At start-up, a window appears containing the following text: Asus A7V8X Press[tab] to show POST screen; press [Alt]=F2 to enter EZ Flash utility then the computer does not respond to the keyboard: the mouse pointer does not appear, and the only way to get out is by brutally switching teh computer off. If I try to switch on again, the same situation repeats, until, after several attempts, perhaps a few hours later, the computer starts normally. I hesitate to try showing the POST screen or enter the EZ flash utility, because I do not know what they are. Any suggestion?
  • gianni_gelat Jun 21, 2009
    I haven't tried it yet (the PC in question is about 500 miles from here and I cannot put hands on it for at least a month), but your suggestions do make sense, and I am confident I will be able to locate and eliminate the source of trouble.
    Thank you
    G.Gelato
    President:
  • 948 Answers
The message you are getting is normal, and a similar message shows on every computer as it is booting. Some computers have this message hidden by a splash screen, often a company logo. After this message, the computer SHOULD hand off the boot process to your boot device. Usually this will be your hard drive and your computer will load the operating system and finish booting. In your situation I would try disconnecting the hard drive (computer off of course), then try rebooting. If you see the window with the same message, followed by an error message about no operating system or no boot device then you know your hard drive is bad and replacing it (reinstalling your operating system and all other files) will fix your computer.
If you disconnect the hard drive and still get no message then your motherboard is not functioning properly, not even getting to the point where it is handing off to the boot device. In that case I would try reseating your memory and video card and if that does not work you'll probably have to replace the motherboard.
Posted on Jun 15, 2009
My satellite Toshiba L875D-s7230 says bootmgr is missing press ctrl alt and delete to restart and does nothing
Which operating you are using?
Method 1: Run Startup Repair from Windows Recovery Environment (WinRE) To run Startup Repair from the Windows Recovery Environment (WinRE), follow these steps:
  1. Insert the Windows installation disc into the disc drive, and then start the computer.
  2. Press a key when the messagePress any key to boot from CD or DVDappears.
    If your PC does not detect the media automatically
    1. During the restart process, read the screen for any instructions that explain how to interrupt normal startup and enter the basic input/output system (BIOS) setup utility. Most PCs use the F2, F10, ESC, or DEL key to begin the BIOS Setup.
    2. Look for a tab in the BIOS Setup Utility that is labeledBoot Order,Boot Options, orBoot. Following the directions on the screen, use the arrow keys to go to theBoot Order, then press Enter.
    3. Locate the CD, DVD, or USB flash drive (this might be called Removable Device) in the Boot list. Following the directions on the screen, use the arrow keys to move the drive up so that it appears first in the Boot list. Press Enter. The boot order sequence is now changed to boot from the CD, DVD, or USB flash drive.
    4. Press F10 to save your changes and to exit the BIOS Setup Utility. SelectYes in the confirmation window. The PC will restart.
  3. Select a language, a time and a currency, a keyboard or input method, and then clickNext.
  4. ClickRepair your computer.
  5. In theSystem Recovery Optionsdialog box, select the drive of your Windows installation, and then clickNext.
  6. At theSystem Recovery Optionsdialog box, clickRepair your computer.
  7. Click the operating system that you want to repair, and then clickNext.
  8. In theSystem Recovery Optionsdialog box, clickStartup Repair.
Method 2: Rebuild the boot configuration data (BCD) from Windows Recovery Environment (WinRE)
  1. Put the Windows installation disc in the disc drive, and then start the computer.
    4. Press F10 to save your changes and to exit the BIOS Setup Utility. SelectYesin the confirmation window. The PC will restart. Allow the PC to restart normally. The scan will take a few minutes and remove any malware that may be infecting your computer.
  3. Select a language, a time, a currency, a keyboard or another input method, and then clickNext.
  5. Click the operating system that you want to repair, and then clickNext.
  6. In theSystem Recovery Optionsdialog box, clickCommand Prompt.
  7. TypeBootrec /RebuildBcd, and then pressENTER.
Jan 20, 2017 | Toshiba Computers & Internet
How do I turn on my wifi switch on my Asus F555l
Usually hold the [ fn ] key and the [ f2 ] together or just the [ f2 ] key depending on how your "Hotkeys" are setup. If you've had a fresh install of windows or the drivers aren't working properly you can do it manually by going into the bios like so:
Step 1
Turn on your Asus Netbook. If your netbook is already on, click the "Start" button, click the arrow next to the "Shut Down" button and then click "Restart."
Step 2
Wait for the Asus Netbook BIOS screen to appear, then press the "F2" key.
Step 3
Press the "Right" arrow to scroll over to the "Advanced" tab.
Step 4
Press the "Down" arrow until you reach the "Onboard Devices Configuration" option. Press the "Enter" key.
Step 5
Press the "Down" arrow to "Onboard WLAN" then press the "Enter" key.
Step 6
If the "Disabled" option is highlighted, press the "Up" arrow to highlight the "Enabled" option, then press the "Enter" key.
Step 7
Press the "F10" key. Press the "Enter" key to save your changes and exit the BIOS. Note: If you are missing your hotkey drivers you can find them here under the ATK section (Use the latest version) http://support.asus.com/download.aspx?SLanguage=en&p=3&s=670&m=F555LA&os=&hashedid=n%2fa
Feb 26, 2015 | ASUS Computers & Internet
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
Asus Eee PC 1005HA wontl load OS
what key do you see during the boot up process
you should see a certain key it will be very quick you might have to restart a few times to get a good look
try pressing the delete key
hope it helps
Apr 09, 2012 | ASUS Eee PC 1000HE Netbook
Computer does not start up
Please reset the system... Disconnect the power adaptor. Remove your battery, press several times on the Power button of the Laptop without the battery and power.. and let me know.
Jun 06, 2010 | ASUS Eee PC 1000HE Netbook
I was told press F2 simultaneously on startup, nothing happened
You need not to press F2 or tab or escape unless you need to do so. If your system is ok, it'll automatically boot up, but if there's boot up problem with your system, then that's different. Thanks for using FixYa.
BIOS POST message cannot be displayed and Setup does not run
As soon as your computer turns on, start pressing F2 simultaneously until it enter the CMOS setup.
A7V400-MX will not boot
In such cases its practical to change the SMPS with a working power supply of the same rating and then trying it out. If with the new power supply it works fine then cange your SMPS. Also make sure that all cables are snug tight and generally ree from dust. The same applies to your RAM too................sodeep
Apr 18, 2009 | ASUS A7V400-MX Motherboard
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
BIOS 1004 cpu not support
I got it :-)
Damn Asus , it was a hard session ;-)
1. Make an ISO from your original Asus CD denn insert (with isobuster or something) the Bios Firmware 1004 in the main Dir name the file M2N-MX.ROM
2.Burn a Second disc with the 0804 Bios ROM also rename the 0804 Rom to M2N-MX.ROM
3. Go to EZ FLASH with ALT + F2 and then insert the 1004 CD wait till Erasing is ready Then Turn OFF your PC :-) so you crashed the bios thats what you need to run the embeded CrashFRee Tool
4 After you turn your PC on insert the 0804 CD then it flashes the this Rom and we are Happy :-)
mfg Eddi Hope this helps someone
Apr 16, 2008 | ASUS M2N-MX Motherboard
Computers & Internet Logo
152 people viewed this question
Alun Cox
David Payne
David Payne
