Question about NAD L40 CD Player
My Sony cd player spins but won't play. Cleaned
My Sony cd player spins but won't play. Cleaned laser with cd cleaner but still won't play.
  • 4,234 Answers
Those CD cleaners rarely work. They are nothing but small brushes on a plastic CD. Unless the problem is loose dust, they won't work. Try carefully opening up the unit and cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, post the model number and I'll provide the replacement optics part number and cost. Some units have replacement optics that cost less than $15. Dan
Posted on Jun 15, 2009
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
When i put in a dvd into my player, it says no disc, and won't play, when it does accept the disc, it doesn't play it, then a "C:13:00" starts blinking. I should be able to just put in a...
It's most likely dirty, though it could be failing. The lasers have an average life span of 3 years, under normal use.
Several companies make CD/DVD laser lens cleaners. You want the kind with optical quality brushes on the bottom side. You simply put it in, let is spin up and play, then take it out. It may not play the first couple times you put it in, but it will be cleaning the lens and pickups.
If that doesn't do it, I'd start looking at sales for a new player.
Jul 05, 2011 | Sony Televison & Video
Sony boom cd/radio/cassette player says no disc and does not play even though the disc is spinning. The radio and cassette do work. We used a Dynex cd/dvd laser lens cleaner and it played for a short...
The laser diode is usually the first component to fail in optical disc players.
If you can, open the casing to expose the CD mechanism.
Point a cell-phone camera at the laser lens, which hides under a flat bridge.
Without a disc inserted, press play or eject / load the CD tray.
Via the camera, you should see the laser diode briefly flash as it tries to read data from where disc should be.
No flash means IR laser diode has probably burnt out.
Don't stare directly into laser beam for long periods with the ***** eye - rather use the camera as an interface.
The beam's visual color is red, but the CDS sensor of a digital camera sees the IR radiation as white on mobile's screen.
Dec 05, 2017 | Sony CD Radio Cassette Boombox, CFD-E90...
Spin both directions theb display show table error
Usually CD rotates in the clockwise direction. Whenever you are using CD which your CD player cannot detect then CD is rejected and suddenly CD rotates in anticlockwise direction.
Also, If your player is older and your CD players laser head worn out then CD's which were played good previously cannot be played properly and then stop in middle, when this happens you can see CD rotating in anti direction.
Clean the laser head, with CD cleaner and do not use scratched CD's
Aug 26, 2010 | Sony CDP-CX300 CD Player
No sound from cd player
the laser lens needs cleaned most likely, you can purchace a cleaning disk, or take the unit apart and used a eyeglasses cloth and very gently wipe the lens clean. the lens will be very small and near the motor that spins the cd. when wiping it off, wipe in one direction only. if that doesnt work then the laser has become weak or has quit working
Jan 14, 2010 | Sony CFD-E75 Cassette/CD Boombox
Sony CDP-C225 will not read or play cd's
Try running a "Laser Lens Cleaner" thru it, preferrably one that uses fluid. You can purchase one at just about any retail store for 15-20. Good to have and great preventative maintanance. If that does not work, you need a new transport, they do not repair or align lasers. Too expensive. The replacement is 100-150 with labor and a new one is under 200. My suggestion would be if the cleaner does not work replace it and keep the new one clean. CD/DVD/PC etc. all can and should be cleaned 3 or 4 times a year. Best preventative maintanance you can do. Hope this helps
Jun 24, 2009 | Sony CDP-C265 CD Player
CD player stopped working on Sony ICF-CD831 PSYC Clock Radio/CD P
I've been able to prolong the life on mine by doing this:
Insert the disc, then spin it by hand and quickly close the door and hit play.
It's always worth using a laser cleaner first, as it may just be dirty and stops spinning because it cannot read the disc.
Apr 26, 2009 | Sony PSYC ICF-CD831 Clock Radio
Durabrand CD player skips while playing.
hi i've had the same problem i though it was the laser or the laser rail until i opened it!! Then i checked the laser, the rail and all the other mechanical it worked fine, until i got to the laser it had a hair right in the middle, don't bother trying the cd cleaner it doesn't work! all i di is take out the laser cleaned it with a cotton suabe and alochol for a bout a minute and now it works beautifaully! also clean the circle thingy that spins and holds the cd! any little particle will make that laser not read the cd right! while ur there tryin cleaning the unit from dust! it's the worst ememy! well hope this helps!
Feb 19, 2008 | Audio Players & Recorders
Sony CD player C305 not playing
The laser or spin motor could be faulty.
Take it to a service centre for professional help.
John
Dec 15, 2007 | Sony CDP-CE375 5-Disc CD Changer
NAD L40 CD Player Logo
627 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
