Question about Bionaire BAP1175-U Air Purifier
Bionaire filter replacement- reset indicator
Where can I find a product manual for bionaire 1175 air
cleaner? I particularly want to find how to reset the
filter life remaining display after the filters are replaced
  • 2 more comments
  • harbourman Oct 31, 2007
    This problem has been solved. Harbourman has found
    someone with a product manual for the Bionaire 1175
    air cleaner.
    It states:
    Reset the Filter
    Monitor after changing the HEPA filters by
    simultaneously
    pressing the power and sleep buttons on
    the control panel.
    Hope this helps someone else, too!
    Harbourman
    Reset the Filter Monitor after changing the HEPA filters by
    simultaneously pressing the power and sleep buttons on
    the control panel.
    Harbourman
  • Anonymous Jul 10, 2008
    Worked for me, and without unplugging it. Thanks!
  • RitaMarchand-You Jul 31, 2013
    Worked for me too. Thanks
  • Greg Arbo Nov 28, 2013
    BAP-1700 has a pin hole under the check filter light. Push in pin and it resets in approx. 6-8 seconds.
It worked - the solution to press sleep and the power button simultaeneously worked! Air cleaner then reset to 99%. Thank you Harbourman!
Posted on Apr 25, 2010
I think that this method for resetting the filter does not work UNLESS you first unplug the unit. (Note: I have tried this only on model BAP1175/1300. I recommend unplugging it for an hour, but I really have no specific minimum time for this; in the past I unplugged it for five minutes as recommended by Bionaire phone tech personnel, but the reset did not happen.) Then, after an hour, plug in the unit, and press the On/Off button (on my unit, this button reads, "Off") and Sleep button (on my unit, this button has a "crescent moon" icon) simultaneously. (Again, not sure how long, but I recommend that you hold these down for at least 20 seconds.) Then, you can turn the device on, and it should reset to 99%. Good luck!
Posted on Mar 09, 2008
    New Friend:
OK, I have the table top version. I've had this very expensive paperweight in my house for a long time. It tells you to take a paperclip and reset both filtersfilters...... Which I did a thousand times. However, what no one tells you is you need to take a flashlight and look intointo those tiny holes. The one on mine goes downward on a deep 45` angle. So I tried again, this time pushing the paperclip downward on that 45 degree angle..... Bamm.... It finally reset. Had to believe that I spent hundreds of bucks on the machine and more on filters. The filters were probley still great.... But the reset hole was ******* up. Learn from my experience my friends
Loyally yours
Kurtis K. Cullen
Windsor, Ontario, Canada
Posted on May 24, 2016
  • 28 Answers
Press the sleep and power buttons at the same time
Posted on Jan 09, 2016
Sdf
Posted on Jul 09, 2008
Can the hepa filter be cleaned?
The link below will show a page on how to clean and care for your air purifier. Although the Hepa filter can be cleaned multiple times, the manufacturer recommends you replace it every 12-18 months.
Bionaire Air Purifier Care + Cleaning
Jan 09, 2012 | Bionaire LC1460-U Air Purifier
I had a honeywell hepa air purifier 50250 given to me as a gift with no owners manual! Is there somewhere I can get one? also, there is buttons on the top, one saying check filter and the other saying pre...
http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Mar 29, 2011 | Kaz Honeywell Hepa Air Cleaner (50250) Air...
Cannot replace cabin air filter
buy a new machine on a super sale deal
fyi
Holmes offers its Holmes Odor Grabber HEPA-Type Air Purifier, model no. HAP223-UC2, together with three Holmes HAPF22 Hepa Filters for $29.97 via the directions below. With free shipping, that's $30 off and the lowest total price we could find for this bundle by $33. Recommended for use in room up to 20-square feet, it features air purification and deodorizing. To get this deal:
  1. Add three Holmes HAPF22 Hepa Filters to your cart for $29.97
  2. apply coupon code "H0PVGRAB3" to add the Holmes Odor Grabber for free
May 25, 2009 | Holmes Products Bionaire Permanent Filter...
Reset Filter Indicators on BAP 725
there should be a small pin hole somewhere on the top of the unit. Stick a pin in there hold for about 3 seconds and it should reset.
Sep 01, 2008 | Bionaire HEPA Air Purifier Air Purifier
Not returning to 100%
Reset filter reminder:
Unplug power code.
Push and hold sleep button.
Plug power code while pushing sleep button.
LCD shows "P" than release the button.
Push sleep button and you can see 99% filter reminder.
Jul 09, 2008 | Bionaire BAP1300 Air Purifier
Bionaire bap825 air purifier
if you have a manual it will be on page 2 of the manual under cleaning and maintance. it willhave the picture there. if you don't have the manual. the hepa's go in first and they should snap on and the the carbon lays on top and then you put the back on the unti back on.
Apr 14, 2008 | Bionaire BAP815B-U Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Will not start up??
    Same problem here. Opened it but everythng seemed intact. Red light flashes momentarily during initial plug in. Has power, oscillates but no fan rotation.
    Nov 05, 2007 | Bionaire BAP1500-U Air Purifier
    Red Light indicator on
    I have a Bionaire tower air filter model BAP1700 that I bought from Costco. The filter check LED came on recently after 5 months of use. After cleaning the Permatech filters, I tried every remedy on this website including following the instructions that say push power button for 2 secs. Nothing worked. Then I noticed a tiny hole on the control panel in front of clean filter LED; I pushed a paper clip pin into that hole, felt a click, held it down and 2 secs later, LED went out. Success!
    Apr 06, 2007 | Bionaire BAP1500-U Air Purifier
    Dirty filter
    Noggin's solution is correct.  My copy of the BAP825 manual says to poke a paper clip into "the hole marked RESET."  There is no hole marked 'reset' on the air cleaner.  Thanks, Noggin!
    Apr 05, 2007 | Bionaire BAP825-U Air Purifier
    Bionaire BAP1175-U Air Purifier Logo
    2,807 people viewed this question
    Top Bionaire Air Purifiers Experts
    Bill Long
    Jay Finke
    Jay Finke
    Tim Whalen
    Are you a Bionaire Air Purifier Expert? Answer questions, earn points and help others
