Question about Cavalry Storage Cavalry CADB001U32 1TB 7200RPM USB 2.0 3.5-Inch External Hard Disk Drive 500 GB Hard Drive
Calvary 1TB USB 2Bay external hard drive problem
I bought this and used it for months with no problems. Now, no matter what computer USB access I used (I have tried several from computers we own) it does not show up under My Computer to be accessed. It is running, the fan is blowing and the light is blue. Anyone have any idea what to do. I have data on this that I need to get to. Thanks.
BullDogg
  • 57 Answers
The problem could be the enclosure, not the drive.
I would take the drive out of the Calvary enclosure and install it in another one. Hopefully it will come up and you can access your data.
Posted on Jun 16, 2009
I just bought a mp3 player the make is IQ sound it has 4GB, it came with USB cable, and software, I'm not understanding several things about this ,for the users manual the print is so small it's...
Many MP3 players will not go to the menu when connected to the computer. You have to access them from the media player. It should not matter if you plug the MP3 into the USB ports on the front or back of your computer.
What kind of problem are you having with loading tracks from your media player? What media player are you using?
Mar 30, 2011 | Computers & Internet
My computer will not power on, only a flashing green light on the back is on. I just bought a new computer and would like to transfer my files to my new computer. Why my old computer will not power on?...
Hi and welcome cj4man1 !
Extract the Hdd out of your old computer . Place it in a external usb box and connect the box to your new pc . You will be able to access and transfer your data .
The issue about your old computer is another matter an could have several reasons , such as power supply , damaged Hdd , defective memory , damaged motherboard ...etc ...
best regards ,
fanaudi .
Feb 20, 2011 | HP Pavilion a450n PC Desktop
When i connect the USB of my 500 GB passport WD it takes a long time to be identified by the windows, after this when i double click to open, it takes a long time to respond and nothing happens, sometimes...
Try using a different USB cable. Try a different USB port of that computer. If you have another computer, try using it with this hard drive.
It kinda sounds like it may be that USB hard drive too, getting flaky (going bad).
Trying different cable, USB port and another computer should help aid in debugging this. If it works with different items (cable, different USB port or computer) then you know it's your computer causing issues or it's operating system. If it's all the same outcome with different items tried then it's the hard drive causing issues. Not much to do but get another drive.
It should not matter if your computer's BIOS is set up for USB 1 or 2 support. The drive should still be seen with all files/folders in it, without slowdown or issues you've described.
Dec 04, 2010 | Western Digital Passport WDXML800UE...
Hello, my name is Thomas, im not quite sure that matters but, i bought a new WD hard drive about 4 months ago, after i bought a 160 GB hard drive a few years back. I'm very pleased with WD hard drives and...
Externals can be a pain. Mainly because of their casings that can cause failures to happen for no apparent reason. If your warranty will be expired and/or the drive is not showing in "Computer Management - Disk Management" I would suggest removing the casing from the external and plugging the hard drive you've extracted from the case into a desktop.
If the drive is still not recognized after being installed into a desktop I would look into data recovery. My personal favorite data recovery software is Knoppix which is an OS(linux) booted from disk.
Sep 26, 2010 | Western Digital My Book Essential Edition...
I bought a WD5000BEV harddrive in december 2009 and within 6 months it has started giving me problems. Sometimes the computer recognises it and some times it does not. Even thought it appears on the...
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 16, 2010 | Western Digital External USB 2.0 80 GB...
Dell Inspirion 530 won't communicate with Dell V305 printer
The problem could be because of ONE out of FIVE problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Jun 26, 2009 | Dell V305w All-In-One R840635AU InkJet...
Sandisk Cruzer no longer prompting for password
I think the problem is corrosion on the contacts. Shut the computer off. Gently insert and remove the USB drive several times to try and clean the contacts. Turn the computer ON and when Windows has set up properly, insert the USB drive and see if you can read it. Many of the new drives and reader ports do not use gold contacts (too expensive) but use copper or aluminium which corrode easier an easiest.
Jun 10, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Can not get pictures from camera to a computer folder
Hello and welcome to FixYa
Please go to a electronics store and buy a USB card reader. I bought one last week and it cost $0.5 so its cheap as dirt. Then simply remove the card from your camera , pop it into the reader and the pictures will appear on a drive like a flashdrive in your my computer folder.
This is a much better option than using the camera's cable as it is faster , safer , saves on your camera battery and you don't need to install any software or drivers.
The card reader will most likely also still be compatible with any new camera you buy in future.
Kind Regards
Andrea
Apr 01, 2009 | Fuji FinePix 2800 Zoom Digital Camera
New WD external drive not showing up in my computer
I just had this problem, go to Computer Management/Disk Management, and assign a drive letter to it, for some reason it doesn't automatically.
Jul 16, 2008 | Western Digital My Book Premium ES...
Computer will not recognize keychain
I'm not too sure from your question what your problem is. Do you mean a USB flash drive/key? Most modern ones don't even require driver installation. Neither do they have a button on, so I must be off point. Without more specific information, the only thing I can suggest is to connect the key directly to a USB port on your computer, and not via a USB hub if you're using one. Sometimes computers can take up to a minute to recognise the drive, after which time to can access by clicking on My Computer.
Jan 07, 2008 | Lexar FireFly 2GB USB 2.0 JumpDrive
Cavalry Storage Cavalry CADB001U32 1TB 7200RPM USB 2.0 3.5-Inch External Hard Disk Drive 500 GB Hard Drive Logo
711 people viewed this question
Top Cavalry Storage Computers & Internet Experts
Arora Singh
Arora Singh
gary433
Glenn Smart
Glenn Smart
Are you a Cavalry Storage Computer and Internet Expert? Answer questions, earn points and help others
