's usually located at the door latch, when the door is closed it pushes the door switch in, you can check it by removing the switch and doing a continuity test on it with the switch in the closed position, or it could be a broken drive belt, some washers use two belts instead of one, check to see if your washer has more than one belt, there are other things it could be that are more complicated such as a bad transmission, bearings, motor, or clutch. which could involve calling a repair man.
Mar 16, 2009 | Maytag PAV2300 Top Load Washer
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Whirlpool washer LSQ9659LW0 will not spin.
If the washer will agitate and drain but will not spin you either have a bad gearcase or the nylon finger that engages the brake is bad. you need to remove the gearcase and check the brake assembly and if that is good replace the gearcase
Jul 25, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
19 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
