Question about Waterway Spa Jet - Poly Jet Internal Pulsator Smooth - Black
No air from Waterway Poly Jet, just water
I installed a pool spa last year. It has 8, 210-6090 - Waterway Poly Jet Insert, Deluxe Series Roto, and I believe was installed with 210-5860 1"S Air x 1-1/2"S Water, Tee Body 1" PVC Air, 1.5" PVC Water. When we started the pool initially we did not hook up a blower. The movement of the water created enough vacuum to pull air into the air inlet pipe and the spa had "natural" bubbles without forcing air into the air lines. It worked that way for the entire season.
I noticed during the season that some of the jets wouldn't turn and flow was restricted in some too because of construction dirt in the jets. At the end of the season I removed all the jet inserts, replaced them with the required manufacturers plug. Over the winter I took them all apart and cleaned them so that when I opened the pool all the jets were free of the dirt and rocks and they all worked and spun perfectly. They still do.
My problem is that for some reason I lost the natural air flow. In fact, the water now seems to be backing up the air line when the pool spa is running. I've tried draining the spa, and restarting it. I even tried hooking up the return line from my shop vac. As soon as the water pressure builds, the water backs up and cuts of the air from the air intake lines.
What did I do? Is there a way to get this back to it's original working order?
5 Suggested Answers
  • 990 Answers
SOURCE: I just bought this pump
The wear ring on the impeller can cause all these problems. It seems natural to put this on the impeller with the wide side tward the impeller but it goes on with the wide side out so when the pump starts the ring slides forward and seals the pessure side of the impeller from the suction side. With this in wrong your water will just circulate inside the pump rather than going back to the spa. I hope this helps.
Posted on Dec 18, 2009
  • 11800 Answers
SOURCE: I have a Waterway SVL56
That means that the connection between the motor and the actual centrifugal pump is broken. This is terminal: replacing the broken part will cost you more than the price for a brand new pump. Just cut your losses and replace it.
Posted on Dec 18, 2010
  • 54 Answers
SOURCE: I GOT A 2 SPEED
Sounds like you don't have the pump lid "0" ring seated properly under the lid, or there is dirt or leaves on the "0" ring. This has to seal perfectly or the pump will not pump much if any water.
Posted on Sep 03, 2011
  • 372 Answers
SOURCE: Waterway pump not priming
Foam will definitely keep a pump from priming. Why do you think it's the calcium causing the foam? I have added large amounts of calcium to pools and I do not recall ever having any foaming issues.
Check to see if your impeller may be clogged. Take the lid off of the pump and fill the basket up with water. Leaving the lid off, start the pump for three seconds and then turn it off. The water should be sucked away almost instantly. If the water level drops slowly you have debris clogging the impeller. If that is the case the pump needs to be opened and cleaned.
Posted on Jul 24, 2013
Testimonial: "Thank you for confirming the foam issue, The reason we think its the calcium is that its the only new thing in the equation. I have have done as suggested and the water was sucked out of the pump instantly, "
Reinstall waterway return jet
turn all the way till it stops then back off 1/2 to 3/4 turn to open
May 05, 2014 | Waterway Pool & Spa
Lid on Waterway pump strainer cover is stuck
close valve when off then release air bleed or remove plug from pump to release pressure
Jul 01, 2012 | Waterway Pool & Spa
Hello. I am looking for a replacement jet for a waterway 218-4690 out of a Galbocca Spa. Can you help me?
I have a whole set for mine but you can't have those. If you can't find Waterway on line to find a local dealer you can try a place called Horizon Spa Parts in Tucson Az. They find almost any thing for me usually in a phone call. I have an account and things show up in tomorrows mail. Their number is 1-800-874-7727. Good luck.
Oct 19, 2010 | Pool & Spa
I discovered tiny ball bearings in my hot tub. Where could they come from? The hot tub is working fine.
The ball bearings from your spa are from a roto head jet. Typically they are from one of the larger sized jets and they make the swivel action in the roto swirl jets function smoothly. You can determine which jet is coming apart by the loose function of the center nozzle. The jet can be removed and replaced to solve this problem. Most jets screw out but when they have deteriorated a lot, you may need plyers to take the jet out in pieces.
Jan 03, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Replacement pump for spa (Waterway Executive Euro 2 speed 2 hp
V1 would be low V2 would be high U1 would be line and then ground. A picture would be helpful to be sure.
Jul 05, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Waterway Spa Jet - Poly Jet Internal Pulsator Smooth - Black Logo
148 people viewed this question
Top Waterway Garden Experts
Mike Raino
Level 1 Expert
john h
roeb
Are you a Waterway Garden Expert? Answer questions, earn points and help others
